Pulled the motor this weekend. Uh-ohh...
Old Feb 23, 2009 | 02:33 AM
specialized5223's Avatar
specialized5223
Wink Pulled the motor this weekend. Uh-ohh...
Everything looked good except on coil pack 5 was some oil. I'm doing a compression test tonight to see if its the rings, what else could it be that would leak oil and isolate it only in cylinder 5? If it were the valve cover gasket wouldnt there be oil on all the coils in that bank? Are there individual o-rings? I misplaced my spark plug socket so I couldn't pull out the plugs yet. Mind you, this was not a little moisture. There was enough oil on the lower inch of the coil to form droplets...
Thanks. I'm pretty mechanically competant but I just don't have a lot of experience on this **** yet. That takes time...
Old Feb 23, 2009 | 03:31 AM
Glex25's Avatar
Glex25
This is a known issue with the Vq35de motors .
All you needs is a new Valve cover.
The coil pack tunnel on the Valve cover has individual O-rings and have been known to let go one at a time
Old Feb 23, 2009 | 03:58 AM
SuperBlack350z's Avatar
SuperBlack350z
the valve covers act as the o rings and are on their itself. You will need new valve cover(s).
Old Feb 23, 2009 | 04:51 AM
QuadCam's Avatar
QuadCam
as the others have sadi, there is a seal around each spark plug tube. they are IRREPLACABLE. if you have a leak, you need to buy a new valve cover.
Old Feb 23, 2009 | 09:05 AM
specialized5223
thanks guys
Old Feb 23, 2009 | 09:17 AM
TheFarmer's Avatar
TheFarmer
If the oil is on the coil pack and upper half of the spark plug (Not the part that threads into the head) then it's just an o-ring on the valve cover.
If your spark plug tip (The part that threads into the head) is foul'd with oil, then you have other issues.
Old Feb 23, 2009 | 12:00 PM
specialized5223
Thank you for clarifying. That seems to be the case as of current. Is there a more specific part name for said o-ring?
Old Feb 23, 2009 | 12:11 PM
Glex25's Avatar
Glex25
The best pics i can find showing you the information that is being spoken
Old Feb 23, 2009 | 12:30 PM
0jiggy0's Avatar
0jiggy0
As they said, the O-ring is part of the valve cover. You cant get just the O-ring.
Old Feb 23, 2009 | 02:17 PM
Blackbird CPV35's Avatar
Blackbird CPV35
you can actually just use a little rtv silione on the o ring area instead of replacing the whole valvecover
Old Feb 23, 2009 | 02:23 PM
specialized5223
Perfect, I really didnt want to have to wait for a new cover to come in. I'm gonna silicone the **** out of that mofoooooo
Thanks again guys.
Old Feb 23, 2009 | 05:03 PM
350Z400rwhp's Avatar
350Z400rwhp
Thanks again guys.
At least use the "gray" silicone so it can handle the heat.
Old Feb 23, 2009 | 05:05 PM
specialized5223
I have a tube of black, you think that would suffice?
Old Feb 23, 2009 | 05:09 PM
XKR's Avatar
XKR
Thanks again guys.
Good luck...let us know how it works out.
350Z400rwhp
I would just make sure it is high temp stuff.
Old Feb 23, 2009 | 05:41 PM
specialized5223
Permatex Ultra Black
This is the ****. I think it should do the job sufficiently.
And thanks again guys.
Old Feb 23, 2009 | 06:07 PM
Blackbird CPV35
you dont have to silicone the **** out of it, just a thin layer would do. You dont want a bunch of silicone boogers getting into the head if you ever have to take it off
Old Feb 23, 2009 | 07:55 PM
BriGuyMax's Avatar
BriGuyMax
Turbo Whore
Exactly, I had leakage into on the the spark plug tubes on my stock motor, when I built the motor I put a little silicone on the valve cover ring and it hasn't leaked again.
Old Feb 23, 2009 | 08:54 PM
350 Rookie's Avatar
350 Rookie
one thing everyone should keep in their house is the nissan orange silicone. Ive used this on turbos and exhausts and even wastegates and it holds up.
Old Feb 24, 2009 | 02:43 AM
specialized5223
I wasnt really going to paint it. Just excited in discovery of the quick fix ;-)
Fixxxercask
Nov 9, 2015 11:10 AM
