what upgrade can I do to prevent my car from fish tailing
Old Sep 18, 2008 | 09:32 AM
JasonZ-YA's Avatar
JasonZ-YA
what width are the tires you are running and what brand, type of tires that said car is fish tailing on??
-j
Old Sep 18, 2008 | 10:35 AM
XKR's Avatar
XKR
Originally Posted by 3FIDDYZED
You could try one of these http://www.racelogic.co.uk/?show=Traction_Control tried, tested and developed on the Zed...
Also you dont the GT-Spec bracing? This has been known to help...
Nice....I have been looking for something like this...Kool
Old Sep 18, 2008 | 02:38 PM
THE ROADSTER's Avatar
THE ROADSTER
-j
19X 10.5 rear with YOKOHAMA Advan Sport.
new Michiline Pilot PS2 in on oreder with new rims.
Old Sep 18, 2008 | 02:45 PM
GTM's Avatar
GTM
Vendor - Former Vendor
This is what I am running on my G35 in order to prevent massive wheel sping/fish tailing when excess of 600rwhp.
1) Camber in rear set around -1 degree or less, you will sacrifice a little bit of handling but your traction will improve, maybe -0.5 a degree to get the most out of your tires. A good alignment is very important.
2) DOT Approved R-Compounds are the best bet for high horsepower street cars. Go down to an 18" and run some Toyo R888s or Nitto NT-01, I beleive the R888 is available in a 19" wheel as well but the 18's will do a bit better. I am running a 305 Toyo RA-1 in the rear of my G on my 18' Enkeis.
3) LSD - Quafie is going to be the best for a street car, ATS/Carbonetic and Cusco are also good, just are going to be a little anoying during turns at low speeds (tires chirp because they lock up)
Lastly, a nice audio setup in the trunk will add some weight in the rear for better traction, handling will decrease, and so will your acceleration, but you will hardly notice the difference with over 550rwhp. ( I am by no means recommending this as an upgrade, but if you were going to do it anyways it wouldn't hurt with traction.
Good luck!
-George
Old Sep 18, 2008 | 02:49 PM
XKR's Avatar
XKR
Thats what I use....305-25-20 Advan Sport....I dont have a problem with them....I guess the fact that I am using LSD does not hurt
I used the PS2 before going to the Advans....I like the Advan more.
Old Sep 18, 2008 | 02:51 PM
Jay'Z's Avatar
Jay'Z
Carbonetics diff/Hotchkis sways FTW.....
Old Sep 18, 2008 | 02:56 PM
350Zdj's Avatar
350Zdj
nismo LSD ftmfw!
ofcourse, work on the throttle control my friend.
Old Sep 18, 2008 | 02:57 PM
THE ROADSTER
thanks guys.
LSD will be my next mod and I will add the spare wheel back in the trunk.
Old Sep 18, 2008 | 04:38 PM
rcdash's Avatar
rcdash
What are your alignment specs? That would be the first thing I would check. Could just be that your toe is out of spec. EDIT: oops - I see George has already mentioned it. I would definitely do that first and work from there. I have a carbonetics LSD, PS2 summer tires, toe within spec, and -2.3 camber and my rear end will swing out to the right when I punch it (depending on the surface)... I don't think the LSD will solve your problem entirely. I'm putting on SPL A arms on the front so I can correct camber all around as George mentions above. Before you start adding on aftermarket traction control, consider that the Haltech can also cut boost based on wheelspin - I just turned this feature on after a scare on the streets and it works though I've got to fine tune it still... Next step is to pull timing on a wheelspin vs. lateral-G map.
Old Sep 18, 2008 | 04:45 PM
iflyjets86's Avatar
iflyjets86
driving skills, take a driving course
Old Sep 18, 2008 | 04:50 PM
rcdash's Avatar
rcdash
lol - always wanted to post that. seriously that is about as helpful as telling him not to drive the car... Trust me when I say that you have very little opportunity to employ "skills", regardless of how well developed or fine tuned, when you punch the throttle in low gear with 500+ to the wheels.
Old Sep 18, 2008 | 05:01 PM
fklentz's Avatar
fklentz
Lower your boost controller pressure?
Old Sep 18, 2008 | 06:00 PM
4SHIZZIL's Avatar
4SHIZZIL
widebody...13inch rims with 345/35/19!
that outta do her!
Old Sep 19, 2008 | 09:34 AM
iflyjets86's Avatar
iflyjets86
I'm not saying I have the skill, but if other 500+whp guys can do it, I'm sure this guy can. Seems like he just needs to gain experience in throttle control. Take it easy and slowly increase how hard you push the car. sooner or later you'll be able to take the training wheels off and you'll be the next DK lol....or not
Old Sep 19, 2008 | 09:49 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Throttle control is key. You cant mash it like you do on a stock block or NA.
Once you realize where the fine line of traction and slip is, you can practive staying there in 1st and 2nd gear runs. Eventually you will take your 500+whp car out in 40 degree winter days and dance down the highway in 3rd for fun. Like anything, practice, practice, and more practice. Also, when it starts to spin, dont let off all the way, the car will ***** you. Let off slowly, as soon as you regain traction your good to go.
Old Sep 19, 2008 | 09:54 AM
Tyler4's Avatar
Tyler4
^Alberto, do you have a LSD?
Old Sep 19, 2008 | 10:06 AM
Alberto's Avatar
Alberto
Cranky FI Owner
S T O C K
It's been good to me
Old Sep 19, 2008 | 10:15 AM
  #38
jumpin800agl's Avatar
jumpin800agl
8 to 11
Originally Posted by Alberto
S T O C K
Correct me if I am wrong but don't you run less negative camber in the rear of your car, closer to -1? i have around -2 in the rear and I was thinking of going with less to hopefully get better traction in 1 and 2nd.
Old Sep 19, 2008 | 10:17 AM
  #39
Alberto's Avatar
Alberto
Cranky FI Owner
-1 rear camber, 295/35 KDW's
In low boost (604whp now) it hooks half the time WOT in 2nd. The other half it needs a little peddling and its still moving quick. Going from -2.2 ---> -1 was a huge difference.
Old Sep 19, 2008 | 10:33 AM
  #40
Crom's Avatar
Crom
We should get a group buy goin on the r888's......
