Deatchsworks Injector Clips
Old Nov 13, 2008 | 02:24 PM
dskang100's Avatar
dskang100
Default Deatchsworks Injector Clips
I noticed the stock injector clips don't fit snug over the Deatchwerk injector's.. I mean.. I know they are drop in's and other people are telling me they just used the stock clips but it just doesn't seem snug because the Deatchwerks are a bit wider at the base.. anyone know what I'm talking about and have any advice?
Old Nov 13, 2008 | 03:44 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
hmm...I havent had any issues with the OEM injector clips fitting the DW injectors. They should click right on.
Old Nov 13, 2008 | 03:48 PM
str8dum1's Avatar
str8dum1
mine didnt clip either. bolts the rails down and have been fine since.
if i could only get all my AN fittings from that NO2 Y adaptor on my RFS to stop weeping....
Old Nov 13, 2008 | 04:16 PM
TinmansZ's Avatar
TinmansZ
^ 2nd that I have the AAM fuel rails with deatchworks inj. there wasn't anyway to use the clips, haven't had any issues going on for a year and a half now.
Old Nov 13, 2008 | 06:43 PM
dskang100's Avatar
dskang100
Thanks for the responses guys. I feel more comfort since Sharif decided to step in as well.
I've solved my problem.. I pretty much just clipped them on even if they are a little loose.. we have 4 big bolts holding down the rail so meh.. I'm positive i'll be fine!
Old Nov 13, 2008 | 06:44 PM
str8dum1's Avatar
str8dum1
you'll if its not right know when u fire the car.
Old Nov 13, 2008 | 11:30 PM
350z006's Avatar
350z006
I thought I didn't need the clips myself (the Turbonetics manual says you don't have to re-use the clips), and I was fine w/ 440's...but when I went to 650s for some reason my injectors would pop out under boost, even with those 4 bolts....I decided to try putting the clips on, and I haven't had any problems since...
BTW, these are with RC's....
Old Nov 14, 2008 | 02:49 AM
dskang100's Avatar
dskang100
Yes I guess I will because there will be like.. you know... possibly an engine fire
Old Nov 14, 2008 | 05:05 AM
Mike@DW's Avatar
Mike@DW
It took me reading your post a few times to realize you are referring to the fuel rail retainer clips, not the electrical clips from the injector harness.
The retainer clips are not necessary.
Feel free to give us a call if you have any questions
-Mike
405 415 6862
Old Nov 14, 2008 | 05:07 AM
dskang100's Avatar
dskang100
-Mike
405 415 6862
Oops, i'm sorry about the confusion. I always refer to those things as harnesses but I can see why you call them clips too.
Yes it was for the METAL clips that hold the injector down into the block.
Old Nov 14, 2008 | 06:45 AM
IIQuickSilverII's Avatar
IIQuickSilverII
very nice to see your issues taken care off
should not be long till you finish up your build ...
Old Nov 14, 2008 | 06:49 AM
jeffie7's Avatar
jeffie7
I also thought the electrical connection clips.
Old Nov 14, 2008 | 06:56 AM
Sharif@Forged
Forged Performance
-Mike
405 415 6862
Mike, I just reread this, and I thought the same thing! Brilliant minds think alike. Glad its all good.
Old Nov 14, 2008 | 07:01 AM
dskang100's Avatar
dskang100
Got the cats off last night which was a breeze thanks to PB, and now I just have to hook up the piping and do the gauges! Jeffie has been helping me a lot via PM
In order to do the AC line do I have to go pick up a special tool to do that?
Old Nov 14, 2008 | 01:54 PM
z2envy's Avatar
z2envy
To make life easier you might definatly want to pic up the tool to pop them out. It was a breeze with that lil tool. They arn't very expensive either. You can get one at any car parts store too. It just slides over the pipe and then you push it into the socket and Pop the pipe right out. Very handy lil tool.
What tool did you end up using to get the cats off? I know the PB blast works awesome I had to use it too.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
