turbonetics or vortech. . daily driver???
You need a better tuner. Reflash's suck get a real EMS and re-tune it. Reflash are only good to scale injectors , raising idle, and speed limiter removal, IMO.
If you want more power out of your TN kit. SFR T-67 Single turbo system-Interest?
The thing is, they could have gotten more power out of my car, but they said that it was not running "consistently", so they left it at that. I would post my dyno but I dont want to hi-jack the thread...
I have the vortech, also it's carb certified, so no worries about here in CA when it comes to the smog checks either. Plenty of hp for me, I do not boost, and I have the NISMO Headers, and NISMO Catback Exhaust also. It's runs smooth and good gas mileage. No lights, no problems, just like stock, smooth as a hot knife through soft butter. Love it on the hwy too.
thanks for more vortech input, seems legit as far as passing emissions and all those tests, but will it when using 2.87 pulley, bigger injectors and utec tune or only with the 3.12 with fmu and ss box
I have the JWT Clutch, JWT Flywheel, and JWT Cams. I can't answer the question about the pulley, as here in CA, if it's visible, they they'll see it on the smog check and they will required it removed. But, check out the ZCarGarage.com website, as Rob can help you out. He's also the shop that did my setup, among many more, and has been in mod magazines for jobs on cars he's done, not to mention his own being in the mags also. His shop and GTM (Motorsports) have done many Z's & G's FI here in CA. Also Forged Internal in Marrieta, GA is another good source to get answers. Good Luck on your decision. W-
i am in no way worried about visible inspection, all i have to pass is the computer diagnosis, as long as no lights on im good to go. no matter what my setup is. . anyone getting codes when going to 2.87 pulley and supporting mods?
It differs, but I would say that it is 9psi or less on a stock motor. I do not know what the max psi is for the TN kit because most will say the if you are building the motor the TN kit is not your best route. I think that it will max out at appx 450ish whp on a DJ, but someone like spoilsofwar may know for sure.
dude just buy my turbonetics single turbo kit, complete minus reflash, its mint. . only 3k miles on it, no shaft play no problems at all. . im just going a different route. . pm me and lets get this done. . lol
Me and my mechanic had both setups. I had the Tnetics and he had the Vortech. Both are very good daily, the only complaint he had was the noise. The Tnetics is very stock sounding under boost. We both ran our setups for about 2years as daily drivers with no problems. Just keep an eye on the pipes and check seals. Goodluck
basically i am just worried about passing inspection, i have gotten alot of good info how the kit is actually a good and reliable kit. . i am in upstate ny and can't have any check engine lights on when inspection time comes
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
