Skid plate or no?
Old Feb 10, 2009 | 08:08 AM
BoostedProbe's Avatar
BoostedProbe
Originally Posted by thom000001
well turn the camera upside down, then just flip the photo in paint or photoshop lol
t
Tried that too, still too dark and you can't see sh...t. Smartass.
Old Feb 10, 2009 | 08:19 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Originally Posted by Car vs. Driver
+1 put vents in the plate if you keep it ...
Also, to the comment previous to this, there's no need for a blanket since there should be sufficient air flow under the car to prevent heat soak on the turbo.
That isn't what a turbo blanket is for.
Turbo blankets serve to keep heat in the turbine section which increases the overall efficiency which means most power and lower exhaust gas flow rates which means lower engine RPMs.
It may not make a huge difference but every little bit counts?
Old Feb 10, 2009 | 08:21 AM
Car vs. Driver's Avatar
Car vs. Driver
Turn off the flash ... use shop lights under the car
Either way, great work dude! Want to fly down here and fab up my roll cage? lol
Old Feb 10, 2009 | 08:22 AM
Car vs. Driver
Really? More heat = less dense air = less efficient ... how does this work? Seriously, I've never heard that before so I'm curious.
Old Feb 10, 2009 | 08:32 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
More heat means more energy. The working medium is the exhaust gases flowing through the turbine.
In an adiabatic turbine, Power=Mass flow*(basically change in energy). Adiabatic means basically that all of the energy in the working fluid is going into creating power.
The change in energy is the difference between the energy of the exhaust gases entering the turbine and the energy of the gases leaving the turbine. This is one reason wrapping exhaust manifolds is a good idea in addition to keeping under hood temperatures down.
But if the turbine is getting hot and air is blowing across the turbine, then the turbine is no longer adiabatic. This represents a loss. So keep the heat in the turbine. Don't give it up to the atmosphere, that is the whole point of a turbo anyway.
Granted, I don't know how much it would help but being as the turbo is under the car and air is blowing directly over the turbine, I would image a significant amount of heat is being removed.
Old Feb 10, 2009 | 08:34 AM
BoostedProbe
I don't really know what the turbo blanket is for, but I would assume that it is an insulator for those running under hood turbo's. For guys with TN kits, to keep the heat from the engine bay. As far as exhaust gas heat goes, as it cools it expands, and therefore travels faster through the turbine. That's at least my impression of the whole thing. Maybe I'm wrong.
Either way I'm am not putting one on.
Old Feb 10, 2009 | 08:37 AM
Ahsmo's Avatar
Ahsmo
Imakecopies
Okay, I am just suggesting it for reducing lag. It might help, it might not is all I am saying.
Old Feb 10, 2009 | 08:43 AM
Car vs. Driver
I did some googlin' and the blankets are intended to protect the engine bay from heat, not to keep heat in the turbo for efficiency. I still believe that's counter productive in a turbo application to trap heat in the turbo - you'd want it as cool as possible on the compressor side for lowest IAT. But that's just my .02
Old Feb 10, 2009 | 10:01 AM
XKR's Avatar
XKR
I agree ...Turbo Blanket, Vents, and filter on the turbo for sure.
Old Feb 10, 2009 | 12:27 PM
zads's Avatar
zads
Originally Posted by BoostedProbe
No vibrating, turbo is isolated through flex pipe from the engine. There won't be any rattling, everything past the flex pipe is soilid and cannot be pushed over to touch any part of the car. I tried really hard. Turbo down pipe and beyond is on stock hangers so there won't be any problems there. This should give you a better idea:
Ok, sounds reasonable.
I assume you haven't run it yet?
Just make sure you loctite the bolts to keep vibration from rattling the solid exhaust mounts loose.
Bottom line is, you're better off running the skid plate for safetys sake,
as long as it doesn't cause any interference/clearance issues.
Also you might want to avoid the vertical horseshoe/siphon loop between the turbo oil drain and the scavenge pump.
You may get turbo oil drainage/scavenge issues, and blue smoke/oil everywhere.
Old Feb 10, 2009 | 01:17 PM
BoostedProbe
The car has been runing, only idling I guess since it's on jacks. I though there would be a bit of vibration, but there really wasn't any. The scavenge system works great actually, it's been tested really well. I put a clear hose (temporary for test purposes) from the turbo to the scavenge pump just to see if there is any oil left behind. It works great, it sucks all the oil up without any problem whatsoever. I will put a small timer, so the scavenge pump runs for 10 seconds or so after the car has been turned off. This will completly eliminate any problems at startup, as the turbo will be drained of all the oil. So, no worries there.
Old Feb 10, 2009 | 08:46 PM
R350nate's Avatar
R350nate
you want cold air going into the engine and hot air coming out to spin the turbo more consistantly. hot air takes up more space meaning more volume of exhaust from the same combustion. isnt that right? Therefore either way the turbo blanket would be beneficial because it could keep heat out of the engine bay while maintaining hotter exhaust.
Old Feb 11, 2009 | 04:53 AM
10-E-C-350Z's Avatar
10-E-C-350Z
sub'd. Excellent work here.
Old Feb 11, 2009 | 07:11 AM
jdf28045's Avatar
jdf28045
Default Sheilding
Have you looked into puting some aluminum shilding around your drive shaft. That amount of heat on your drive shaft cant be good!!
Old Feb 11, 2009 | 08:13 AM
350Z400rwhp's Avatar
350Z400rwhp
This is a good point though I'm not sure how hot before the carbon fiber will start breaking down. I would do the turbo blanket at least for this reason only.
Old Feb 11, 2009 | 12:19 PM
SoldzMyZ's Avatar
SoldzMyZ
What turbo do you have?
Old Feb 11, 2009 | 12:43 PM
BoostedProbe
All the build info. is here.
https://my350z.com/forum/forced-indu...brication.html
BEBO'S ZEE
Jun 7, 2016 07:48 AM
kyin
Oct 15, 2015 05:54 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
