Deatschwerks install question
Old Mar 3, 2009 | 03:56 PM
CaneZMD's Avatar
CaneZMD
Default Deatschwerks install question
I'm installing deatschwerks 600's for my vortech. I pulled out the oem injectors and compared them with the deatschwerks, but the dw's are different.
The OEM attaches to the clips by a nub on the outside and a plastic notch around the circumference of the injector; the dw has no nub and their is no plastic notch, just a gap between the plastic injector body and a metal sleeve at the injector top.
Is this how the DW's are supposed to fit? I got them in, but the clips don't fit very well without the circumferential notch in the plastic.
Old Mar 3, 2009 | 04:06 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
https://my350z.com/forum/mid-atlanti...ch-thread.html
look at post #19
Old Mar 4, 2009 | 04:32 AM
Jeremy@Altered's Avatar
Jeremy@Altered
They are direct fit. Just throw them in there after you make sure you apply oil or their lubricant they provide.
Old Mar 4, 2009 | 04:51 AM
fpacquing's Avatar
fpacquing
give a little tug on the injector after putting the clips to make sure there clipped on right
Old Mar 4, 2009 | 07:08 AM
CaneZMD's Avatar
CaneZMD
Originally Posted by Chef-J
They are indentical to the ones in this thread. I'll make it fit. It's just dificult to get the clips between the metal ring and the plastic flange. The metal ring slides up and down, so it closes off the gap where the clip clips.
Old Mar 4, 2009 | 07:55 AM
350 Rookie's Avatar
350 Rookie
What you need clips for. I ran injectors without clips. Just pop em in and go.
Old Mar 4, 2009 | 01:11 PM
CaneZMD's Avatar
CaneZMD
I was thinking the same thing... they are bolted down by the fuel rail; do they really need to be clipped in also?
Old Mar 4, 2009 | 01:24 PM
350z006's Avatar
350z006
Well...
When I installed my 440's (I use RC's, BTW) I didn't have any problems not having the clips on...but for some reason when I switched to 650's, the stupid injectors kept popping out! It gave me and my tuner nightmares when I was getting tuned....
I finally decided to pop the clips on, and the problems went away...
Just sharing some personal experience...I may have just had some bad luck...
Old Mar 5, 2009 | 03:13 AM
Car vs. Driver's Avatar
Car vs. Driver
That's because you used RC's ...
Old May 15, 2009 | 09:19 PM
Mr_pharmD's Avatar
Mr_pharmD
anyone know if the DW fit with AAM fuel rails?
Old May 16, 2009 | 03:45 AM
Glex25's Avatar
Glex25
They fit fine with my CJM rails so I don't see why they wouldn't with the AAM rails.
Old May 16, 2009 | 05:17 AM
350 Rookie's Avatar
350 Rookie
All injectors will fit, the only thing is with RC injectors, you need another set of spacers for the rails.
Old May 16, 2009 | 05:45 AM
fishclub's Avatar
fishclub
Originally Posted by 350z006
Well...
Did you install the spacer in between the fuel rail and the manifold?
Old May 17, 2009 | 06:00 AM
350z006's Avatar
350z006
Yup
Workshop12
Mar 23, 2020 01:45 PM
TrackFiddy
Sep 24, 2015 11:40 PM
Suffolk350z
Sep 13, 2015 02:43 PM
