Are Nismo R tune cams worth it for FI?
Old Jan 16, 2009 | 06:41 PM
Mr_pharmD's Avatar
Mr_pharmD
Default Are Nismo R tune cams worth it for FI?
I'm debating on getting some NISMO R-Tune Camshafts for my non rev motor but not sure if it's worth it. The most I see on a NA with these cams are 10whp but are the gains more impressive with a built motor with vortech?
Old Jan 16, 2009 | 07:36 PM
wannabuy350z's Avatar
wannabuy350z
it has a slightly higher lift than stock 262* i believe the nismo's,
but depending on your power band is what cams you should get to help in the weaker areas
Old Jan 16, 2009 | 07:49 PM
Mr_pharmD's Avatar
Mr_pharmD
I was thinking if I add 1-2 more timing + meth kit with stock cams I should be able to gain the same amount of whp or even more compared to the nismo cams... am I wrong?
Old Jan 16, 2009 | 09:51 PM
laswyguy's Avatar
laswyguy
sent u a pm, I'm selling some cams brand new if interested.
Old Jan 17, 2009 | 03:50 PM
ttg35fort's Avatar
ttg35fort
Professional
Check out JWT, BC and GTM cams. They are all good. After researching this, I chose JWT C2 cams. That was my choice, but your's may be different.
Old Jan 17, 2009 | 04:34 PM
bbs350z's Avatar
bbs350z
no. get the above listed before you go for nismo
Old Jan 17, 2009 | 04:37 PM
GTM's Avatar
GTM
Vendor - Former Vendor
I like the GTM Stage 3's on my G, great for top end power. Which is what the DE's lack. Your idle will be loopey though ( I like it :P)
-George
GT Motorsports
Old Jan 17, 2009 | 05:05 PM
Mr_pharmD's Avatar
Mr_pharmD
i might get a great deal on some new nismo r cams that's why I asked and I dont want to spend anymore $$$ on head stuff. Also not too crazy about the loopy feeling at idle.
Anyone know on average how much HP u would gain by each degree of added timing?
Old Jan 17, 2009 | 05:37 PM
Mr_pharmD's Avatar
Mr_pharmD
Well, I just bought the nismo R cams so I'm hoping I made a good decision. I didnt want something too aggressive but still had some kick in the mid range.
Anyone know if the VPRO can turn off SES in case the cams throw a random misfire?
Old Jan 17, 2009 | 05:50 PM
turismo's Avatar
turismo
No
Old Jan 17, 2009 | 06:02 PM
rcdash's Avatar
rcdash
Why would cams cause a random misfire?
George, can't wait to see a write up on your car!
Old Jan 17, 2009 | 06:03 PM
rcdash's Avatar
rcdash
That depends on many factors, including how far away you are from minimum best timing. If you're already there, then 0.
Old Jan 18, 2009 | 12:48 AM
GTM's Avatar
GTM
It won't be for a while, I want to wait until everything is 100% ( still waiting on the seats/headlights/interior work)
You can always give me a call for a sneak peak
Take car Raj!
OP: Let us know how you like those Nismo's curious to see how they compare to our stage 2 cams (mild and not loopey)
-George
GT Motorsports
Old Jan 18, 2009 | 04:47 AM
booger's Avatar
booger
I have the Nismo cams...N/A you can really feel them kick in at 3000rpm . They seem to work real well with the Vortech , but as far as turbo's with them . I dont know
Old Jan 18, 2009 | 09:36 AM
Mr_pharmD's Avatar
Mr_pharmD
Hey Booger, did your nismo cams throw a ses light or did u have your ecu flashed for that? Also what did u set your idle to? Thanks.
Old Jan 18, 2009 | 01:54 PM
wannabuy350z
nismo's will not cause any cels.
Old Jan 18, 2009 | 05:43 PM
booger's Avatar
booger
No CEL...I had my idle set at 775 rpm with the Haltech it idles perfect . I could put the idle back to stock if I wanted to
Old Jan 18, 2009 | 05:58 PM
Nexx's Avatar
Nexx
-George
GT Motorsports
how loopy george? my car right now is set to idle around 1200rpm.
Old Jan 18, 2009 | 06:44 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/ZvdfwIpvpY8&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZvdfwIpvpY8&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Here is the GTM stage 3 @ idel 950 rpm's
SAM
Old Jan 19, 2009 | 06:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
-George
GT Motorsports
Im so sick of seeing people ask about a certain turbo kit, or fuel system or in this case cams, only to see you chime in with your worthless sales banter.
The guy is asking about a mild cam, and you basically recommend a freaking stage 3 cam He also stated he wanted good midrange, and your stage 3 cam is a top end cam-did you even read the thread?
Op-if you wanted to keep a stock like powerband just beefed up the Nismo would work for you. If those are your goals I would choose the Nismo or the JWT S1's.
