Boost spike/creep problem again.
Old Oct 22, 2008 | 10:21 PM
zads's Avatar
zads
Originally Posted by JAMEZ@CiNcity
Serious question Raj; where do you learn all this?
btw, does PID=Proportion Integral Derivative?
Yep, PID is a control algorithm that can be used for any closed-loop feedback- controlling speed, temperature, (boost) pressure, whatever.
You can also just use P, PI, PD, etc, depending on the situation/application.
Old Oct 23, 2008 | 02:10 AM
hydroflip's Avatar
hydroflip
what kind of wastegate do you have? if you have a turbonetics, get a tial
Old Oct 23, 2008 | 02:46 AM
djtimodj's Avatar
djtimodj
Sound like you a power and control tech/instrument mech! ha..
Old Oct 23, 2008 | 05:17 AM
rcdash's Avatar
rcdash
Sorry I didn't mean to be confusing. Just giving you a starting point for the parameters to plug into the boost controller.
I learned it because I was running open loop but wanted to run closed loop so read some engineering articles on PID closed loop feedback algorithms. Everything is on the net.
Here is mine for the Haltech using a 30 Hz boost solenoid (I have an internal wastegate setup, but for boost control, I think this all still applies similarly):
Start duty cycle: 35%
Target boost turn on point: 3 psi (that is the feedback becomes active 3 psi before target boost)
Proportional: 8
Integral: 4
Derivative: 0
If you search on Google, you'll find the setup for the Hydra EMS. The #s are all very different. I would highly recommend starting small. You will find that boost response suffers and you don't reach target boost. BUT you are safe! Then gradually increment #s and track your boost. Just need to dial it in...
EDIT: And many thanks go to Hal at Injected Performance and Sharif at Forged Performance for providing insight along the way. I bet I've asked Hal more questions about the Haltech than any other person on the planet.
Old Oct 23, 2008 | 05:37 AM
JAM3Z's Avatar
JAM3Z
Phenom
Got any particular websites that are informative, Raj?
Old Oct 23, 2008 | 05:48 AM
rcdash's Avatar
rcdash
http://en.wikipedia.org/wiki/PID_controller is a great place to start. It's not really complex at all. The table halfway through that tells you what happens when you increase parameters is all you really need to do some troubleshooting (e.g. it tells you that if you increase Proportion and Integral, overshoot INCREASES, etc.).
(I think their first graph is labelled wrong though, it shows the overshoot increase with a lower Kp - I think they got that backwards. The text, tables, and remaining graphs look correct to me though.)
Old Oct 23, 2008 | 06:13 AM
JAM3Z's Avatar
JAM3Z
Phenom
Good stuff. Thanks Raj
Old Oct 23, 2008 | 08:22 AM
Blwn_By_Twins's Avatar
Blwn_By_Twins
I have dual tial 44mm's. A buddy of mine told me they maybe getting gunked up b/c of soot and I should take them apart and clean them. Any thoughts on that?
I've tried setting the b/c @ 8.5psi and it still creeps. I'm beginning to think it has to do w/ the weather at least some b/c it did it worse when it was below 55deg. I got on it hard yester day and it only did it a little. I even turned the gain down on the BC. There has to be something I can do to keep it from doing it in cold weather, right?
Old Oct 23, 2008 | 09:44 AM
SnyperZ's Avatar
SnyperZ
X2. And I bet im a close second!! haha
Old Oct 23, 2008 | 09:47 AM
SnyperZ's Avatar
SnyperZ
if they were getting gunked up then you have other issues. I took my wastegate off a few weeks ago to fix a pipe problem and my wastegate had a thin layer of black soot on it as it should and wiped off easy. If theres enough on there to jam it up then you have a bigger problem than you know of.
Old Oct 23, 2008 | 09:51 AM
Blwn_By_Twins
I'm going to try resetting my EVC again and see if that fixes it. Thanks for the info bout the gates.
Old Oct 23, 2008 | 02:04 PM
hydroflip's Avatar
hydroflip
turbo manifold design...or lack there of.
Old Oct 23, 2008 | 05:53 PM
SnyperZ's Avatar
SnyperZ
how would that cause over boosting?
Old Oct 24, 2008 | 02:20 PM
hydroflip's Avatar
hydroflip
It has to do with having very low exhaust backpressure and the air not making the turn into the wastegate due to a small pressure differential between the turbine and wg inlet.
Old Oct 24, 2008 | 03:04 PM
hydroflip's Avatar
hydroflip
just took a look at the manifold design on the greddy kit...looks like that shouldnt be the problem..whats your timing set at? and a/f?
Old Oct 24, 2008 | 03:54 PM
SnyperZ's Avatar
SnyperZ
never seen it.
Old Oct 26, 2008 | 08:29 PM
boostedmaxima's Avatar
boostedmaxima
Not sure if it's spiking b/c when I take off I keep my eyes on the road, but it's going up to 9.9psi w/ the boost controller off. My springs are 8.5psi and I have the EVC 6 bc. It did it one time before after I disconnected the batt. I had to reset everything on the BC. This time it's just started doing it on it's own and I have no idea what to check.
If you are not wanting to go much over 8.5 you probably want to get a 5 lb spring. I had a tial wg with 8.5spring thinking it wouldn't go over 8.5 but it would spike to 11 when you just jump on the throttle. I downgraded to a 5 lb spring and I have to hammer it to get it up to 8. With ebc it just allows you to run higher psi by just regulating the vacuum signal to the wg. An 8.5 spring probably starts opening the gate around 5 psi. All this is relevant if you have no vacuum leaks in the wg line you checked.
Old Oct 27, 2008 | 10:05 AM
  #38
Blwn_By_Twins
I was thinking of putting smaller springs in for normal driving anyway. Thanks! I shouldn't need it re tuned for that, right?
Old Oct 27, 2008 | 10:36 AM
  #39
SnyperZ's Avatar
SnyperZ
I didn't even think of that..you *shouldn't need a retune..your midrange might change a LITTLE bit due to different boost levels on the way up to 8.5
Old Oct 27, 2008 | 04:51 PM
  #40
Blwn_By_Twins
Okay, reset the the BC today, it is still doing it. It is definitely creeping, not spiking, & weather related. It was up in the 70's outside today and it held boost fine. It dropped to the low 50's after the sun went down and it started creeping. Hit 8.5 and kept going up to 9.0 when I let off just before RL. I have fuel line run to the wg's my friend said, so they shouldn't be crushing. I' gonna try to replace the springs if nobody has any other ideas.
