Vortech with 650cc injectors
I think I am going to ditch the SS box and fmu and run a utec. Will I need a walbro 255? If so I read about mods to lower the fuel presure but can't find out with what they are.
unless ure going to hit 500whp on the vortech the 650 are overkill. I would get 550cc, a walbro and also a fuel return line to run with the utec. Utecs are known for hard starts if u go too big on the injectors.
i dunno, i'm at over 90% IDC with a CJM stage 2 return, 255l, and DW 600's on a FP tune.
[RPM] [TPS] [IDC%] Wide Band
5757 23 85 11.8
5817 98 89 11.8
5837 98 87.8 11.8
5847 98 89.8 11.8
5973 98 92.7 11.8
6027 61 95.4 11.7
Although, that might be fixed by upping my base fuel pressure.
If you go with DW 800s, you'll want to get a ECU reflash along with the UTEC or dump the UTEC and go Haltech. The reflash/UTEC is probably cheaper and enough control for a SC
But if someone wants to buy my DW 600's so I can go with DW 800's, I'm all ears
5757 23 85 11.8
5817 98 89 11.8
5837 98 87.8 11.8
5847 98 89.8 11.8
5973 98 92.7 11.8
6027 61 95.4 11.7
If it's a good deal, I would go for them. 550's or 600's might be better for starting the car (I had hot start issues with 650's), but I'm not sure about the duty cycle on something like the 550's. I would just go with the 650's for being cheap and future-proof.
You are correct in the need to lower your the fuel pressure with the Walbro. Some drilling is required of the Walbro..Check search on Phunk. He has a nice write up on whats required...W/O the drilling expect to see around 80-90 psi.
As quirky as I've heard the Utec is . I would suggest keeping the SS box and flash the ECU for the 650's and get re-tuned .
350Z_Al
Oct 29, 2020 07:44 PM
