car went into limp mode 4 cel codes help!!!
Old Feb 14, 2009 | 01:34 PM
drumminguy81's Avatar
drumminguy81
Default car went into limp mode 4 cel codes help!!!
ok so first off i have a 2003 with vortech, 5/16 plenum spacer, header back exhaust, ssbox. i have been having problems with the idle so i decided to take my plenum off and retorque it back on to make sure i have no vaccum leaks, i also decided to swap my 3.12 pulley out for a 2.87 that i had. i started the car up and it idled fine for about 10 min in my driveway so i decided to take it around the block to see how it ran. i made it half way around, never really got into boost at all, never got out of 2nd gear, and all of a sudden while shifting from 1st to 2nd at 3500 rpm the tach spiked to redline then dropped off i lost all vaccum pressure car went into limp mode and idle was extremely rough sounded like a harley. the 4 cel codes are p1121, p1122 which are electronic throttle control actuators, and p1614, p1615 which said nats malfunction. im not really sure what any of these mean. after towing my car home i reset the codes and unplugged the throttle body and maf and replugged them in to make sure i had good connections then started it up and it seems to idle fine again.. does anyone have any ideas what may have cause this? hopefully i have not done any damage to my car.. please any input would be great.. thanks-
Old Feb 14, 2009 | 01:48 PM
thom000001's Avatar
thom000001
did tach just move, or did engine rev to redline then die off?
tom
Old Feb 14, 2009 | 01:49 PM
drumminguy81
engine revved all the way up then down.
Old Feb 14, 2009 | 02:10 PM
thom000001's Avatar
thom000001
hmm, I was thinking the tps's got out of sync, but I thought it would just shut down didn't think it would rev.....lemme think
I'm still thinking vacuum leak somewhere too in the back of my mind
t
Old Feb 14, 2009 | 02:17 PM
Spork's Avatar
Spork
NATS malfunction is referring to the key... or more specifically the chip in the key.
Old Feb 14, 2009 | 02:39 PM
drumminguy81
i did read about the nats being a key but it still starts fine with the key so im not sure how that could have been effected
Old Feb 14, 2009 | 02:40 PM
drumminguy81
t
if it is tps what can i do about that?
Old Feb 14, 2009 | 02:43 PM
Spork's Avatar
Spork
Happened with me a while back. The code never showed up after I got a new key and reprogrammed both of them.
Have you tried disconnecting the battery for 30 mins?
Old Feb 14, 2009 | 02:54 PM
drumminguy81
no not yet, i have done all of the throttle position, idle volume reset though.. and cleared all of the codes from the ecu
Old Feb 14, 2009 | 02:56 PM
drumminguy81
i am also getting terrible belt squeel now it wasnt slipping at all before it shut down but now it wont stop slipping the belt seems tight enough i will try to tighten it a little more as soon as i can get my car jacked up..
Old Feb 14, 2009 | 03:37 PM
drumminguy81
belt slip fixed. anyone have any ideas why my car shut down? is it possible that because i put the smaller pulley on and drove it before i did the throttle relearn it caused the tb to freak out or something like that?
Old Feb 16, 2009 | 05:47 AM
drumminguy81
bump
Old Feb 21, 2009 | 04:22 PM
tylerxfire's Avatar
tylerxfire
Old Feb 21, 2009 | 04:58 PM
drumminguy81
i ended up resetting everything. put a new throttle body on that i had, put the 3.12 pully back on and everything seems to be back to normal.. go figure.. not sure what happened. but at least it is running now.. the weird thing is the idle is still jumping between 750 and 1000 pulsing but if i turn the ac on it stops and idles at 950 where it should and idles very smooth..
Old Feb 21, 2009 | 05:11 PM
tylerxfire's Avatar
tylerxfire
cool
etkms
Jun 19, 2022 06:30 PM
aarrgghh
May 1, 2022 11:04 AM
350Z Project X
Oct 17, 2015 05:16 PM
Bigsyke
Sep 11, 2015 06:19 PM
Darkspy
Sep 7, 2015 09:09 PM
