all APS Single Turbo owners come in.
Old Nov 18, 2008 | 11:16 AM
  #41
Cide's Avatar
Cide
Originally Posted by Zivman
headers are easy compared to a turbo/twin turbo install. Even with the stockers, you will need to get at the bolts and 'adjust' them to allow for clearance.
well i know that but it will save me having to change out the passager side
Old Nov 19, 2008 | 12:19 AM
  #42
travismaser's Avatar
travismaser
ok i have a few questions on the aps st kit...i just bought the kit about 2 months ago (while on deployment) and i get home sometime in dec...im going to start doing the install shortly after, but i wana make sure i get EVERYthing right...i cant risk a blown motor...
so my questions are:
-should i upgrade to a U-TEC? or will the unichip be fine for running 9lbs (at or right under 400hp)
-i work at an exhaust shop and we were going to build my NISMO exhaust and turbo XS test pipes to fit it...will that provide the proper exhaust flow for it??? or should i go bigger?
-who is a good tuner in the seattle/ tacoma area?
-i read in a few posts that i will have to change out some turbo parts soon after i buy it and upgrade...is this true?
- and finally, i want this motor to be safe...will a tune be enough or should i look into replacing a few internals?? i hear our rods arnt to strong on the VQ (if so..what would you recommend replacing, and with what?)
i know some of these questions might be dumb but i am a noob in the fi world...i had a STI b4 the z but never really did much to the turbo...and iv been searching around alot latly and cant find many answers...i get mixed answers
Old Nov 19, 2008 | 05:44 AM
  #43
Zivman's Avatar
Zivman
Not worth the extra money for the utec. The unichip will be more than capable
take another look at the exhaust setup. You will not be able to use any test pipes in the setup... modified or not. The nismo should flow adequately, but I would still recommend the APS single exhaust
According to the APS site, drift office is your closest dealer. I would contact them first if local is of concern
Not aware of this... do you have more specific details?
You don't just 'replace a few internals'. You would be looking at a full rebuild. If that is the case, you will want to be looking into a twin setup of some sort. Your motor should be fine for the most part with a proper tune
keep researching... you have more to learn about the setup
Old Nov 19, 2008 | 02:42 PM
  #44
travismaser
thanks alot zivman!!! that helps alot...just backed up everything iv been reading a lil more and explained each part better then i have found...
as for the turbo parts that keep breaking, i will look around and see exactly what it is, i know what it is to picture it but i cant remember the proper name haha
Old Nov 19, 2008 | 03:26 PM
  #45
zads's Avatar
zads
You have intake piping that runs through that area as well as the hot pipe off the turbo to the IC..... On the TN kit is the exhaust piping
I am kind of with rookie on this one, "I dont understand why this is so hard to understand. LOL"
Well its hard to just imagine what you're talking about- I ordered a ST kit, but haven't seen one installed yet so I can't really see all the clearances you're talking about. (couldn't find many pictures of the intake piping installed)
Your last statement makes more sense though. I can definitely see there being interference issues with aftermarket headers + TN/Powerlab exhaust downpipes, but I didn't know the intake piping on the APS ST got that close to the exhaust headers.... that's not a good thing, if it does get close..
Old Nov 19, 2008 | 03:44 PM
  #46
travismaser
zivman- ok i searched around and i found some things that were happenign to the earlier APS ST kits...they had a mechanical check valve and i guess the new kits have an electric check valve.....does anyone know how you know if you have a new styl kit or the pld style?
Old Nov 19, 2008 | 04:23 PM
  #47
Zivman's Avatar
Zivman
I think it is safe to assume all new kits are shipping with the updated electronic check valve.
Maybe it's just me, but before ordering any kit, I had checked all the manufacture's sites. I read through the install instructions and looked at the component lists to know exactly what I was getting. Check APS' site and look through the install instructions and check out all the pics they have, you will have a much better understanding of the setup
edit:
LINKED: APS site for your convenience
LINKED: Install instructions for your convenience
Please reference the install diagrams on this page
Please reference the component list -> you will notice APS part # 000-094-100 "SOLENOID - OIL CONTROL" that looks like this:
^ if your check valve doesn't look like that, you will want to get that one prior to installing... but like I said, it is safe to assume that all new kits will be shipping with this solenoid
and just a fun little bit of info:
The G in the following video Please right click save as
Now looks like this:
Old Nov 19, 2008 | 04:48 PM
  #48
travismaser
edit:
LINKED: APS site for your convience
LINKED: Install instructions for your convience
i bought the kit from z1motorsports so i assume it is the new kit with the new check valve...when you look at the specs on the z1 site it just sends you straight to the aps site...but i guess i wont know for sure till i get home in dec and look at all the parts
thank you for all the help tho! its greatly appriciated
Old Nov 24, 2008 | 04:40 AM
  #49
nightcrawler_8's Avatar
nightcrawler_8
i have a question regarding the unichip that comes with the ST kit. its pretuned ..
