How do you take the engine out with the tranny still mounted?
Old Feb 19, 2009 | 07:50 PM
Blackbird CPV35's Avatar
Blackbird CPV35
Default How do you take the engine out with the tranny still mounted?
This is the second time I have had to take the engine out of my car and I am getting pretty efficient at doing it. Last yeah I took the whole engine and transmission out of the front with the K member still on.
Lately I have been seeing a few threads where the tranny is still mounted to the chassis and the engine is out. I figured that it would be difficult to do this because of the amount of lift to get the engine mounts out of the holes would make it hard for the input shaft to slide out.
anyone got any tips?
here is a pic for reference (sorry to hijack the pic)
Old Feb 19, 2009 | 09:22 PM
iamdigital's Avatar
iamdigital
You don't. I have done this the first time I pulled my engine. After removing the whole thing the second, third, and fourth time I would never try to do it the other way again. It was the biggest PITA to do first time round and I actually broke the upper oil pan on that engine doing it. Remove the whole thing and thank me later. It's simple:
1. remove driveshaft - 2 minutes
2. remove shifter stuff inside car - 10 minutes
3. remove tranny supports and use a tranny jack with wheels to hold it in place
4. pull the whole ***** forward and slightly up. You'll need to watch the steering lines on the axle, break them and it'll be a ***** to replace.
Old Feb 19, 2009 | 09:24 PM
Blackbird CPV35
thats actually how i did it the first time, Looks like ill be doing it like that again, thanks
Old Feb 19, 2009 | 10:24 PM
phunk's Avatar
phunk
CJ Motorsports
i dont imagine the process of lining up the input shaft and motor mounts at the same time would be a good time... but i never tried it this way.
Old Feb 20, 2009 | 06:19 AM
fstrnldr's Avatar
fstrnldr
removing the engine only is great for some vehicles, like subarus, for the Z the trans is so easy to unhook from the chassis i can't think of any reason to ever try and leave it in. One trick i will give you if you are doing this w/ out a lift, is to jack the back of the car up higher than the front when you go to do the actual engine removal. This will give the trans more room to come out level to the ground.
Old Feb 20, 2009 | 06:32 AM
Jeremy@Altered's Avatar
Jeremy@Altered
its all about chaining the cherry picker in the right angle. leave the tranny attached, four more bolts and a shifter with a lot less headaches.
Old Feb 20, 2009 | 06:36 AM
thom000001's Avatar
thom000001
I helped Chris at SP pull my motor. They made a trick little cart that the engine and trans sit in perfectly (larry has madd measuring and welding skills). Engine/trans come out the bottom as a unit attached to the subframe. They are pretty proficient at it now. Took chris and I about 3 hours (with us bs'ing A LOT, and not having access to his toolbox, blocked by a viper hood, so had to find tools in other boxes).
can see cart here when we pulled my motor
tom
Old Feb 20, 2009 | 07:23 AM
GreenGoblin's Avatar
GreenGoblin
I would take the tranny out its much easier
Old Feb 20, 2009 | 01:26 PM
Cass007's Avatar
Cass007
Take it to dinner....and maybe a movie and then some slow jams...
Sorry...
Old Feb 20, 2009 | 01:34 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Since we are showing off tranny's....here is our rack that holds the engine and tranny together.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/67BCKVwtXaw&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/67BCKVwtXaw&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
Old Feb 20, 2009 | 06:32 PM
iamdigital's Avatar
iamdigital
Sharif you suck
Come build a shop out here. I'll help you start it
Old Feb 20, 2009 | 06:33 PM
Car vs. Driver's Avatar
Car vs. Driver
You guys can build it in my garage.
Old Feb 20, 2009 | 07:56 PM
Blackbird CPV35
i cant actually get my car up high enough to drop the K member and roll it out on a car. Im doing this on jackstands in my garage with a cherry picker
Oh well looks like ill have to do it the old fashion way
Old Feb 20, 2009 | 09:59 PM
fstrnldr's Avatar
fstrnldr
like i said if your working on the ground just jack the back up higher than the front when you are ready to pull the engine. It will give you the room for the transmission to clear. The other nice thing to have is a load leveler. You can get a cheap one at harbor freight. Not the best quality, but for a once and a while tool, it should last quite a while. That will allow you to get the angles needed to clear everything w/ ease.
Old Feb 21, 2009 | 06:17 AM
QuadCam's Avatar
QuadCam
what do most of you do with the wiring harness?
do you:
a) disconnect it from the ecu and lay it on top of the motor while pulling the motor out
b) disconnect the harness from the motor/trans and leave it in the car?
Old Feb 21, 2009 | 06:29 AM
thom000001's Avatar
thom000001
I did a. Nissan/infiniti did a good job making it easy to get the whole thing out with the motor.
t
do you:
Old Feb 21, 2009 | 06:30 AM
phunk's Avatar
phunk
CJ Motorsports
depends on how much the engine is taken apart when i pull it. if the upper and lower intakes are already off, ill usually just take the harness off the engine and lay it aside... but if everything is still assembled its really easy to just pull the harness into the bay - i just dont like to upset all my FCON wiring since its rather tight down there.
Old Feb 21, 2009 | 09:23 AM
Blackbird CPV35
I pull the whole harness out into the engine bay. just make a note not to hardwire anything and run it through the grommet where the harness comes into the car. my widebands were wired in that way and I ended up having to cut some stuff
Old Feb 21, 2009 | 09:47 AM
shakuya88's Avatar
shakuya88
Blackbird, you should do a DIY of the engine pull so people who hasn't done it before have some idea how to do it right. Just a thought.
Old Feb 21, 2009 | 11:02 AM
thom000001's Avatar
thom000001
It sounds overly simple but:
decide if you are removing trans before engine or together as a unit.
remove anything that is touching the engine and firewall/fenders/front clip be-it plastsic, metal, wire, or rubber
Then attack supporting engine/engine and trans and remove.
lol
I know its sounds crazy but thats really all there is to it......several hours of work and viola.
tom
