How big can you go??
Old Jan 21, 2009 | 03:27 PM
satcomguy85's Avatar
satcomguy85
Default How big can you go??
Intercooler that is
What's the biggest intercooler someone has put in a 06 350z without doing some serious mods?
P.S. Sorry if this is a repost. I DID search and found nothing.
Old Jan 21, 2009 | 03:32 PM
Nexx's Avatar
Nexx
how many licks does it take to get to the center of a tootsie pop?
Old Jan 21, 2009 | 03:57 PM
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
The Sound Performance TT kit comes with a huge 5" thick core. I think it is probably the biggest currently being offered for the Z.
Old Jan 21, 2009 | 04:04 PM
thom000001's Avatar
thom000001
I believe it is Sound Performance as well, you do have to remove bumper support
5inDx12.75inHx27.8inL
Old Jan 21, 2009 | 04:06 PM
350z2go's Avatar
350z2go
nice, that thing is hugeeee
Old Jan 21, 2009 | 04:12 PM
thom000001's Avatar
thom000001
Oh SP's is on an 03...don't think there's any differences up there though.
Tom
Old Jan 21, 2009 | 04:14 PM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Yeah, I hear that alot
Old Jan 21, 2009 | 04:22 PM
thom000001's Avatar
thom000001
Ba-Dum-CHI
Old Jan 21, 2009 | 04:33 PM
thom000001's Avatar
thom000001
HA!!!!!
That core is rated to 1775HP lol.......turn up the boost larry
Old Jan 21, 2009 | 05:42 PM
SoundPerformance
Sound Performance
Originally Posted by thom000001
HA!!!!!
I will!! We just took out our weak *** 14 psi WG springs and now we have 21 psi base springs in it. Should be good for 42 -45 psi. Oh and then of course there is a little old nitrous kit going on it!!
Old Jan 21, 2009 | 09:05 PM
thawk408's Avatar
thawk408
Your crazy. Im semi-crazy, but you for sure take the cake.
Old Jan 22, 2009 | 04:36 AM
Cass007's Avatar
Cass007
The APS Extreme kit comes with a 5" core, but it doesn't look as huge as SP's intercooler. To fit the Z you have to mill out a portion of the front crash support bar, but you still use it.
Old Jan 22, 2009 | 05:05 AM
Jay'Z's Avatar
Jay'Z
You can go as big as you can afford........
Old Jan 22, 2009 | 05:14 AM
SoundPerformance
Sound Performance
IF the power is still rising at 45 and backpressure to manifold pressure ratios are still in check.... then guess what? Yep Let's try 50 psi or more. I will run the turbos to the point where they are no longer efficient. I suspect it will be in the mid 40s though. Boost itself never hurts anything although the HP created by it can if the motor is not built to withstand it.
Old Jan 22, 2009 | 06:40 AM
thom000001's Avatar
thom000001
APS extreme is a vertical flow correct? Which would be more efficient at dropping temps in our apps a vertical or a horizontal flow....Larry??? I have no clue.
Just curiouso
tom
Old Jan 22, 2009 | 08:52 AM
thawk408's Avatar
thawk408
You think it will make that much boost or be efficient that high with the .63 hotsides?
Old Jan 22, 2009 | 09:00 AM
danisr1's Avatar
danisr1
Sleeps in 350Z
APS Extreme on my car for comparison
Old Jan 22, 2009 | 09:05 AM
thom000001's Avatar
thom000001
They've got those billet wheels which flow very different than standard wheels.....kinda in a test and see situation I guess.
tom
Old Jan 22, 2009 | 09:49 AM
SoundPerformance
Sound Performance
Im thinking of putting a tick larger turbine wheels in it and bumping up the a/r. The way she sits with 10 more psi I think we could hit close to 170 in the 1/4. If we want to run 175-180+ trap speeds. though...
While I have the motor out I may make some changes.
Old Jan 22, 2009 | 09:58 AM
cwylie's Avatar
cwylie
Trap speeds like this? ;-)
http://www.youtube.com/watch?v=QbpRpj74wAo
