Used Injectors... Clean them before Installing?
Old Mar 26, 2009 | 07:51 PM
skn5002's Avatar
skn5002
Default Used Injectors... Clean them before Installing?
I have a set of 440cc that were previously used for around 5k miles. They look to be in great condition, but should they be cleaned in any special way before installing (besides wiping them down and lubing the orings)? If one of the injectors do not work, how would I be able to tell upon start up?
Old Mar 26, 2009 | 09:18 PM
FredB's Avatar
FredB
your car will sound like a subaru. google an injector facility that cleans and rebuilds injectors in ur area and they can help further.
Old Mar 26, 2009 | 09:20 PM
wannabuy350z's Avatar
wannabuy350z
Get them flow tested before installing them.
Old Mar 26, 2009 | 09:22 PM
fstrnldr's Avatar
fstrnldr
personally i would send them out and have them actually cleaned before installing them. I don't know the history on them, but i would never trust a used set of injectors in my engine w/ out having them cleaned and flow tested. As far as the o-rings before you put the intake back on turn the car to on (DO NOT TRY TO START IT you just want to prime the fuel pump) and look for leaks. You won't know if the intake side leaks until you actually have it all back together and start it up, then you can listen for signs of a vacuum leak. Most of the time if you have them cleaned, they will also include some new seals though.
Old Mar 27, 2009 | 01:00 PM
Cass007's Avatar
Cass007
+100 on all the above advice. Have them flow tested and cleaned - better safe than sorry.
Old Mar 28, 2009 | 10:40 AM
skn5002's Avatar
skn5002
Alright I'll be sending them out to have them tested and cleaned this week. I found a place that seems pretty reputable that does injectors for $18 each. Here's their site: http://www.witchhunter.com/
Old Mar 29, 2009 | 01:32 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Let me know how it goes.
Old Mar 29, 2009 | 01:50 PM
JETPILOT's Avatar
JETPILOT
Send them to Deatschwerks.
Old Mar 29, 2009 | 07:43 PM
fstrnldr's Avatar
fstrnldr
i've used them before w/ great results.
_bit
Oct 2, 2015 07:49 AM
nanotech
Oct 2, 2015 05:02 AM
