Need help fixing some "Not Ready" Codes
Old Mar 11, 2009 | 04:44 PM
down_shift's Avatar
down_shift
Default Need help fixing some "Not Ready" Codes
I am getting 4 Not Ready's... and no CEL's.
O2
hO2 (heated o2?)
Catalytic
Evap
Is Catalytic meaning Cat converter?
I have the o2's plugged in, I don't have Cats and and my Evap was pulled while doing my build (Built engine, Greddy TT, Haltech + Old Turbonetics Reflash'd Ecu)
any suggestions on how to get these to ready inorder to pass emissions?
Old Mar 11, 2009 | 04:50 PM
doug's Avatar
doug
put your cats back in to pass emissions
Old Mar 11, 2009 | 05:23 PM
Glex25's Avatar
Glex25
Non foulers x2 per side
Check your evap canister, it should never been removed
Old Mar 11, 2009 | 05:24 PM
thom000001's Avatar
thom000001
Well evap is easy...its not there (same with me)
You are getting the o2's for up to 2 reasons...first, you aren't running cats but could also be cause you are running non-stock o2's (if you are but you said no cats). They fail because the computer expects them to get to a certain temp in a certain timframe based on CAT being there.....thats how it knows cat is in place.
To pass emissions put cat back on. Evap will be tough. Don't know the requirements where you live.
Old Mar 11, 2009 | 05:37 PM
down_shift's Avatar
down_shift
You are getting the o2's for up to 2 reasons...first, you aren't running cats but could also be cause you are running non-stock o2's (if you are but you said no cats). They fail because the computer expects them to get to a certain temp in a certain timframe based onCAT being there.....thats how it knows cat is in place.
The cat is a weird one since I never had one to start with. I had a Turbonetics kit on my car before and the Cat was always marked READY.
Old Mar 11, 2009 | 05:59 PM
thom000001's Avatar
thom000001
Makes sense though. Before when you had the TN, the exhaust was going up to the Turbo then through the DP down through the exhaust.
Now the turbos are lower and much closer to the cat. So they are heating faster (too fast) for the stock computer. Get the non-foulers to fix that.
Evap you may be outa luck though.
t
Old Mar 11, 2009 | 06:39 PM
doug's Avatar
doug
here in CT they physically look for cats
Old Mar 11, 2009 | 07:46 PM
Glex25's Avatar
Glex25
The OP is in Chicago.
I don't know how they do it over there.
I'm in NJ they don't really inspect for cats unless you give them a reason.
You probably think I live in CT because I spend so much time out there.
but thanks for info on CT checking Cats.
Old Mar 11, 2009 | 07:50 PM
doug's Avatar
doug
i thought he was in MA
Old Mar 11, 2009 | 08:05 PM
Glex25's Avatar
Glex25
Sorry you right.
He is in Boston
Old Mar 11, 2009 | 08:49 PM
down_shift's Avatar
down_shift
I'm in MA.
I'm gonna get under the car this weekend and make sure I have those defoulers installed right.
I figured it's kind of weird I have NO CEL's... JUST NOT READY's!!
Maybe I need to drive it some more? It's been about 130 miles + whatever dyno tuning (quarter tank of gas)
Old Mar 11, 2009 | 08:55 PM
Glex25's Avatar
Glex25
I'm in MA.
K i thought you had CEL's
Maybe some CEL you disabled with the Osiris app won't let you get OBDII ready.
The only thing I can think about is rewiring your MAF
back in and see what happens.
If I'm not mistaken you have a AIT sensor wired in correct?
Old Mar 12, 2009 | 05:22 AM
Cass007's Avatar
Cass007
It sounds like you are running a re-flashed ECU, just not the TN re-flash. My TN re-flash threw codes constantly, but an Up-Rev or similar re-flash won't throw the code, but will show the sensors as not ready or pending like the OP is having issue with.
Dave from F:T seems to think that the O2 codes can be fixed with simulators and proper spacing of the sensors. If you still have your stock exhaust lying around, it may be the easiest fix. Most states that plug into the OBD port will allow one pending code and still pass. Good luck OP.
Old Mar 12, 2009 | 05:54 AM
down_shift's Avatar
down_shift
I also have the MAF in the car also.
No Osiris here, just the TN reflash (as far as I know)
I'm going to change my battery today since it was acting up a few days ago. (car's been sitting for 10 months) See if it resets my ecu and we can start fresh.. Gonna go under the car tomorrow to check if my non foulers are still there.
Old Mar 12, 2009 | 06:13 AM
terps's Avatar
terps
yo do any work with cipher? it will eliminate the codes but will give you that error. i would imagine that the reflash is messing it up and would set it back to stock settings, drive 40 miles on easy throttle(once maf voltage goes over a certain point it wont reset until the car is reset). and then put the reflash back in place good luck
Old Mar 31, 2009 | 09:39 AM
chopperman's Avatar
chopperman
Bump this thread
Im getting the same codes and I have the exact same setup runinng a F con v pro and I am not getting any CEL's. What can I do about my evap? Im in NY btw.
Old Apr 22, 2010 | 03:09 PM
350z_widebody's Avatar
350z_widebody
so i have a h02 problem i ran diagnostic and it read h02 bank 2 fault, im woundering which of the four ho2 sensors is it? can anyone please help, thanks.
Old Apr 22, 2010 | 04:53 PM
rcdash's Avatar
rcdash
If you get not ready codes and have NOT disabled CELs using a reflash (Osiris can selectively disable DTC codes), then you just haven't driven enough in the pattern required by the FSM.
Uriyo_
Sep 8, 2021 08:46 AM
derekinthez
South East
Sep 28, 2015 06:35 PM
Detailed Image
Cleaning & Detailing
Sep 28, 2015 03:03 AM
