vac line or boost controller? Please help me
Old Oct 4, 2008 | 01:05 PM
G35cTT's Avatar
G35cTT
Default vac line or boost controller? Please help me
My car was running perfect until a couple days ago my Hi boost was peaking out at like 8psi normally it's 19psi. My lo boost is 14.5 and only goes to 7.25psi and no boost controller I'm supposed to be at around 10psi but only goes up to 5 or 6 psi. Is that a vacuum line issue or do you think my GReddy Profec B boost controller is broken? Any suggestions/help would be greatly appreciated.
Old Oct 4, 2008 | 03:14 PM
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
Trying to understand your statement... if wastegate boost is 10psi and you are only seeing 5 or 6, it is a mechanical failure meaning the boost controller has nothing to do with it. You should be checking for a leak - such as cracked exhaust manifold.
Old Oct 4, 2008 | 03:25 PM
G35cTT's Avatar
G35cTT
So wouldn't be something minor like a vac hose?
Old Oct 4, 2008 | 03:46 PM
Dynosty's Avatar
Dynosty
If you remove a vacuum hose from the wastegate, boost will increase. If the boost controller failed, you would see wastegate boost. You can not set boost lower than wastegate with any boost controller.
Depending on how you have your wastegates plumbed, it could be possible that you have a boost leak on the intercooler pipe side of things.
Old Oct 4, 2008 | 04:15 PM
SnyperZ's Avatar
SnyperZ
x2..or a crack somewhere else on the hotside(pre turbo)
Old Oct 4, 2008 | 04:46 PM
G35cTT's Avatar
G35cTT
I have the GReddy TT kit and just recently had a new bumper put on so I'm hoping it's the IC piping is loose and no cracks anywhere. Thanks for your guys input and will post what I have found out.
Old Oct 10, 2008 | 04:52 PM
G35cTT's Avatar
G35cTT
Checked everything a friend suggested vac line and another shop suggested silicone boots on intake side. It ended up being a split vac line that goes to my BOV. Back in action, and thanks for the input/help. Glad it wasn't a cracked manifold or something serious.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
