Anyone tried using Defi sensor on FCOn VPro?
I have 6 Defi gauges on my APS TT with F Con Vpro and AFK.
(Oil temp, water temp, oil press. EGT, Boot, fule pressure)
I only have MAP and AIT for f con now.
It's good to monitor those, but would be much better if I could use those sensor for F Con and run compensation table.
Has anyone tried to use defi sensor to HKS IF module?
Thank you guys for your help.
chopperman, thank you for your reply.
I am in Il-San.
So, it works with IF module. I am thinking of installing camp2 and get rid of all the gauges and keep the sleeper look.
I am in Il-San.
Hey man check with rookie the FX35 dude he tried the Defi Sensors with the HKS IF Unit, but the MAP/Boost Sensor didn`t give an accurate readings, about the others he reported that they did run fine,
Sorry to hijack your thread but the NEW question is can we use The Defi sensor for both HKS/Defi units at the same time ??
liqalu04
Jan 2, 2022 12:58 PM
bcoffee20
Nov 19, 2015 06:39 PM
