Sharing my Vortech experience
Old Mar 26, 2009 | 12:26 PM
jpc350's Avatar
jpc350
Default Sharing my Vortech experience
After I started her up today I noticed the blower made a louder than its usual grinding sound...I pulled on the blower (forward ) to see if it had any affect and surprisingly it did..Much quieter. Checked all mounting bolts to verify they were not loose. So I cut a piece of wood and wedged it so that the blower is pushed forward and now the blower is much quieter..Apparently the mounting plate is not quite aligned properly and pushing the whole assembly forward helped...Strange but true. Need to find a permanent fix.
Old Mar 26, 2009 | 12:27 PM
kacz07's Avatar
kacz07
Yeah, a thick piece wood in a hot engine bay? Only under the covers, bro.
Old Mar 26, 2009 | 12:35 PM
civic4982's Avatar
civic4982
you can always take that piece out and have it cut in alumnium or something then replace it.
Old Mar 26, 2009 | 01:04 PM
booger's Avatar
booger
You probably got a spacer in the wrong place
Old Mar 26, 2009 | 02:36 PM
jpc350's Avatar
jpc350
Default spacer
No, ran fine for about 20k miles w/o this noise...Maybe a shift in alignment?
Old Mar 26, 2009 | 04:01 PM
str8dum1's Avatar
str8dum1
odd.
pics of what you did?
Old Mar 27, 2009 | 06:10 AM
jpc350's Avatar
jpc350
Originally Posted by str8dum1
odd.
Need a digi camera..Imagine approx. 5 in. X 3/4 dia. wedged between the back of the blower motor (around 1 pm) and up against the structure between the bracket for the stock air box and a cable run..Crazy but it eleminated the noise...
Old Mar 27, 2009 | 11:43 AM
Car vs. Driver's Avatar
Car vs. Driver
So you're basically pushing the whole bracket forward from behind (no pun)?
Old Mar 28, 2009 | 08:31 AM
jpc350's Avatar
jpc350
Exactly.. I Replaced the wood with a steel tube. Seems to eleminate a load on some bearing(s)..
Old Mar 28, 2009 | 01:09 PM
rx7/350z's Avatar
rx7/350z
i see it now, "the home depot mod" . Pics please
350Z_Al
Oct 29, 2020 07:44 PM
Workshop12
Mar 23, 2020 01:45 PM
May 30, 2017 03:28 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
dcains
Nov 11, 2015 11:36 PM
