View Poll Results: Which do you like?
SMC
5.56%
AEM
38.89%
SNOW
55.56%
Voters: 18. You may not vote on this poll
Which of these Meth kits do you prefer?
Old Sep 27, 2008 | 11:24 AM
SnyperZ's Avatar
SnyperZ
Default Which of these Meth kits do you prefer?
Ok Im trying to decide which kit to get..If I were looking to maximize power id absolutely go with the aqaumist kit..however Im just looking for an added safety blanket. I don't really care about the extra hp it will give me...I want to make a number and then add the kit and tweek the tune slightly..so if the kit were the completely fail the car would still be fine.
Old Sep 28, 2008 | 01:08 PM
SnyperZ's Avatar
SnyperZ
any recommendations?
Old Sep 28, 2008 | 01:46 PM
350 Rookie's Avatar
350 Rookie
I have the aem kit if you wanna buy it. 1 gallon tank. it hasnt been used, just wired up.
Old Sep 28, 2008 | 02:00 PM
SnyperZ's Avatar
SnyperZ
how much do you want for it?
Old Sep 28, 2008 | 02:02 PM
Zivman's Avatar
Zivman
from the limited experience I have with the kits, aquamist would be the only kit I would personally use. the others are like playschool toys in comparison IMHO
Old Sep 28, 2008 | 02:03 PM
SnyperZ's Avatar
SnyperZ
and I considered it but Im not going to double the price for something ill never need. I wont be using it to make more power..just to add to safety
Old Sep 28, 2008 | 02:14 PM
Zivman's Avatar
Zivman
OK then, buy whichever you like..... I have used the less expensive kits and they are less money for a reason.
Old Sep 28, 2008 | 03:53 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
It won't be very "safe" if it stops working...
Old Sep 28, 2008 | 04:02 PM
XKR's Avatar
XKR
I use the Snow and it works perfect...
Old Sep 28, 2008 | 04:18 PM
350Z400rwhp's Avatar
350Z400rwhp
Snow kit is fine. I used it and it works perfect.
Old Sep 28, 2008 | 07:23 PM
SnyperZ's Avatar
SnyperZ
yes it will..I plan to tune it close to the limit..but safe and then add this in small amounts just to make it safer...
Old Sep 29, 2008 | 06:07 AM
Zivman's Avatar
Zivman
the term "safe" in regards to this application is basically an illusion. It is a gamble regardless of how good your parts are... if you don't care if it stops working; by don't care I mean you feel your tune is "safe" without it, why buy any kit at all? Especially if price is a concern.
Old Sep 29, 2008 | 06:32 AM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
+1
Old Sep 29, 2008 | 06:48 AM
q8z's Avatar
q8z
Aquamist HFS-5?
Old Sep 29, 2008 | 06:53 AM
rcdash's Avatar
rcdash
Most kits have an option to detect a no flow condition. If that triggers a fail safe, such as preventing boost over wastegate pressure, then it should be fairly safe regardless of the kit used. One extra relay on the boost control solenoid is really the only extra part required. The Haltech is supposed to have its 32 in/out module coming out and that's the piece I'm waiting for so that the injection can be controlled directly from within the EMS using PWM (not just a trigger on/off).
Old Sep 29, 2008 | 08:46 AM
SnyperZ's Avatar
SnyperZ
Maybe I didnt put it clearly enough. The car will be tuned WITHOUT the meth..therefor it will obviously be fine without it..and then on top of that I plan on adding a small amout of meth to where I wont need to have it retuned...to further add protection..what is so hard to understand about that? I wasnt asking your opinion on my idea I was asking for opinions on kits...and if price was a concern I woulda went with a UTEC intead of haltech and saved over 1000.00 since they will both get me to where I want to be...
I also wanna thank you for the two educated opinions you've provided in this thread.
Old Sep 29, 2008 | 09:39 AM
Alberto's Avatar
Alberto
Cranky FI Owner
If your not tuning on meth, running meth will only make your a/f's richer. IMO its a waste at that point. If your only spraying small amounts, the cooling advantages will be slim to none.
Old Sep 29, 2008 | 10:02 AM
rcdash's Avatar
rcdash
It may not provide a sizeable horsepower gain, but it will cool the intake charge, it will run richer a/f ratios, it will cool EGTs, it will reduce combustion temperatures (with a W/M mix) - bottom line is that it will raise the detonation threshold. Definitely added safety and a good move, esp. on a stock block. I wouldn't recommend 100% meth. A w/m mix is the way to go if horsepower isn't the only goal.
Old Sep 29, 2008 | 10:17 AM
XKR's Avatar
XKR
Alberto is correct...if not tuned on Meth it will run rich which will rob you of power. FP had mine set to spray around 14psi..but for some reason it was spraying at 11psi which lowered my A/F from 11.9 to under 9...when this happened the car studdered....the problem was fixed. It is now going to be setup to spray at 16psi's
Old Sep 29, 2008 | 11:05 AM
eagletanggreen's Avatar
eagletanggreen
Got Track!!!!!
I may have my meth kit for sale $500 bucks...
Alky kit its what all the big players are using everything else is just mainstream...
