VQ35DE Swapped and Superchaged 1998 Maxima
Old Nov 4, 2008 | 08:16 PM
mastercater7's Avatar
mastercater7
Default VQ35DE Swapped and Superchaged 1998 Maxima
I know that this is a 350z forum; but the car has almost identical characteristics with a 350z. I wanted to post on here to share my project as well as do my best to help others. I am a member on maxima.org, but as far as having a boosted VQ35, there are not many people. Thus, needing input or help with problems can be hard to find. Well I put the motor back into the car. Anyways the setup is a 2004 VQ35 on 3.0 timing, V2 on a V1 bracket, 2.87 pulley, 3" charge piping, JWT ecu with 370cc and z32 maf, z32 maf, Deatschworks 600cc injectors, Cattman headers, 3" warpspeed catback (waiting to be installed), Innovate LC-1 wideband, Greddy EMU, ARP rod bolts, and a short shifter. The only problem I have had so far is the the damn injectors and their clips. The injectors are deatschworks 600cc's. For some reason, these clips will not fit snug like the stock injectors do. Someone please tell me the secret!
Thanks,
Zack
Old Nov 4, 2008 | 08:17 PM
mastercater7
Entire engine bay. The 3.0 piping did not agree with the throttle body position, what a head ache:
I cut a hole in the fender for the cold air:
HKS SSQ blow off valve:
300zx maf and overflow relocated:
Old Nov 4, 2008 | 08:19 PM
mastercater7
Some interior shots, I dont have a boost gauge yet because I am still trying to decide how to hide it, yet see it.
The Innovate LC-1 gauge:
And finally the exterior. I am going for the complete sleeper look, which is also why I want my gauges hidden.
I hope ya'll enjoyed these.
Old Nov 4, 2008 | 08:28 PM
Mr_pharmD's Avatar
Mr_pharmD
how u get the HKS BOV to work with the vortech??? do u need to change anything?
Old Nov 4, 2008 | 09:02 PM
mastercater7
No, Just have the flange welded onto the charge piping. I LOVE the SSQ blow off valve. Have you had trouble with it?
Old Nov 4, 2008 | 09:08 PM
350Z400rwhp's Avatar
350Z400rwhp
Very cool and nice sleeper! What kind of power are you making? Is the torque steer bad? I have the d-werks 600cc injectors and they dropped right in like stock and no clips or harnesses needed.
Old Nov 4, 2008 | 09:11 PM
Lawy'dU's Avatar
Lawy'dU
a bov will not work with a vortech without modification. The bypass valve that vortech uses is different from a bov.
Old Nov 4, 2008 | 09:24 PM
mastercater7
For the injectors, you didnt use those clips that came on the stock injectors that cliped them into the fuel rail? Anyways, I am having some MAJOR belt slipping issues. One of the mounting points for the blower to the V1 bracket sits directly under the supercharger pulley. The V1 bracket was made for the VQ30DE and the tensioners and placement of certain other pulleys are slightly different. In order to tighten the belt enough so it doesn't slip, it wants to rub on that mounting post. The best I could get on the dyno was 305whp and 301wtq and 5200rpms around 6 - 7 psi. It should be pusing around 13.5 psi. The most boost we saw was a quick spike to 8 psi. I have to pull the bracket and blower assembly off and take a saw to that post. Also I am going to try a half inch shorter (in length) belt to prevent the belt from arching into eachother between the supercharger idler pulley and the stock tensioner. It sucked that I paid for a useless tune due to the belt slip, but I am impressed with the numbers at such low boost and with the belt slipping so bad.
Zack
Old Nov 4, 2008 | 10:03 PM
mastercater7
I can't take credit for the BOV because the previous owner of the kit had the flange welded into the pipe. As far as I know, there wasn't any extra modification needed. I just tapped the vacuum line for the VI and I haven't had any problems. Why won't the BOV's work with the Vortech kits? I would think that they would once the flange is welded into the piping and you tap a good source of vacuum. Is there a certain reason they won't work? I searched around on the maxima.org forums and the only thing I saw was something about the spring.
Old Nov 4, 2008 | 10:31 PM
DracoLancet04Z's Avatar
DracoLancet04Z
pretty cool sir
Old Nov 4, 2008 | 11:19 PM
mastercater7
I had a quick question for ya'll that are running the Vortech kits. What brand belts do ya'll find the best? I have heard some people say gatorbacks, and I have heard people say the gatorbacks are terrible and slip a lot. I am planning on special ordering a gates belt (I can't find an autoparts store around that stocks them). Any ideas?
Zack
Old Nov 5, 2008 | 04:20 AM
chris'smax's Avatar
chris'smax
WRONG
I used a greddy type-s on my vortech setup on my maxima and it worked perfectly fine.
Old Nov 5, 2008 | 04:27 AM
chris'smax's Avatar
chris'smax
Zack
gatorbacks worked best for me.
I think i was the first one to do this setup. My car was a 2000 w/ a 3.5, V2 SC, and cams. I was on maxima.org a few years ago. That is going to be a fun car man, i just wish i could have got mine running right before i got rid of it.
Old Nov 5, 2008 | 04:39 AM
Highway Riding's Avatar
Highway Riding
Nice build.. A close friend of mine had a 1998 black maxima charged and it hauled A$$.. Vids pls..
Old Nov 5, 2008 | 05:29 AM
mastercater7
I will definitely post up some vids and final dyno numbers once everything is ironed out. With meth injection, I think I can get her up into the high 400's range.
Zack
Old Nov 5, 2008 | 05:30 AM
SirSpeedyZ's Avatar
SirSpeedyZ
sweet, what a sleeper
Old Nov 5, 2008 | 05:32 AM
mforrest100's Avatar
mforrest100
Originally Posted by chris'smax
WRONG
Understandable but you will have surge. The best BOV to use with the V2 is the Vortech Mondo. I too had a VQ35 swapped 4th gen supercharged in 2006. Just never posted it. You can find my for sale threads in maxima.org under the screen name mforrest100.
Old Nov 5, 2008 | 06:59 AM
hydroflip's Avatar
hydroflip
im thoroughly impressed...looks like the engine sits high...can you close the oem hood?
Old Nov 5, 2008 | 07:28 AM
chris'smax's Avatar
chris'smax
after some adjusting of the pre-load spring mine worked fine. I am sure there was some surge, but not enough to affect the SC bearings. My blower had like 30,000 miles w/ this setup when i sold it and never had a issue w/ it.
BTW i remember you from the org, is your name mike? Do you have a z or g now?
Old Nov 5, 2008 | 07:33 AM
gothchick's Avatar
gothchick
Nice.
