Vortech Rattle
Old Feb 19, 2009 | 07:36 PM
y0shi's Avatar
y0shi
Default Vortech Rattle
Below is a video of my car with the vortech tuner kit installed. The rattle is what concerns me. The rattle is coming form the blower itself. I know it's supposed to rattle a bit, but i think this might be too much. Thoughts?
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Mq-7yj7_HUU&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Mq-7yj7_HUU&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Feb 19, 2009 | 07:53 PM
phunk's Avatar
phunk
CJ Motorsports
thats a bit more than normal but the lower the RPM the worse it gets... is your AC on or anything? what is your idle RPM?
have the dealer raise the idle and it will sound better
Old Feb 19, 2009 | 10:47 PM
Nexx's Avatar
Nexx
which pulley are you using? the rattle lessens with each upgrade. the rattle seems to go away at higher rpms.
Old Feb 20, 2009 | 04:54 AM
y0shi's Avatar
y0shi
i'm currently using the 3.33 pulley. I will be upgrading to 3.12 once it get warmer. How much does the dealer charge for raising the idle?
Old Feb 20, 2009 | 07:33 AM
Mr_pharmD's Avatar
Mr_pharmD
I was charged 65 for the bump. Mine was set to 900 at idle but wierd part is when it's in gear it drops to around 875 so I would bump urs to 950 if possible.
Old Feb 20, 2009 | 02:43 PM
Cass007's Avatar
Cass007
automatic???
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
Calinismo350z
Sep 14, 2015 04:04 PM
