Utec Pro's Chime In!Help Needed!!
Old Mar 2, 2009 | 04:51 PM
aguita's Avatar
aguita
Default Utec Pro's Chime In!Help Needed!!
I have a problem with my utec, When I go WOT below 4k the car bogs and shutters alot..but if i go WOT after 4k the car accelerates fine.
if I accelerate moderatly the car below 4k the car doesnt bogs down or anything on those lines..
Greedy TT,Map Sensor,Etc,490cc
Where should I look at?
Old Mar 2, 2009 | 06:01 PM
rcdash's Avatar
rcdash
Your logs? You really need the wideband data tied in there...
Old Mar 2, 2009 | 06:06 PM
athenG's Avatar
athenG
+1 log will give us a better idea what is causing the bog...
Old Mar 2, 2009 | 08:46 PM
aguita's Avatar
aguita
all this happened after I switched to 750cc and installed the map sensor...On the log data the bar that shows the load is on 0 all over the rev range...Any other inputs??
Old Mar 2, 2009 | 09:00 PM
GreenGoblin's Avatar
GreenGoblin
did you have it retuned after you went from the 490cc to the 750s because the scale factor is probally off.
Old Mar 2, 2009 | 11:47 PM
jining's Avatar
jining
Did you change the load indicator to 1? 0 = MAF 1 = MAP. If so, what are your min and max PSI values set at?
KOF
Tuning
Sep 30, 2015 04:09 AM
