Vortech with Hi Flow Cats - DO I NEED A NEW TUNE
Old Nov 13, 2008 | 02:28 PM
Bashar368's Avatar
Bashar368
Default Vortech with Hi Flow Cats - DO I NEED A NEW TUNE
Just as it is stated in the title. I have a 2004 6mt G35 with a vortech SC. I replaced the factory pulley to a 3.12 pulley a have a custom tune. I am thinking about removing my factory cats and replacing with a Hi Flow Cat. Do I need to retune the car, or I can get away with the old tune. Thanx
Old Nov 13, 2008 | 02:31 PM
JET MECH's Avatar
JET MECH
do you have a wideband A/F meter installed in the car?
Old Nov 13, 2008 | 02:32 PM
k6750gsxr's Avatar
k6750gsxr
i would get it re tuned because thats just me ... i like to know i am getting as much power as i can. But freeing up the exhaust more you are going to maybe lose a little psi which will chng your tune.
If you already have a tune your shop should re tune it cheap due to not taking more than a hour to re tune.
Old Nov 13, 2008 | 02:48 PM
Bashar368's Avatar
Bashar368
I am getting the afr wideband installed tomorrow, I was thinking to kill 2 birds with one stone.
The guy who tuned the car is about an hour away from me and he'll probably charge me the full price to retune it. I am guessing it is not even worth it to do all that work for a few ponies.
Old Nov 13, 2008 | 06:20 PM
booger's Avatar
booger
your going to free up the motor quit a bit....get it re-tuned
Old Nov 13, 2008 | 06:46 PM
str8dum1's Avatar
str8dum1
what ems? if UTEC, takes only a second to do a few logs and adjust the AF accordingly (assuming you have a wideband AF meter and logging software to combine everything)
your timing shouldnt have to be changed.
Old Nov 14, 2008 | 06:07 AM
Bashar368's Avatar
Bashar368
I am running the Split second box
Old Nov 14, 2008 | 10:29 AM
jpc350's Avatar
jpc350
A dyno with A/F and decide on whether a tune will be necessary...$75?
Old Nov 14, 2008 | 01:57 PM
JET MECH's Avatar
JET MECH
i recently removed my aps 2.5" test pipes and installed my 2.25" high flow cat's. did not retune, monitored my AFR's through out the power band and everthing looks ok. ( 11.0 to 11.5 AFR's ) did not alter timing, it is running like a champ! also picked up a bit of low end tourqe and lost minimal high rpm power. it is more enjoyable to drive now. a little more tourqe and no exhaust rasp....
Old Dec 22, 2008 | 03:39 AM
350z006's Avatar
350z006
Which HFC's are you using...I just switched to Crawford HFC's and I'm getting some rasp when boosting...trying to find an HFC which won't rasp with a Vortech....
Old Jan 1, 2009 | 04:11 PM
civic4982's Avatar
civic4982
so how did this end up turning out? how different was the A/F after the TPs?
Old Jan 5, 2009 | 01:47 PM
tylerxfire's Avatar
tylerxfire
Old Jan 6, 2009 | 06:31 AM
Bashar368's Avatar
Bashar368
I am still on stock cats..
AbrasiveRaysive
Sep 20, 2021 02:29 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
Li1ag
Sep 28, 2015 02:07 PM
