having issues-might be paranoia-update w/pictures
Old Nov 27, 2008 | 05:50 PM
terps's Avatar
terps
Default having issues-might be paranoia-update w/pictures
alright having some issues and wanted some input.
-keep on getting cylinder 5 misfire codes, consistantly with multiple misfires but more concerned about why cylinder 5 is being specified.
-heavy smoking on WOT pulls. can't see it during day( tinted windows might be affecting in) but at night I engulf the car behind in a wall of smoke. just changed to 0w40 mobile one so it might just be the thinner oil passing the turbo seals. on reg. driving no smoke what so ever
-just noticed on cold start up( mornings) my car exhaust spits water(did not rain earlier) and water is beading in pipe. could be condensation but again this after 30 secs with ac off.
my af are in the 11's and utec is not sensing knock nor does the motor feel like its missing a cylinder. coolant levels are good and no sign of oil. running 1 step colder platnium plugs with aprox. 15K miles on them.
maybe being paranoid but I recalled one cylinder going first before the motor takes a dump. I heard that plugs should be good for atleast 30k but also know some change them as frequently as 10k. got a retune recently so that might have a factor. probably nothing major but would like my fears put to rest. thanks
Old Nov 27, 2008 | 05:52 PM
surfcity40's Avatar
surfcity40
clearly it's parania.
Old Nov 27, 2008 | 05:58 PM
shift-er's Avatar
shift-er
A misfire is a misfire. No paranoia in my opinion. The rest seems almost natural on a FI Z.
Definitely check into cyl. 5. That dosent mean however that the motor is gonna necessarily meet its doom
Old Nov 30, 2008 | 12:05 PM
iflyjets86's Avatar
iflyjets86
heavy smoking on WOT pulls is paranoia and natural FI Z stuff??? could be wrong, but my turboed z deff. doesnt smoke
Old Dec 4, 2008 | 03:05 PM
terps's Avatar
terps
update- took it to AAM since I was in the area, they pulled the plugs and plug 5's had a larger gap, a 4 or 5, ended up switch the plugs to copper and ideal was smooth.
Thanks clint@AAM
also picked up a turbosmart evo specific BOV @ams used for 150 installed and am back to a recirulating setup. got to tweak the spring setting since its setup for 20lbs+ but it already sounds nicer. ill take picture and sound clips but the fit is BETTER than the APS, sounds better and looks nicer
Thanks cory @ams tuning
Attached Thumbnails having issues-might be paranoia-update w/pictures-00002.jpg   having issues-might be paranoia-update w/pictures-00001.jpg   having issues-might be paranoia-update w/pictures-00005.jpg   having issues-might be paranoia-update w/pictures-00006.jpg   having issues-might be paranoia-update w/pictures-00003.jpg
Old Dec 5, 2008 | 11:19 AM
terps's Avatar
terps
my plugs look lean. i havnt used octaine booster and my afr are reading in the 10's(11's on the dyno afr). so im kinda at a loss, possibly engine breaking had to do with it since my breaks were shot i was engine breaking for a bit
Old Dec 5, 2008 | 12:47 PM
Cass007's Avatar
Cass007
please fix the spelling in the title, its bugging the **** out of me - lol.
Old Dec 5, 2008 | 12:55 PM
doug's Avatar
doug
for your smoking issue.. read here https://my350z.com/forum/forced-indu...lve-cover.html
i noticed i had lots of smoking, crankcase pressure and oil problems..since i went to 0w40
this weekend i'm going back to 10w40 and adding a breather filter.. and prior to that i added a catch can
Old Dec 5, 2008 | 01:04 PM
Cass007's Avatar
Cass007
Thank You Terps!!
Old Dec 5, 2008 | 02:52 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I have some stumbling in the 1500-2000 rpm range under light load and i am thinking its the plugs.I am going to switch to copper plugs and see if it makes a difference.
Old Dec 5, 2008 | 05:21 PM
frankie945's Avatar
frankie945
Are you using the mobile 1 0w40?
That's what I use and I have to let my car warm up for like 15 minutes just so the pressure will go down. And I burn a bit more with the 0w40.. I have been thinking of switching on the next change.
Old Dec 5, 2008 | 05:23 PM
doug's Avatar
doug
i'm using Rotella T-Sync 0w40....
hmm.. you think letting the car warm up for some time reduces pressure? seriously.. i MUST try that because i'm desperate at this point
Old Dec 5, 2008 | 05:33 PM
frankie945's Avatar
frankie945
Well just by watching the oil pressure gauge, I'm almost at 80 then After warm up it drops to 35 at idle. I guess that's just the oil pressure not crankcase pressure. Under boost it's at 60 after the car is good and warm.
Old Dec 5, 2008 | 05:35 PM
doug's Avatar
doug
i got rid of my stock gauges.. so i don't even know
aggie300zx
Aug 24, 2002 10:26 AM
