New Stainless Motor Mounts
Old Mar 20, 2009 | 08:24 PM
QuadCam's Avatar
QuadCam
Default New Stainless Motor Mounts
Here's a pic of my new motor mounts. They are made out of 304 Stainless and then TIG welded. I used the same size studs as Nissan so that the factory nuts can be reused on these mounts. (still not sure why nissan uses a 10mm stud on one end and a 12mm stud on the other. )
Using these mounts will cut just over 5 pounds off the car.....I know that's not a lot, but every little pound helps out. Hopefully, I'llget around to installing these soon......Installation should be a PITA since I already have a greddy twin kit installed. That outta make getting access to the top 10mm nut very difficult.
Old Mar 20, 2009 | 11:26 PM
thom000001's Avatar
thom000001
taking all the luxury outta the luxury car are ya lol...
let us know how you like them. I've been thinking poly mounts. Don't quite want the harshness of solids.
tom
Old Mar 21, 2009 | 05:12 AM
QuadCam's Avatar
QuadCam
I've been in other solid mount Z, and I didn't feel much of a difference in NVH. I guess time will tell when I install these.
Old Mar 21, 2009 | 06:25 AM
SmallTuner's Avatar
SmallTuner
they look like the SGP ones
i have the SGP, and the Forgedperformance. new didnt use the
i any body like them 100$
Old Mar 21, 2009 | 06:26 AM
BoostedProbe's Avatar
BoostedProbe
Very simple, and looks good. Why not use stainless studs too?
Old Mar 21, 2009 | 06:37 AM
QuadCam's Avatar
QuadCam
I couldn't find stainless studs in the right thread size. the M12 x 1.25 isn't a very common size. Plus, stainless is fairly soft and can't take as much torque as a GRade 8 fastener before going into plastic deformation. Stainless isn't an ideal fastener for taking a high tensile load. these don't take that much torque (about 75 ft-lbs or so) but I'd rather be safe. I used wheel studs....definately designed to take some torquing (or overtorquing!)
Old Mar 21, 2009 | 08:01 AM
Quamen's Avatar
Quamen
Looks good Quad!!! I agree that solid mounts in a Z aren't that bad. I have been running them for two years now with a light weight flywheel and I love them!!!
Those are some nice quality!!!
Old Mar 21, 2009 | 08:22 AM
XKR's Avatar
XKR
Lets know how they feel when you test them...
Old Mar 21, 2009 | 08:55 AM
QuadCam's Avatar
QuadCam
thanks Quamen......I appreciate the comments....especially comign from you. I have followed some of your threads, and you have made some very nice stuff...including your motor mounts.
Old Mar 21, 2009 | 08:58 AM
Those are trick.
Old Mar 21, 2009 | 09:20 AM
phunk's Avatar
phunk
CJ Motorsports
looks nice.. what wall thickness tubing did you use?
Old Mar 21, 2009 | 09:31 AM
QuadCam's Avatar
QuadCam
Charles,
I used 2" 304SS Pipe... the OD is approx. 2.375." the end plates are 1/8" 304 Sheet.
Old Mar 21, 2009 | 09:33 AM
vinniePOOH's Avatar
vinniePOOH
are you installing them yourself?? if so, do a DIY on these bad boys. i've been wanting these solid mounts! where did you get them??
Old Mar 21, 2009 | 12:50 PM
phunk's Avatar
phunk
CJ Motorsports
I need to get something line this soon... I think it will aid me with more clearance for piping my new turbos... I just need to research and find out if there is any reason I wouldn't want them for a build like mine
Old Mar 23, 2009 | 04:15 PM
vinniePOOH's Avatar
vinniePOOH
would these be as good as the one that QUADCAM has??
http://www.injectedperformance.com/e...ID=4478&VID=36
Old Mar 23, 2009 | 04:21 PM
projektZ's Avatar
projektZ
yes do let us know how that feels. My b/f has solid motor mounts in his built 240 and I feel like I'm riding in an Apache helicopter with the vibrations/noise. lol
Old Mar 23, 2009 | 05:30 PM
Quamen's Avatar
Quamen
The one thing I have too say about the stud design is that it makes putting the motor in and taking it out a PITA. I remember the first time I put the motor in with the stock mounts it took me forever. Now, since I am using a bolt design, I can just remove the bolt and pull the mounts out with a lift supporting the engine via a strap. No tugging or pulling other than some simple pivoting to get over the powersteering line under the motor.
Obviously the stud design has multiple advantages over the bolt design and looks cleaner as a product IMO.
Your gonna love them Quad!! I would say that out of all the mods I have done N/A, solid mounts had the largest impact on driving enjoyment for me. Not to mention the helped me keep tight clearances on all the stock in my engine bay. Otherwise my supercharger would torque right into my radiator
Old Mar 23, 2009 | 06:14 PM
QuadCam's Avatar
QuadCam
well...I went to install them and I got to the driver's sdie unit first. the greddy kit really get in the way for getting access to the upper nut on the factory mount.
As such, I had to use several extensions and swivels to gain access to it. according the FSM, there should only be about 50 ft-lbs of toque on that nut. HA!!!!! that biotch is on there!!!!! needless to say, I used my impact gun to remove it. Unfortunately the socket wasn't seeatewd properly when I pulled the trigger.........
I rounded off the head on the nut completely!!! totally sux. I put the car back together and have since picked up some special sockets for rounded off bolts/nuts. Hopefully, they work. if not, I'll have to pull the motor to get to the motor mount.......and I am not planning on pulling the motor right now!
I'll post up later this week if I can get to this job and I'l take some pics.
Old Mar 23, 2009 | 09:40 PM
down_shift's Avatar
down_shift
Looks really raw
I'm curious to see how they feel in a G. I had some MM's on my RSX to help wheel hop (fwd ftl) and the vibrations were not my cup of tea.
Old Mar 24, 2009 | 03:49 AM
Quamen's Avatar
Quamen
Originally Posted by down_shift
Looks really raw
I could see solid mounts being annoying on a 4-cylinder since there is less cylinders firing per rev. We put solid mounts in our Porsche 928 V8 and there was no difference in vibration at all.
