Built motor issues with piston oil squarter???
Old Nov 7, 2008 | 03:44 PM
Mr_pharmD's Avatar
Mr_pharmD
Default Built motor issues with piston oil squarter???
What could be the cause for the piston to break off the 3 oil squirters in the block??? I found one in the oil pan and not sure where the other pieces went. Could it still be inside the block somewhere? What are my options at this pt???
Pistons have a little nick on them (just needs resurfacing) and rods arent bent.
The freakin builder, BZM won't take responsibility for the mistakes and keeps telling me it's my installer/tuner's fault.
What am I suppose to do now???
Old Nov 7, 2008 | 03:48 PM
teh215's Avatar
teh215
This sounds familiar from years ago. I do not know the exact answer but IIRC it had to do with improper clearencing.
Old Nov 7, 2008 | 04:19 PM
Sean's Avatar
Sean
this has indeed been known a long time.....but there should not have been any of the old impropper rods still on anyones shelf
here is a thread from 2004
https://my350z.com/forum/forced-indu...ease-read.html
Old Nov 7, 2008 | 04:35 PM
r0mey's Avatar
r0mey
idk why bzm wouldnt stand behind it
Old Nov 7, 2008 | 04:41 PM
Sean's Avatar
Sean
for fun, do a search of BZM on this forum. the locked threads at the bottom are epic.
Old Nov 7, 2008 | 04:51 PM
str8dum1's Avatar
str8dum1
you are supposed to pull the motor and do a rebuild, apparently.
sucks, hopefully you can get it done for cheap!
Old Nov 7, 2008 | 05:36 PM
Mr_pharmD's Avatar
Mr_pharmD
BZM wont even return my calls now. Supposely Todd Pickman is no long building motors and feels it's not his fault.
I see the link for the Arias pistons but I have wiseco pistons so do all aftermarket pistons have this issue? Am I suppose to ask the machine shop to take 1/8 more clearance off to not hit the squirters???
Old Nov 7, 2008 | 05:47 PM
r0mey's Avatar
r0mey
I can see this thread being EPIC
Old Nov 7, 2008 | 05:48 PM
Sean's Avatar
Sean
Arias wasn't the only piston to have the issue, yes you need to show the thread to the machine shop.
there is no excuse for this as I am sure at some point they were aware of the issues. someone built the engine and screwed up...if they want to blame it on the piston maker that's on them. I would sue BZM over it.
Old Nov 7, 2008 | 05:51 PM
DanielW's Avatar
DanielW
rut ro rorge
Old Nov 7, 2008 | 10:13 PM
thawk408's Avatar
thawk408
Pistons were installed backwards. Did it break off both banks or just one? Due to the location of the oil squirters the pistons have to be installed a certain way to clear the squirters (provided they are cut correctly). If the were installed 180 degrees from the correct way, then it will break off the squirters.
Old Nov 7, 2008 | 11:09 PM
phunk's Avatar
phunk
CJ Motorsports
thawk is correct. if they are properly cut to clearance the squirters than they need to be facing the correct direction, that also applies to the valve reliefs as they are often cut to provide more or less clearance depending on if they are for the intake or exhaust valves which are significantly difference in size.
if the pistons were not machined to clear the squirters its not a big deal... that is, if you catch it before the engine is running in the car... which is not the case here i take it. its no big deal for any machine shop to cut the clearances and rebalance the pistons, however it requires an entire rebuild. you could grind them in the block if you remove the engine and upper oil pan... but this is at your own risk and no one will tell you its the right way to do its.... its one of those things you would do to your own car but never someone elses.
hell, with all the problems with oil squirter clearance in this motor over the history of VQ35 builds, you would think that oil squirters were new as of 2003... but they are not, not at all... and the piston manufacturers look really retarded for not considering them from the get-go. as for a builder not noticing... well, while they should have learned to check... 20 sets of good pistons later it wouldnt surprise me that they took it for granted and didnt notice if they were sent a set that doesnt clear... its not exactly OBVIOUS as the natural position of the skirt would barely hit it anyway. on my first engine build way back in the day we didnt even notice right away but luckily we did catch it before the heads were put on and it wasnt a big deal to cut the reliefs, rebalance, and assemble.
Old Nov 8, 2008 | 06:18 AM
06Track's Avatar
06Track
While we can blame this on the piston manufactures, it really comes down to the
engine builder WHO should, as part of the blueprint process, go over every detail
including all tolerances which includes CLEARANCES between rotating parts. Alot
of GOOD builders actually build an engine twice,,,once to assemble most of a shortblock
and check everything, disassemble and clean everything once more, then off to the
final build. Same goes for a longblock! Blueprinting an engine is NOT the same thing as
assembling one.
Old Nov 8, 2008 | 06:54 AM
westpak's Avatar
westpak
SFZCC
assembling one.
This is half correct, the engine builder doesn't build it twice, unless he has a full machine shop and does everything in house, but if you use an outside machine shop to do the balancing/cylinder bore/bearings, they will put it somewhat together to pick the right bearings but you really don't build it all up and tear it down to just clean and put it back together
related to OP I believe GTM has some squirters that have additional clearance, I know it would be a pain in the **** to do it in the car but check with a shop to see if they would replace them, GTM says it can be done, I really have not looked to see if there is enough clearance to get at the squirters while trying to get past the main caps, crank and around the rods.
Old Nov 8, 2008 | 07:54 AM
go-fast's Avatar
go-fast
assembling one.
+1 i assemble and reassemble multiple times with strokers checking as i go.if he missed squirter clearance,then he didn't do his job an should repair the motor.you should never trust the parts.......always confirm math,or suffer the conseqences.
Old Nov 8, 2008 | 07:59 AM
Mr_pharmD's Avatar
Mr_pharmD
This is what Todd wrote, "I sympathize for your situation so I am trying to help u out- I can not assume liability or responsibility in this matter as there are several variables involved and we deliver a product that is clearanced, machined, assembled and ready for operation.... After startup we can not be held accountable for other mishaps that can occur with a high performance forced inducted engine. I realize you have theorized that all of the squirters broke upon startup, but we check these clearances after Machining, upon assembly, to identify such an issue before a problem occurs. Sorry to hear about your issues u are having and let me know if you'd like me to order those parts for you."
If he says he checked these clearances how would the squirters get broken???
Old Nov 8, 2008 | 08:03 AM
350 Rookie's Avatar
350 Rookie
Why would it matter if the car is FI'ed or not. its not like more air pushes the pistons down more. He knows he fuked up but he doesnt wanna admit it or pay for it.
Old Nov 8, 2008 | 08:29 AM
westpak's Avatar
westpak
SFZCC
it does matter, if this happened soon after install then yes the builder is obviously at fault but if this happened after some miles then you need to look into more.
Old Nov 8, 2008 | 08:46 AM
Mr_pharmD's Avatar
Mr_pharmD
seriously. he keeps blaming the tune and the sc for braking them. How do I take legal actions?
Old Nov 8, 2008 | 09:22 AM
thawk408's Avatar
thawk408
Unless the pistons/rods got trashed due to a bad tune, then yes maybe that could of caused the oil squirters to brake off if they had excessive play. That is HIGHLY unlikely tho. Id put my money on improper piston install. Did you buy a longblock from BZM?