but i am in a place were the temp is much like a desert. 45 degree on avarage ans sometimes reach the 50mark...
petrol i am using is 98 octane... i believe the tune is done on 91.... ( correct me if am wrong )
i was not planning to keep the kit as it is out of the box till i get used to the power then tune it for more power.. so would the unichip given in the kit is enough.. or i have to retune it ???
keep in mind i am not after power. am after reliability and more secure tune.
Old Nov 24, 2008 | 05:00 AM
  #50
Dynasty.Zero's Avatar
Dynasty.Zero
Unichip is fine I ran the Unichip at 380whp for 2 years and nothing bad happened.
Old Nov 24, 2008 | 05:38 AM
  #51
nightcrawler_8
what was the weather conditions ???
and what is the petrol octan ???
i am using 98 octan ?? i am pretty sure it makes a differnce right??
Old Dec 6, 2008 | 11:49 AM
  #52
nightcrawler_8
hey APS fellas
since teh turbo is very low on the APS ST. do u guys ever wash the car from below???
an if its winter .... does that mean u should never drive on rain ???
i am installing my kit next satarday and its raining these days. so shall i just keep the car away from rain ???
thanks in advance
Old Dec 6, 2008 | 02:41 PM
  #53
JoeDirtPharmD's Avatar
JoeDirtPharmD
Rain is fine
Old Dec 6, 2008 | 07:11 PM
  #54
nightcrawler_8
Originally Posted by JoeDirtPharmD
Rain is fine
thanks for the reply .. but it was way much smaller than i expected hehehe
can i have some more details. just lil bit. thanks buddy
Old Dec 7, 2008 | 05:15 PM
  #55
JoeDirtPharmD
OK, driving in the rain will be fine
It's not a big deal, just don't take the car extreme off-roading, you'll be fine with where the turbo is positioned.
Old Feb 13, 2009 | 04:38 PM
  #56
VeilsideZ33Mass's Avatar
VeilsideZ33Mass
OK so ive had the kit on my car for almost two years and put maybe 5K on it.
I can tell you this, my kit was older, so i needed the check valve. Currently I made a custom downpipe with a tial 44mm gate because the stock APS setup overboosts. And as for the Uni Chip its garbage. NO ONE tunes it, and i think you have to remove it each time to load a map... Mine is for sale if anyone wants it. I have a Utec and I like it, not perfect, but much safer and more capable I think. Theres also a oil blow by issue sometimes because of the turbo being so low but im putting on a Force Performance inline oil filter to hopefully aid that issue. As for upgrades, I heard none of the TT setups broke 1000hp, I could be wrong. Intense power has a powerlab kit modded and it made 900+hp... my OPINION is that the aps kit should kit in the 600hp range maxed out, as for upgrades, Im more then sure you could stuff a larger turbo under there if your willing to cut up your Z a bit. things likt the frame rail and the K member. All in all I stumbled into my kit for 4K shipped and so far it works brilliantly makin 371hp and 380ftlbs on a DD.... AT 6-7PSI (aps wg sucks)! I also have their exhaust... Like I mentioned before these are my opinions... Im sure they'll **** someone off... but I wouldnt bother with the TT setups... most of them max out close to 600hp too I THINK... APS Extreme is prolly the best one... but I intend to hit 900hp on my APS ST, im sure they'll be cutting and welding, but thats the fun of it! APS FTW.
Old Feb 13, 2009 | 05:29 PM
  #57
tig488's Avatar
tig488
what does your downpipe look like, post some pics.
Old Feb 13, 2009 | 05:59 PM
  #58
JAM3Z's Avatar
JAM3Z
Phenom
Do they even sell the APS single anymore?
Old Feb 13, 2009 | 07:25 PM
  #59
nightcrawler_8
VeilsideZ33Mass: post some pics of the WG pipes.
discontinued already.
Old Feb 14, 2009 | 03:18 AM
  #60
captj3's Avatar
captj3
900 hp that remains to be seen from this kit. The best so far is approximately 500 rwhp.
