Turbo LS2??
Old Jan 13, 2009 | 02:34 PM
ttg35fort's Avatar
ttg35fort
Professional
I can't wait to see this thing complete!
I understand the benefits of a single large turbo, but if a single large turbo will not fit, how about going with two smaller turbos? Perhaps they will be easier to fit.
Old Jan 13, 2009 | 03:16 PM
SnyperZ's Avatar
SnyperZ
Originally Posted by Hal@IP
Pics of progress? What mounts are you using - premade or are fabbing a set?
Ahh, must of missed this one. Im using the Hinson mounting kit with the CF driveshaft option.(same one NOAH used)....I will post pics of progess when I make some..right now im in the collection of parts stage. Hinson quoted me about a month out for the oil pan and mounting parts..and I wont know if im going FI until the motors in the car and I see what kind of room im got.
Originally Posted by bryan@Z1
Magnuson 112H or if the OP is really feeling froggy a Magnuson 122 will give plenty of tire melting torque.
Im very partial to turbos and the big lag...the supercharger will have too much down low for what im looking for.
Old Jan 13, 2009 | 06:15 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
Originally Posted by SnyperZ
Well, its gettin close to install time. I have the LS2 drivetrain, just waiting on swap parts...once the motors in im going to see if we can reuse the stock manifolds facing forward and if we can we will be throwin in a pte78 or pte88 turbo depending again, on size...if neither can fit then ill just move this thread over to the nitrous thread.
We built a Firehawk with a 6.0 iron block this past season, and made a single turbo kit with it using the truck manifolds facing forward. We used a Precision 78gts and lets just say the car is SICK!!! at 17.5 psi it goes 9.25@148 all day long!!
I forsee you having a tight fit up front if you place it in front of the motor and the pte88 is likely to surge, I'd recommend the 78 for your setup, you'll make plenty of power and it will spool instantly on the LS motor.
Also, if you plan on making some good boost I suggest using L19 head studs and cometic phuzion (o-ring) head gaskets. These motors at bigger boost have a tendency to lift the heads a tick. We've started using L19's and those head gaskets and problem solved.
We're Precision Turbos 4th largest reseller in the US. Let me know if we can help you with your turbo selection.
If you need any help just let me know. Here are a couple pics of the one we built.
This should keep you motivated take a listen
View Video on FQuick
Good luck, sounds like you should have a wicked setup!
Chris
Old Jan 13, 2009 | 08:28 PM
SnyperZ's Avatar
SnyperZ
How much smaller in physical size is the 78 from the 88?
Old Jan 13, 2009 | 08:41 PM
Chris@SP's Avatar
Chris@SP
Sound Performance
you can stuff an 88 in the package of the 78gts, so they would be the same size.
Old Jan 13, 2009 | 08:47 PM
SnyperZ's Avatar
SnyperZ
alright. looking at the trans am you did..thats almost exactly how I want to do my setup. I bought a pair of truck manifolds and as soon as the engine is in the car im going to see what kinda room we are working with.I was thinking about doing the turbo up front like that,if theres enough room between the engine/rad.
Old Jan 14, 2009 | 03:30 AM
*Boose*'s Avatar
*Boose*
Ehh, id rather do it myself. And ill make room if I need to. =) I wont be running A/C in the car...the downpipe will be in its place. Theres going to be more room in there with the LS2 then there was with the VQ.
Custom rear turbo setup should work right? I've seen GTO's and Z's with them. Engine bay space wouldn't be an issue especially if you're saying there is more room with the ls2.
Old Jan 14, 2009 | 04:57 AM
SnyperZ's Avatar
SnyperZ
ehh, Im not a fan of the rear turbo setups...im going to do everything I can to get it to fit up front...pretty much just like the setup on the TA...or maybe opposite to where the powerlab turbo sits.
Old Jan 14, 2009 | 05:23 AM
SnyperZ's Avatar
SnyperZ
does the alternator NEED to be relocated over to that side for the kit to work?
Old Jan 14, 2009 | 05:33 AM
Chris@SP's Avatar
Chris@SP
Sound Performance
You will not have A/C using the truck manifolds unless you move it up high. We also made a custom alternator relocation kit for it since it has to be moved up as well. The problem you run into when running the truck manifolds forward.
Depending on the Hinson, or whatever sub assembly you use, you may be limited to a 3 or 3.5" downpipe since it's very tight between the frame and the block, but since it's in a Z I don't know if that will be a factor, just something to watch for.
Can't wait to see you progress!
Chris
Old Jan 14, 2009 | 05:58 AM
gothchick's Avatar
gothchick
Picz of OP'z setup? I can haz?
Old Jan 14, 2009 | 06:13 AM
SnyperZ's Avatar
SnyperZ
Chris
yeah I wont be using A/C...the downpipe will be there instead. =) So the alternator down low wont go huh? hmmm I like where you put the alternator but I dont think it will fit under the tower brace..how high above the manifold does the alternator sit?
Old Jan 15, 2009 | 07:17 PM
SnyperZ's Avatar
SnyperZ
well..looks like a front mount turbo might not be happening..I dont think there will be anywhere for a decent size turbo to fit up there..
Old Jan 22, 2009 | 02:16 PM
SnyperZ's Avatar
SnyperZ
Hey Hal, how strong are these diffs?
Old Jan 22, 2009 | 02:46 PM
frankie945's Avatar
frankie945
Just spray it, with a 200 wet shot.
Old Jan 22, 2009 | 04:03 PM
SnyperZ's Avatar
SnyperZ
..thats the plan now..I just wonder if these diffs will hold up to anything.
Old Jan 22, 2009 | 04:34 PM
frankie945's Avatar
frankie945
Good Question, That would be a lot of TQ.
Old Jan 22, 2009 | 07:41 PM
  #38
Dynosty's Avatar
Dynosty
Vendor - Former Vendor
We ran a stock never-opened 350Z dif all season, and it remains in the car in one piece. Keep in mind we also ran an auto which is easier on them, and kept a built dif in the trailer just in case...
Old Jan 22, 2009 | 09:07 PM
  #39
SnyperZ's Avatar
SnyperZ
in your green car?
Old Jan 22, 2009 | 09:11 PM
  #40
Dynosty's Avatar
Dynosty
Correct.
