Fuel Pump Fuse
Old Nov 8, 2008 | 10:11 AM
dskang100's Avatar
dskang100
Default Fuel Pump Fuse
Can someone please tell me where the fuel pump fuse is? I know there's only 2 locations for fuses... in the driver's side foot well and one in the bay next to the battery but none of them say they are for fuel :-(
Old Nov 8, 2008 | 10:30 AM
westpak's Avatar
westpak
SFZCC
in the engine compartment, next to the battery
Old Nov 8, 2008 | 12:00 PM
dskang100's Avatar
dskang100
I brought the cap over for the fuse box and according to PL's instructions the fuse is a 15A.
The closest one I can see on this cover that is also 15A is.. "ENG CONT." I pulled that out and ran my car for about a minute and it wouldn't stall.
The other 15A fuses are Horn and Radio.. so I didn't touch them.
Can anyone please elaborate for me?
Old Nov 8, 2008 | 12:41 PM
westpak's Avatar
westpak
SFZCC
wrong fuse "box" there is another one almost behind the battery next to the firewall, you have to remove the black trim over the battery area to get to it
Old Nov 8, 2008 | 12:46 PM
dskang100's Avatar
dskang100
Thanks so much. Going to find that!
Old Nov 8, 2008 | 07:41 PM
350 Rookie's Avatar
350 Rookie
OR you can pull the fuse inside, its a 15a fuse called ign cont. Thatll disable the fuse. Thats what i pull when i wanna do a compression test.
Old Nov 9, 2008 | 03:40 AM
dskang100's Avatar
dskang100
I'll keep that in mind.
I found the fuse thanks to both of you.
Old Nov 9, 2008 | 06:20 AM
westpak's Avatar
westpak
SFZCC
Not sure that will do it, it may disable ignition but fuel will still be in the lines and spray as you crank, the manual states to pull the fuse in the engine compartment
glad you found it
