My Build: The Good, The Bad & The Progress
Old Jul 11, 2009 | 06:34 AM
  #1521
Cass007's Avatar
Cass007
The crank is done. The rod bearing from #5 fused itself to the crank.
My Build: The Good, The Bad & The Progress-p7090222.jpg My Build: The Good, The Bad & The Progress-p7090223.jpg My Build: The Good, The Bad & The Progress-p7090224.jpg
My Build: The Good, The Bad & The Progress-p7090238.jpg My Build: The Good, The Bad & The Progress-p7090239.jpg
Old Jul 11, 2009 | 06:36 AM
  #1522
XKR's Avatar
XKR
here is my question..... Which shop is going to pay for this??? I am just waiting for you to say the customer is happy!!!!
You know where I stand in all this..... I don't care what's found.... The point is you paid for a car that runs....and from what I see ( unless I missed something) that's not what you received.
Old Jul 11, 2009 | 06:49 AM
  #1523
tylerxfire's Avatar
tylerxfire
yeah this blows, dude car needs to be up and running for u asap...
Old Jul 11, 2009 | 06:55 AM
  #1524
Havok_RLS2's Avatar
Havok_RLS2
Attachment 249295 Attachment 249296 Attachment 249297
Attachment 249298 Attachment 249299
Looks at if the car was run with no oil in it at all.
Old Jul 11, 2009 | 07:08 AM
  #1525
Cass007's Avatar
Cass007
The cam covers show some wear again, but Jim said there is zero chance of any of the cosmetic peices causing an issue.
My Build: The Good, The Bad & The Progress-p7090213.jpg My Build: The Good, The Bad & The Progress-p7090214.jpg My Build: The Good, The Bad & The Progress-p7090215.jpg
My Build: The Good, The Bad & The Progress-p7090218.jpg My Build: The Good, The Bad & The Progress-p7090219.jpg
Old Jul 11, 2009 | 07:14 AM
  #1526
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
No offense Chris. But I truly believe there was zero chance that your cosmetic enhancements (powdercoating) caused the first failure either.
Regardless of which shop pays, I think it would be wise to insist that Justice builds your next motor.
  #1527
Chef-J's Avatar
Chef-J
Booooosstt!!
+1,
Old Jul 11, 2009 | 07:20 AM
  #1528
thefireboy's Avatar
thefireboy
i guess the oil dialysis from black stone sill say alot...
Old Jul 11, 2009 | 07:26 AM
  #1529
Cass007's Avatar
Cass007
The original oil analysis showed the car to be healthy with nothing out of the ordinary. Nick, if you have access to it maybe you can scan and post it. Jim and Frank agreed that sending a sample that was removed at teardown would be useless since there is so much material that has been put in the oil.
Old Jul 11, 2009 | 07:30 AM
  #1530
Cass007's Avatar
Cass007
Pics of the heads - they are a loss as well. Cam journals are all messed up, so cams are done too.
My Build: The Good, The Bad & The Progress-p7090231.jpg My Build: The Good, The Bad & The Progress-p7090235.jpg My Build: The Good, The Bad & The Progress-p7090232.jpg
My Build: The Good, The Bad & The Progress-p7090227.jpg My Build: The Good, The Bad & The Progress-p7090230.jpg
Old Jul 11, 2009 | 07:31 AM
  #1531
Havok_RLS2's Avatar
Havok_RLS2
So when you got the first oil sample none of that grey sludge was in it? Where did it come from?
Old Jul 11, 2009 | 07:33 AM
  #1532
Cass007's Avatar
Cass007
The timing cover looked fine and the oil journals were all completely sealed.
My Build: The Good, The Bad & The Progress-p7090220.jpg My Build: The Good, The Bad & The Progress-p7090225.jpg My Build: The Good, The Bad & The Progress-p7090226.jpg
Old Jul 11, 2009 | 07:34 AM
  #1533
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
FAWK
I was hoping you would only have to replace the shortblock.
Old Jul 11, 2009 | 07:37 AM
  #1534
Cass007's Avatar
Cass007
The pistons showed a very slight amount of detonation, but not on cyliders 2 or 5 where the bearings failed. Jim said this was most likely caused by the bearing and oil starvation washing out the rings and letting some oil into the combustion chamber.
My Build: The Good, The Bad & The Progress-p7090233.jpg My Build: The Good, The Bad & The Progress-p7090234.jpg
My Build: The Good, The Bad & The Progress-p7090236.jpg My Build: The Good, The Bad & The Progress-p7090237.jpg
Old Jul 11, 2009 | 07:39 AM
  #1535
go-fast's Avatar
go-fast
this does not look like a tuning issue
bearings,cams and end play will look like that after a contaminated oil situation,going out on a limb,i would suspect the oil pump ate your bearings.just cause it looks good means squat,it's a close tolerance pump.either pump faliure or the worst assembly ever.....that's my vote
if this was my snafu you would be running already,question is why the dragging of feet?everyone knows they're part of the build.....get it done.who pays what is for later.
Old Jul 11, 2009 | 07:44 AM
  #1536
Havok_RLS2's Avatar
Havok_RLS2
Agree 1000000000%
Old Jul 11, 2009 | 07:45 AM
  #1537
XKR's Avatar
XKR
No more..... No more pictures... This is a d@mn horror story!!!!
that's what I have been saying..... Let's move on to the part where. Shop "A" takes care of customer. Customer gets in car and loses control of car in parking lot with a smile on his face
Old Jul 11, 2009 | 07:46 AM
  #1538
Cass007's Avatar
Cass007
Just a few more and then I am done Mike.
Old Jul 11, 2009 | 07:52 AM
  #1539
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Both shops should have agreed to have Justice build a new motor ASAP for Chris and then settle the blame/debts later.
Old Jul 11, 2009 | 07:53 AM
  #1540
Cass007's Avatar
Cass007
Cylinder walls.
My Build: The Good, The Bad & The Progress-p7090241.jpg My Build: The Good, The Bad & The Progress-p7090244.jpg My Build: The Good, The Bad & The Progress-p7090245.jpg
My Build: The Good, The Bad & The Progress-p7090246.jpg My Build: The Good, The Bad & The Progress-p7090247.jpg
