APS Twin Turbo Installed: Multiple Cylinder Misfires! HELP!
Old Oct 27, 2008 | 03:42 PM
weslutes's Avatar
weslutes
If you didn't put the steering shaft back together exactly the way it was, all the slip lights & traction control will go crazy.
Old Oct 27, 2008 | 06:54 PM
specialized5223's Avatar
specialized5223
that explains it. it is off slightly. i was told it had to be rotated atleast 180* to throw the sensors.
thanks
Old Oct 28, 2008 | 08:10 AM
str8dum1's Avatar
str8dum1
how can your steering be off, mine was notched and only went together one way???
interesting
Old Oct 28, 2008 | 12:04 PM
specialized5223
Mine is notched as well but theres about 40 notches around the shaft... So it's seemingly easy to put the wrong ones together.
Old Oct 28, 2008 | 01:37 PM
weslutes's Avatar
weslutes
yep. It took me a few tries to get it right.
The whiteout i used to mark it smeared onto 3 notches. I drove it in a straight line(to settle the suspension/alignment), farward then back. Jacked it up, removed the shaft, straightened the wheel, then put the shaft back on.
The 1st time I did it, infiniti charged me $80 to fix it. I knew I could fig it out
Old Oct 30, 2008 | 07:31 PM
TSG-Z's Avatar
TSG-Z
I got the code it was like P0300 for multiple cylinder misfires.
I'm throwing the same code along with the NATS, I need to get my car inspected, I'm fuked!
Old Oct 30, 2008 | 07:45 PM
kihun's Avatar
kihun
I get that mis-fire sometimes. It didn't happen when I replaced spark plugs.. or maybe I haven't noticed because I dont drive my Z too much.
Old Oct 31, 2008 | 07:51 AM
specialized5223
I replaced my plugs. It isnt misfiring any more but I still get the code.
This that code going to effect my emissions?
Old Nov 12, 2008 | 06:49 PM
03ZHIFT's Avatar
03ZHIFT
**** it. Pull the cel bulb
Old Nov 12, 2008 | 09:03 PM
specialized5223
lol
Old Nov 13, 2008 | 05:56 AM
350 Rookie's Avatar
350 Rookie
I still want to know why the random mysfire comes on. Just because you have a turbo? No, i dont think so. There must be a reason.
Old Nov 13, 2008 | 06:59 AM
specialized5223
Well figure it out then inspector gadget. damn...
lol I'm just kiddin man.
Old Nov 13, 2008 | 07:18 PM
350 Rookie's Avatar
350 Rookie
Ill try to once im done blowin up motors.
Old Nov 14, 2008 | 05:52 AM
Cass007's Avatar
Cass007
- that was a good one.
Do a search, there are many threads about the dreaded CEL issue, some people have fixed and some have not (like me), but YES it will cause you to fail emissions if they plug in to your OBD port.
Old Nov 14, 2008 | 07:59 AM
350 Rookie's Avatar
350 Rookie
Im about to open an emmissions shop for all you turboed z owners. Ill pass anyone for only a Big N Tasty with extra pickles.
Old Nov 14, 2008 | 08:07 AM
specialized5223
Your easy. Call me.
sherm
Apr 11, 2020 05:21 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
