Deatschworks Fuel Injectors
Old Sep 28, 2008 | 09:24 AM
OldManZ350's Avatar
OldManZ350
Default Deatschworks Fuel Injectors
Originally Posted by Mike@DW View Post (1-23-2008)
In the past we (DeatschWerks) have rated our 350z injectors at 3.5 bar because that is the stock fuel pressure. But with our recent over haul of our VQ35 product line, switching from OEM cores to brand new Denso cores, we also switched back to 3bar like the rest of our applications. We used 3.5 bar because we thought it would make thing easier since that is the stock fuel pressure, but it really caused more confusion.
Our line up now consists of all Denso injectors rated at 3bar
440cc
600cc
850cc
custom sizes also available
Hope this helps
-Mike
APS are also rated at 3 BAR. So whatever the flow rate says is the who you can expect.
So the sumation for flow rates @ stock fuel pressure and what power you can expect....
APS: As Advertised
RC: As Advertised
Deatschwerks Denso Core NEW*: As Advertised
Deatschwerks OEM cores: 550 (480-500whp), 440 (380-400whp), 650 (580-600) approx. at stock fuel pressure.
JET
Are you saying that, OEM CORE 440cc DEATSCHWERKS INJECTORS WERE RATED @ 3.5 BARS.
Old Sep 28, 2008 | 11:02 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
APS has always been rated at 4 bar, if my memory is correct. Hence, their 880cc injectors were really closer to 750cc, and their 500cc injectors were closer to 440cc. Unless they recently switched to the industry standard 3 bar flow rating, I think they still "overrate" their injector flow rates.
DW, HKS, Denso, and RC are all true to industry standard.
Old Sep 28, 2008 | 01:34 PM
QuadCam's Avatar
QuadCam
that'swhat they are saying.
I have the OEM core Deatschwerks 550s. At 3 Bar, they flowed 500 cc/min.
Old Sep 28, 2008 | 03:25 PM
Glex25's Avatar
Glex25
so lets say since now they rate their cores @ 3bar.
Would that make their 600cc injectors in a APS kit which is 4bar closer to 700cc?
Old Sep 28, 2008 | 05:41 PM
QuadCam's Avatar
QuadCam
right. I don't know what the exact number would be, but it would probably be 700 cc/min or more at 4 bar.
Old Sep 28, 2008 | 06:43 PM
JonnyC's Avatar
JonnyC
Yup, just bought some OEM core 440's which will be more like 400. I might end up maxing them out pretty quickly :-/
Old Sep 29, 2008 | 04:15 AM
Mike@DW's Avatar
Mike@DW
You can use this fuel pressure correction calculator on our website.
http://www.deatschwerks.com/catalog/...alculators.php
To know the true "call size" of any brand injector you do need to know the testing pressure they are rated at. Common testing pressures are 3 bar, 4 bar, and 5 bar. 3 bar is the most common, or what can be called the industry standard (there really is no industry standard, we wish there was). More and more stock fuel systems are 4 and 5 bar, but 3 bar is still the standard.
But you also have to know what the fuel pressure your system is at. With the use of FMU's, return systems, upgraded fuel pumps, AFPR, and changes in rails and lines, an accurate fuel pressure gauge is very helpful.
Old Sep 29, 2008 | 04:44 AM
Audible Mayhem's Avatar
Audible Mayhem
My350z
kinda early to be working in OK right now isnt it ?
Old Sep 29, 2008 | 05:43 AM
Mike@DW's Avatar
Mike@DW
I am usually up and working by 6 am every day. Fuel injection waits for no man.
Old Sep 29, 2008 | 09:34 AM
athenG's Avatar
athenG
/\ so what is the failure rate of Deatschwerks at 95% IDC? I've had mine for about 1 1/2 year and I have always been above 90% IDC. Granted I don't Redline everyday but I do spend a lot of time up there when I feel the need for speed.
Old Sep 29, 2008 | 10:50 AM
Mike@DW's Avatar
Mike@DW
It is not wise to run injectors at that high a duty cycle. The chances of something happening is slim but it is something to be concerned about.
Basically you are running the risk of 1 or more injectors going static.
Old Sep 29, 2008 | 11:08 AM
Barzten1's Avatar
Barzten1
In the market for injectors but looking for something slightly used. I have RC 550's now. Need bigger.
Old Sep 29, 2008 | 01:08 PM
Audible Mayhem
My350z
i can get you whatever injectors you need. shoot me a pm or give me a call.
thanks
