Tell me what's wrong/what am I missing?
Old Mar 11, 2009 | 03:22 PM
Rommy's Avatar
Rommy
Default Tell me what's wrong/what am I missing?
The main idea here is to run 450-475HP or so, maybe 500 at most. Here's what I had in mind:
Eagle rods
Wiseco pistons (no overbore)
ARP Headstuds
ARP Mainstuds
A decent Headgasket
Snow stage 2 meth kit
Anyone have any input on this? Am I missing something that would make it unsafe/unreliable at 450-475HP? Give me ideas, guys. I have the Powerlab GT35R kit already, and it will be going in soon. The only thing is that I don't have a huge budget for this.
Old Mar 11, 2009 | 03:27 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Dude it looks like you have been here long enough to have seen some of the builds.
Search dammit.
Old Mar 11, 2009 | 03:40 PM
Rommy's Avatar
Rommy
Search dammit.
Buddy, I've spent WEEKS searching every thread here, but I can't find anyone with similar mods to what I want to do, running the power I'm trying to do, so I needed to make a thread. I've found people with similar mods, but I want to know if I'm missing anything important or crucial before I go ripping things apart. No need to attack me, I'm just trying to do things right here.
Old Mar 11, 2009 | 04:28 PM
SlideFox's Avatar
SlideFox
Pistons/Rods/Fuel/EMS/Clutch that is all...
Old Mar 12, 2009 | 12:20 PM
Rommy's Avatar
Rommy
*bump* anyone have any more opinions they'd like to share before I go spending a few grand on parts?
Old Mar 12, 2009 | 01:15 PM
frankie945's Avatar
frankie945
Rear coolant bypass...
Old Mar 12, 2009 | 02:34 PM
Cass007's Avatar
Cass007
Just a few ideas:
Nissan engine rebuild gasket kit
Pathfinder coolant mod
Rev-Up Oil Pump
NGK one step colder plugs
Upgraded Pulley - may not be necessary
Nismo low-temp thermostat
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
ACL Race main bearings
Heads inspected and cleaned
Heads redecked
All may not be necessary, but if your tearing everything down you may as well built it right the first time. Also, if you are considering cams in the near future, get them done while the motor is out, the labor will be much less.
Old Mar 12, 2009 | 06:43 PM
MethodRN's Avatar
MethodRN
For Sale
Take it to Relentless Autosport?
Old Mar 12, 2009 | 07:29 PM
Cass007's Avatar
Cass007
Maybe a built trans from SGP??
Old Mar 13, 2009 | 04:41 AM
350 Rookie's Avatar
350 Rookie
www.forgedperformance.com
Old Mar 13, 2009 | 06:10 AM
jubes's Avatar
jubes
a good driver
I keed I keed
Old Mar 13, 2009 | 06:18 AM
danisr1's Avatar
danisr1
Sleeps in 350Z
Every mod to keep the engine cool.
Old Mar 13, 2009 | 06:55 AM
Jeremy@Altered's Avatar
Jeremy@Altered
Less fuel and more timing is always the answer.
Old Mar 13, 2009 | 07:20 AM
Rommy's Avatar
Rommy
Originally Posted by jubes
a good driver
I keed I keed
Lol, I'm the one who got rear-ended, not vice-versa. :P
Old Mar 13, 2009 | 07:35 AM
jubes's Avatar
jubes
LOL I know
Old Mar 13, 2009 | 09:44 AM
IntenseSales's Avatar
IntenseSales
Vendor - Former Vendor
DING DING DING, we have a winner!
Old Mar 13, 2009 | 10:19 AM
ToastZ's Avatar
ToastZ
The most important part of a new FI build is being patient and not making quick decisions or trying to take short cuts. You will come up missing your goal and possibly loosing everything you put into the car and some.
Other than that, your good to go with Pistons/Rods/Fuel/EMS/Clutch/HeadGasket/ARP-bolts/Radiator/Fans/Gauges/TT-kit/Luck
Old Mar 16, 2009 | 01:32 PM
boostintt's Avatar
boostintt
im also doing a build... is the rev up oil pump REALLY necessary? or can i just use the non-rev up with less than 30k miles?? im also running water thru my turbos not oil...
Old Mar 16, 2009 | 02:25 PM
Zivman's Avatar
Zivman
Eagle rods
ARP Headstuds
ARP Mainstuds
A decent Headgasket
I would skip the meth injection, just complicates things. At your power levels it won't make much of a difference. If going through a full build definitley buy 20 over pistons. No telling what the holes will be like on your motor and no telling how a stock bore aftermarket piston will match up. Get the pistons and have your machine shop bore accordingly
Jambo016
Sep 16, 2016 01:08 PM
chief3630
Feb 29, 2016 02:54 PM
TrboMike
North East
Sep 28, 2015 06:36 PM
pslamp32
Sep 14, 2015 03:05 PM
