the next CJM intake
Old Jan 20, 2009 | 04:57 PM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by Kirk Lazarus
Wow, very nice. Is this "balanced" to the point that the cylinders near the back of the manifold won't be starving for air?
It is very large and open on the inside and every cylinder has an equal shot at pulling air from the plenum. I believe that we will find that we have enough displacement to overcome any potential static airflow balance. It certainly couldn't be any worse then coming in from the rear!
Old Jan 20, 2009 | 05:00 PM
phunk's Avatar
phunk
CJ Motorsports
Originally Posted by TurboTim
Can you make me one out of titanium
Probably! Anything the cnc can cut thru!
Thanks for the g hood info
Old Jan 20, 2009 | 05:13 PM
XKR's Avatar
XKR
OMG I MUST HAVE TITANIUM CHARLES
Old Jan 20, 2009 | 05:17 PM
XKR's Avatar
XKR
Originally Posted by Z1 Performance
will it make more power than my current spacer?
is it going to make 50 whp untuned? why do I have to retune for it?
will it take 75 psi of boost and a 400 bazillion shot of NOS as well as Methanol (together)?
what else do I need to install on my car? My current mods are Zaino, tint and test pipes....
how much does it weigh?
why is it so expensive? I think if you can make it for $250, you'll sell alot more and make alot more money
Now that those are out of the way
Adam.....I bet I can come up with some more
Old Jan 20, 2009 | 05:22 PM
phunk's Avatar
phunk
CJ Motorsports
Definitely looks badass Charles - I know you've got HKS injectors (IIRC?) on your car - any issues with the usual suspects as far as rails/injector combos? (that last question was legit lolol)
I think I understand what Cheston is asking, since I know where he works Is it a channeled air guide on the underside of the cover (sorta like a reversed diffuser) or a flat plane? I think I know the answer, but that might be what he was going for
No issues with the rails with my tall hks 1000s. There is nothing fancy on the underside of the plenum cap.
No strut bar question? I think the cusco will fit with spacers
Old Jan 20, 2009 | 05:27 PM
XKR's Avatar
XKR
That was a question I was going to ask also about the injectors...because i am using the HKS also.
About the strut bar....OK..I will ask...Will ARC strut bar fit
Old Jan 20, 2009 | 05:40 PM
turismo's Avatar
turismo
Looks sick. Can't wait for the numbers
Old Jan 20, 2009 | 05:48 PM
Quamen's Avatar
Quamen
Charles-
that would look bada$$ through here:
Old Jan 20, 2009 | 05:50 PM
Crom's Avatar
Crom
Originally Posted by turismo
Looks sick.
+1 ...very refreshing to see new cool stuff.....
Old Jan 20, 2009 | 05:58 PM
phunk's Avatar
phunk
CJ Motorsports
Any bar that will fit will have to be spaced up, and be able to fit inbetween the plenum and hood... The thinner the bar the better the chances... Cusco is insanely thin and wide . I haven't seen the arc but I'm willing to bet there aren't many bars like the cusco, which still may not fit I'll check tommorrow.
Old Jan 20, 2009 | 06:10 PM
350z-900whp's Avatar
350z-900whp
would it clear GTM shored+fans 14inch with 53m radiator (koyo) since its elbow throttle body style ?
on my new build am going with GTM TT kit with twin35's and 272cams gtm shooting for mid to low 600s how would u say u plenum would work with my setup
Old Jan 20, 2009 | 06:14 PM
JAM3Z's Avatar
JAM3Z
Phenom
Originally Posted by XKR
This was designed for cars with very high HP with high rpm range
This must mean you've already put a deposit down one one
At any rate, this thing looks like it means business.
Old Jan 20, 2009 | 06:36 PM
thom000001's Avatar
thom000001
Charles,
First off looks great.
second, if you want to make sure it'll clear on the G, we'll probably have my plenum off soon (damn you chris )
tom
Old Jan 20, 2009 | 07:18 PM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
If I put this on my car, would I make 1034 RWHP instead of 1033?? Does it come in Dark Cherry or Bamboo?
Looks Great CJ!!
Seriously I think that one of the keys to our car making all that HP and revving so high is the CJM intake manifold.
Old Jan 21, 2009 | 12:16 AM
phunk's Avatar
phunk
CJ Motorsports
I hope you're right larry!
If we do any more wood ones we thought we should just leave on the treebark and everything... Dissipates heat better. We cut one out of chocolate for brandons wife's v-day gift.
Old Jan 21, 2009 | 05:14 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
lolol - I totally overlooked the strut brace question!
Chocolate intake manifold
Old Jan 21, 2009 | 05:20 AM
plumpzz's Avatar
plumpzz
You forget the most important question, can I retain my stock strut bar?!?!
edit: damn someone beat me to it!
Old Jan 21, 2009 | 07:00 AM
  #38
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
U Da Man Charles.....I must have mine in Billet What you said about the Hood...does that apply to the G's also???
BTW...Cosworth for sale
Me too! MUST HAVE IT IN BILLET!!!
The G has more clearance.
Tim
HOORAY!!!
Old Jan 21, 2009 | 09:37 AM
  #39
Chebosto's Avatar
Chebosto
excited to see preliminary / prototype results...
(wood?? did u check for termites? jk)
Old Jan 21, 2009 | 09:48 AM
  #40
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Looks Great CJ!!
Do you guys think you will switch to this new version with the throttle body up front? As impressive as the one currently on your shop car is, I'm confident that this straight path through the front has gotta flow better and will yield more power versus the conventional angled rear entry on your prototype and all the other VQ plenums out there.
