Dyno Comparison
Old Feb 2, 2009 | 10:37 AM
nomyth46's Avatar
nomyth46
Default Dyno Comparison
i searched this but couldn't find anything........i know all dyno's read differently and some general read higher than others.......but which ones read the highest and which ones read the lowest...like for example does a mustang read higher than a dyno dynamics and lower than a dyno jet?.............i'm just curious how they all match up
Old Feb 2, 2009 | 11:01 AM
thom000001's Avatar
thom000001
Warning, you are about to get flamed baaaaaaaaaaaad
but.
Generally dyno Jets are the standard "accepted" by most
dynapack, DD, and mustang generally read lower. There are way too many variables though.
People will tell you dynapack, dd, and mustang you just configure and get whatever numbers you want. Well you can do the same thing with dynojets (just change the weather station settings).
Here's how I look at it. The dyno is a tool. I rather measure the power changes I see based on changes I make in the setup. The ultimate number doesn't mean that much.
tom
Old Feb 2, 2009 | 11:08 AM
Car vs. Driver's Avatar
Car vs. Driver
There are only these factors that are important when measuring power ...
1. Baseline numbers vs numbers after mods (on the same dyno only - if you change dyno's it's a moot measurement).
2. ET and trap in the 1/4. That's really the best way to measure how powerful your car is.
Beyond that, it's a dick waving contest. But I'm happy to display my numbers in my sig anyway.
Old Feb 2, 2009 | 11:13 AM
Car vs. Driver
Read this ... ignore the flames and you'll find some very useful technical information about load based and inertia based dynometers.
https://my350z.com/forum/forced-indu...t=dynodynamics
And do a better search, there's about 128732098713248979823 threads on this topic already.
Old Feb 2, 2009 | 11:23 AM
nomyth46's Avatar
nomyth46
yeah it's cool........i was really just wondering because i did know how dynapack and mustang read compared to others.........thankyou for the responses
Old Feb 2, 2009 | 11:31 AM
ttg35fort's Avatar
ttg35fort
Professional
As far as I can tell, everyone has a different opinion. Not only that, you can put a car on a dyno one day and get one measurement, then put the exact same car on the exact same dyno the next day and get a different measurement. The only way to get a true comparison is to put the dynos side by side in a controlled temperature and humidity environment and with a controlled power source, which I have not seen done.
Search Google (e.g. dyno A vs dyno B). I found quite a few threads discussing differences in dynos, as well as other very informative information. Once you read enough threads, you'll probably form your own opinion. I remember a thread in one of the Corvette forums that gave a very detailed break down of the differences between the different dynos and expected results. I don't remember exactly in which forum it was, but perhaps you'll come accross it in your search.
Old Feb 2, 2009 | 11:47 AM
Jeremy@Altered's Avatar
Jeremy@Altered
There is a reason that they all have Dynojet corrections. Dynojet is and will be the industry standard.
IBTL !!
Old Feb 2, 2009 | 12:59 PM
Cass007's Avatar
Cass007
Mustang = I wish my tuner had a real dyno
DJ = Wow look at all that power and that nice curve ( smoothing set on 5)
DD = What do you mean that's all its got?!?!?!
It seems that based on how the settings on any individual dyno are set up (weather, elevation, smoothing, gear selection, traction, fans) you can vary greatly in your horsepower #, IMHO.
Agreed that DJ is considered the industry standard though .
Old Feb 2, 2009 | 01:09 PM
str8dum1's Avatar
str8dum1
yes but the only way to properly tune is by a load based dyno, like a DD.
Old Feb 2, 2009 | 01:22 PM
XKR's Avatar
XKR
So true
Old Feb 2, 2009 | 01:49 PM
IslandZavage's Avatar
IslandZavage
IBTL.. waiting on you know who to respond....wait for it..
Old Feb 2, 2009 | 02:04 PM
XKR's Avatar
XKR
You mean Dr Doug He is in charge if the Stillen SC section....not the dyno section
Old Feb 2, 2009 | 03:06 PM
nomyth46's Avatar
nomyth46
you can get a DynoJet with load control..............they have one at national speed
Old Feb 2, 2009 | 06:02 PM
booger's Avatar
booger
Seems every one that dyno's and tunes on a load based dyno.....thinks that , that dyno type is the lowest reading dyno .
But what seems to work real well is a whp calculator . Using your cars real wt. and trap speed
Old Feb 2, 2009 | 06:34 PM
nomyth46's Avatar
nomyth46
i agree, last time i played with one of those it was like within 15whp
Old Feb 2, 2009 | 06:46 PM
thom000001's Avatar
thom000001
Yup, assuming traction of course......I will use SP's as a perfect example.....
Car weighs 3428 (as per pic on website) with chris behind the wheel.
Car trapped 158mph
Car dyno'd at 1033rwhp.
ET calculator show that 3428lbs and 158mph = 1055rwhp
not too bad on accuracy
tom
Old Feb 2, 2009 | 07:18 PM
Car vs. Driver
^--- on what dyno?
Old Feb 2, 2009 | 07:20 PM
thom000001's Avatar
thom000001
Mustang Dyno ("calibrated to read like dynojet")
tom
Originally Posted by Car vs. Driver
^--- on what dyno?
Old Feb 2, 2009 | 09:41 PM
phunk's Avatar
phunk
CJ Motorsports
Thom just FYI there is no way to change dynojet readings. You can only select from sae, std, din, and one or two more standards for environmental corrections and that is all. If you wanted to try really hard to falsify readings you would need to put the weather station in an oven... But evev then it says the temp right on the graph unless they turn it off... Not worth the work
Old Feb 2, 2009 | 10:18 PM
go-fast's Avatar
go-fast
what if dyno's where calibrated and software was based off of a yamaha v-max?
