Temp gauge on FI
Old Dec 9, 2008 | 06:12 PM
niceguyyy01's Avatar
niceguyyy01
Default Temp gauge on FI
Where are you guys mounting your temp sender on your FI cars? I was reading on another thread and didnt want to hijack it to ask.... someone was asking about high water temps and another member asked if the sender was mounted in the lower hose or upper hose. I was wondering what is the best spot for the sender with the motor already in the car?
Old Dec 9, 2008 | 09:03 PM
Blackbird CPV35's Avatar
Blackbird CPV35
i think the best spot is to put it in the rear coolant pipe behind the engine if you can get in there
Old Dec 10, 2008 | 02:36 AM
D-tuned's Avatar
D-tuned
I used this to install my temp sensor in the upper radiator hose http://www.z1motorsports.com/350_g35...365&imageNum=1 Now I just have to figure out where I can mount the oil temp sensor.
Old Dec 10, 2008 | 06:01 AM
ToastZ's Avatar
ToastZ
The upper hose has coolant flowing from the engine to the radiator when the thermostat is open.
The lower hose has coolant flowing from the radiator to the engine when the thermostat is open.
The upper hose sensor placement will give a more accurate reading of the current engine coolant temperature as it flows out of the engine.
The lower hose sensor placement will give a more accurate reading of the temperature of the coolant that is flowing into the engine. Some car owners are actually more interested in the coolant temperature flowing "into" the engine vs. the coolant temperature flowing "out" of the engine. That's why you see some variation in regards to the placement of the sensor from one car to the next.
When comparing coolant temps from one car to another, its important to know where the sensor is located.
Old Dec 10, 2008 | 06:05 AM
westpak's Avatar
westpak
SFZCC
I believe the upper and lower coolant hoses do not have constant flow only when the thermostat opens, I have mine on the hard pipe running along the passenger side of the engine
Old Dec 10, 2008 | 06:12 AM
ToastZ's Avatar
ToastZ
Originally Posted by westpak
I believe the upper and lower coolant hoses do not have constant flow only when the thermostat opens,..
Good point.
Old Dec 10, 2008 | 06:14 AM
niceguyyy01
Excellent guys!!! Thanks so much. I am gonna put it in the upper hose, cause I care more about the heat in the motor.
Old Dec 10, 2008 | 06:15 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The upper has constant coolant in it...so I usually put the sensor somewhere prior to that hose, including the hardpipe that Westpak mentioned. The OEM sensor is located on the cast aluminum bridge pipe in between the two cylinder heads.
Old Dec 10, 2008 | 06:19 AM
niceguyyy01
How can the hard pipe not have constant flow when the upper hose is connected to the hard pipe? If the hose doesnt have constant flow, the pipe isnt going to either, right?
Plus the water pump is always turning, so there should be constant circulation throughout the motor and into the radiator.
Old Dec 10, 2008 | 06:20 AM
teh215's Avatar
teh215
What about oil temp sensors? Are the sandwich plates OK to use for this? If so, are there any brand that are 'better' than others?
Old Dec 10, 2008 | 06:28 AM
westpak's Avatar
westpak
SFZCC
The hardpipe has constant flow because there is a hose connected at the front of it that flows to the driver's side of the block, the upper hose connected to it and the radiator doesn't flow unless the thermostat is open. It is probably close enough to that it will probably read accurately but I am picky and wanted the sensor to always have coolant flowing past it for accurate temps, and it is pretty much dead on with the ECU readings.
Coolant doesn't flow through the radiator all the time, only when the thermostat opens up, that is how the engine is kept cool, the coolant stays in the radiator cooling down from airflow and when the thermostat opens up the cooler coolant from the radiator goes into the engine
Old Dec 10, 2008 | 06:38 AM
ToastZ's Avatar
ToastZ
Hey Sharif,
Do the standalone EMS's (FCON, Haltech) get their coolant temperature readings from the OEM sensor ?
Old Dec 10, 2008 | 06:45 AM
coachk's Avatar
coachk
Put the oil temp sensor in your oil pan or spacer if you have one.
Old Dec 10, 2008 | 06:46 AM
westpak's Avatar
westpak
SFZCC
Originally Posted by ToastZ
Hey Sharif,
Fcon does
westpak's Avatar
westpak
SFZCC
That is where i have mine, on the JWT oil pan spacer
Old Dec 10, 2008 | 06:58 AM
D-tuned's Avatar
D-tuned
I've been trying to figure out where I can mount my oil temp sensor. I'm having my APS TT installed next week. So I cant put it on the pan and there is no room by the oil pressure switch for a tee. I'm hoping once the motor is pulled we'll be able to find a place for it.
Old Dec 10, 2008 | 07:52 AM
ToastZ's Avatar
ToastZ
When my APS-TT was installed, the shop drilled & tapped a hole into the APS oil pan for the oil temp sensor. They put it on the side of the pan.
While they were drilling new holes into the pan, they also put in a heli-coil in the same place as the existing drain plug. Some APS oil pan owners have had a problem with the APS drain plug stipping if it is over tightened. Usually not a problem if you DIY oil changes and are careful.
In the pic, the sensor is located right under the oil filter.
Old Dec 10, 2008 | 08:03 AM
coachk's Avatar
coachk
+1 that's where mine is too.
Old Dec 10, 2008 | 08:04 AM
frankie945's Avatar
frankie945
If you do not have a spacer use a sandwich plate I did and it works fine.
Old Dec 10, 2008 | 08:09 AM
niceguyyy01
Again, thanks guys. I can't get to the hardpipe while the engine is in the car, so I am just gonna put it in the upper hose. I mainly want it for emergency uses anyways... not for precise readings.
bcoffee20
Nov 19, 2015 06:39 PM
SharX59
Sep 27, 2015 09:23 AM
