So happy about Powerlab's V2 IC
Old Nov 14, 2008 | 07:25 PM
dskang100's Avatar
dskang100
Default So happy about Powerlab's V2 IC
Yay no cutting!
Stuff for tomorrow.. I'm almost done..
Old Nov 14, 2008 | 08:04 PM
SlideFox's Avatar
SlideFox
Niiiice!!! Congrats!!!! Will she be running tomorrow?
Old Nov 14, 2008 | 08:44 PM
jeffie7's Avatar
jeffie7
show off... =(
I still need to hack my crash bar more, its sitting out back of my house lol.
I also had to cut A LOT of my front bumper to make it fit.
bigger is not always better.
Old Nov 15, 2008 | 03:19 AM
dskang100's Avatar
dskang100
Unfortunately no, I still have most of the piping left to do and gauges.
First I have to figure out HOW to wire up these gauges.. I know there's a firewall grommet above the gas/brake pedals and there's probably a power source I can tap(Maybe cig lighter)..
I figure that Oil Pressure will go in one of the bung's in the oil pan, then innovate WB will go nearest the engine bung in the downpipe and then o2 sensors will go in the last two. EGT... well I guess I will have to get a bung drilled.
For the boost however I think i found a picture on the forums where they just hooked up the vacuum tube on that little nipple that comes off the plenum.
Old Nov 15, 2008 | 04:43 AM
z2envy's Avatar
z2envy
i had to cut alot of my bumper off too. The bottom valance and my scoop
Old Nov 15, 2008 | 06:47 AM
SnyperZ's Avatar
SnyperZ
I only had to do some slight trimming off the corners(on both sides) of the inside of the grill on the bumper where they stick out. From the outside you can't even tell.
Old Nov 16, 2008 | 08:21 PM
BabyZiLLa's Avatar
BabyZiLLa
So the Powerlabs kit now comes with a smaller IC meaning no/less cutting? Did i get that right?
Looking at ordering my kit this week.
Old Nov 16, 2008 | 08:23 PM
str8dum1's Avatar
str8dum1
yes less cutting
Old Nov 17, 2008 | 02:45 AM
dskang100's Avatar
dskang100
Originally Posted by str8dum1
yes less cutting
No cutting at all for me, unless it has some sort of issue with the stock front bumper.
Old Nov 17, 2008 | 05:16 AM
UMW350Z's Avatar
UMW350Z
Meh...mines bigger and she says it fits juuust right
Old Nov 17, 2008 | 08:28 AM
z2envy's Avatar
z2envy
Mine I had to trim the Crash bar to fit it and also had to trip the bottom of my bumper alil as well as my bumper scoop. I have the stillen bumber so it's alot diffrent then the stock one. If you have the stock bumer you should be fine.
350Z_Al
Oct 29, 2020 07:44 PM
May 30, 2017 03:28 PM
Ganglio
Europe
Sep 26, 2015 07:06 PM
