Battery
Old Nov 11, 2008 | 08:18 AM
Cannysage's Avatar
Cannysage
Default Battery
Is everybody using just a standard battery? The shop put in an old asz battery and charged me for a new one. It was sitting at 12.9 or so volt from day one. after a few months, it's at 12.3v with a warning light coming on from my turbo timer (just the other day, It didn't even have enough juice to crank over and had to charge it).
is everybody using just a standard battery? any benefits of getting a deep cycled battery? i've read some peeps having longevity issues with optima.
Old Nov 11, 2008 | 08:38 AM
westpak's Avatar
westpak
SFZCC
good old Sam's club battery, had to buy one on the road back from Zdays a couple of years ago, no issues.
Old Nov 11, 2008 | 08:55 AM
XKR's Avatar
XKR
I use the Optima Red...there is no issues with it.
Old Nov 11, 2008 | 08:59 AM
doug's Avatar
doug
I have a regular Autozone Battery and a 1500 watt stereo system
Old Nov 11, 2008 | 08:16 PM
rcdash's Avatar
rcdash
I've tried Optima yellow top, Odyssey light weight, Optima red top, and regular old NAPA off the shelf. The last was the cheapest and has done well. Both yellow top and Odyssey did not last long. The red top has done well in my other cars.
If I had to recommend - I'd get a cheap, heavy (standard) battery.
Old Nov 11, 2008 | 09:11 PM
SpoilsofWar's Avatar
SpoilsofWar
I'm willing to bet the cause of your drain is an improperly wired wideband O2 sensor. If wired wrong, its heating the element all the time, and thus killing your battery. I had the same problem with my braille battery (which was a whole lot easier to kill anyway) until I rewired it.
Old Nov 11, 2008 | 11:18 PM
Cannysage's Avatar
Cannysage
that's 2 'Ok's for the optima red top.. might have to try it out
definitely not. My battery was sitting at 12.9v when it was put in. I'm positive it was a used pos. New batteries should be around 15v.
Old Nov 12, 2008 | 10:52 AM
SpoilsofWar
Ah my bad, I spaced on that line in your original post.
I was just saying that cause I know a lot of people who've had mysterious battery drains after going FI, and the cause was improperly wired wb's
Old Nov 12, 2008 | 11:33 AM
GTM's Avatar
GTM
Vendor - Former Vendor
I have an Optima red top, been happy with it. Let me know if you need the part number since we need the one with the reverse polls.
Good luck,
-George
Old Nov 12, 2008 | 01:24 PM
ToastZ's Avatar
ToastZ
NAPA or just OEM.
I have the largest cranking amp NAPA battery Sharif could fit into the car. Not sure of the part number, if interested I could look further.
Old Nov 13, 2008 | 07:34 PM
Cannysage's Avatar
Cannysage
Good luck,
-George
I think it's the INSSC34R.
Originally Posted by ToastZ
NAPA or just OEM.
red top is apparently 800 cranking amp.. should be plenty. dunno exactly what the stock numbers are but it's a lot less, i believe.
anybody know where I can pick this up? I'm think superautobacs might carry them.
Old Nov 13, 2008 | 07:56 PM
350Z400rwhp's Avatar
350Z400rwhp
I'd go with a stock one, mine has lasted 5 years and still going strong. Of course I have had the same luck with NAPA batteries in the past with my other cars.
Old Nov 13, 2008 | 08:10 PM
RED RIDER's Avatar
RED RIDER
don't believe what the box on your pyramid amp tells you...
Old Nov 14, 2008 | 03:14 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
OEM battery, even with a stereo, there is zero need for anything else - and they are inexpensive
Old Nov 14, 2008 | 04:15 PM
XKR's Avatar
XKR
If you are asking about the Red Top....Autozone is where I picked mine up.
Old Nov 14, 2008 | 06:12 PM
doug's Avatar
doug
don't be an ignorant a-hole.. wow look who's talking ****.. the guy with a full JL Audio system.. you just lost all credibility
Old Nov 14, 2008 | 06:21 PM
Escobar's Avatar
Escobar
Can't go wrong with optima, don't know if it is really worth the extra money though.
Old Nov 14, 2008 | 06:24 PM
surfcity40's Avatar
surfcity40
IMO, don't skimp on a battery. It is a maintenance issue that YOU have control of, unlike some you'd rather be in control of but Nissan tries to do so.
Old Nov 14, 2008 | 10:41 PM
RED RIDER's Avatar
RED RIDER
lol don't be jealous...1 sub and two amps dont quite make it a FULL Jl system though...
so lets see pics of your 1500 watt system...
Old Nov 16, 2008 | 10:54 AM
doug's Avatar
doug
keep looking.. you will see it.. they are all around.. so what do you have for components? probably something generic and weak like your choice of JL Sub and Amps
