Idle relearn is not working!
Old Jan 16, 2009 | 06:32 PM
surfcity40's Avatar
surfcity40
Well then you posted a code...that is different. You know P507 means idle air control system is high. It generally means you need an idle reset.
here....
http://www.zcar.com/forums/read/5/1820398
REPLACE THE SENSOR, YOU"LL BE FINE.
sry
Old Jan 16, 2009 | 06:35 PM
athenG's Avatar
athenG
here....
He's having the same error code and yes a relearn help if the parts are working. Did you read the entire thread?
here.. He does have a code too!!!!
Originally Posted by Biochem7
Anybody else have this problem? My setup is Vortech with UTEC. I originally had my idle set to ~1,000 RPM. However, my idle has never been correct and lately its been around 1200 RPM causing DTC P0507. When I do the idle air relearn procedure, my idle will drop to ~850 RPM, but when I restart the car it goes back to 1200 RPM. Its like the ECU will not remember the relearn procedure. I have searched this forum and google and looking for any insight before I go to the dealer or buy a new Throttle body.
Thanks for any feedback.
Edit
YOU FAIL miserably!!! the link you posted is about p1121 error so your advice is inaccurate.
Old Jan 16, 2009 | 06:39 PM
surfcity40's Avatar
surfcity40
here.. He does have a code too!!!!Edit
My bad. I was a bit ticked so I overreacted. I posted two answers one correct one incorrect.
Old Jan 16, 2009 | 06:41 PM
athenG's Avatar
athenG
So where is the correct one?
Old Jan 16, 2009 | 06:52 PM
surfcity40's Avatar
surfcity40
here:
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/KwdYzWzc170&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/KwdYzWzc170&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Jan 16, 2009 | 07:02 PM
athenG's Avatar
athenG
here:
/\ That wasted my time!!! That video is all about just cleaning the TB which we already advised the the OP. The OP already cleaned his MAF sensor and TB and also did the relearn but still get the P507 error. Now where is the correct answer so the OP can say bye bye to the P0507 code.
Old Jan 17, 2009 | 07:38 AM
Netacoma2003's Avatar
Netacoma2003
any more suggestions?
The Nissan dealership "consult" module did not work on my '04.5 model year but I've read where they can adjust idle on other years.
Have you tried Osiris? They had no trouble adjusting my idle to where I wanted it and they scaled my 600cc injectors / varied throttle body position as to practically eliminate the hot start issues I was having with my Techno flash / UTEC setup.
Old Oct 14, 2010 | 01:22 PM
maybeZ?'s Avatar
maybeZ?
no post of the final outcome? I ask because I just took mine in the shop for the same problem. I will advise. thx-
Old Oct 17, 2010 | 04:56 AM
james12345pt's Avatar
james12345pt
Default utec and throttlebody reset
I had the same problem with my Vortech/UTEC setup after I sucked up some rain driving in an afternoon thunderstorm. I tried everything to reset the throttle body and remove the code but nothing worked. I was finally able to reset the car by disconnecting the Utec and performing the reset procedure. I now have an Haltech and can reset the throttle body with no problems. Also, If you are planning on staying with this setup; I would suggest getting an Osiris flash. It will help with cold starts, and smooth out the transfer of control from the stock ECU and the UTEC. Good luck.
PS: My Idle was set at 1000rpms (adjusted by cipher) without any codes.
Old Mar 19, 2023 | 08:13 AM
cees1120's Avatar
cees1120
If you go to the dealer the first thing they will tell you is buy a TB. I went to Nissan and when I mentioned my P507 error they already made up their mind that I need a new TB. Of course I didn't listen and tried to do the relearn myself and that fixed my problem. If the problem persist then maybe you really need a new TB. I also changed my MAF and that help me stabilize my idle..
What do you mean by TB. I’m having the relearn problem too.
Old Mar 19, 2023 | 08:16 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Throttle Body
Old Mar 19, 2023 | 10:26 AM
cees1120's Avatar
cees1120
Originally Posted by MicVelo
Throttle Body
So I replaced the throttle bodies and cleaned the mass airflow sensors. My mechanic replaced the the compressor and the spark plus and then it started doing it. Mechanics and Nissan cant seem to do the relearn. No leaks are found head gaskets were also replaced. What else do you think it might be mate?
liqalu04
Jan 2, 2022 12:58 PM
_bit
Oct 2, 2015 07:49 AM
