Getting HKS CAMP system for Procharger...Questions
Old Sep 14, 2003 | 05:58 PM
keepupp's Avatar
keepupp
Default Getting HKS CAMP system for Procharger...Questions
I am putting in my order tomorrow for the HKS CAMP system to monitor Exhaust Temp, Boost, and Fuel pressure...is there something else I am missing? Is there any way with the CAMP system that I can monitor if my fuel is going too lean? Even after installing my own Procharger I am still a novice so any input would be great! Most of my posts have been questions (for that I apologize) but you guys have been more than helpful. Thanks you!
Dan
Old Sep 14, 2003 | 07:11 PM
redlinez's Avatar
redlinez
What monitor do you plan to use to view these readings? Where are you going to put it? I have Nav and have been wondering if the CAMP system would work with it. Please keep us informed.
Old Sep 14, 2003 | 07:13 PM
rouxeny's Avatar
rouxeny
Definitely keep us informed.
I'm thinking about it.
Old Sep 14, 2003 | 08:48 PM
MY350Z.COM's Avatar
Default Re: Getting HKS CAMP system for Procharger...Questions
Dan
what screen are you using for the CAMP system? what connection does the CAMP system use to output video?
Old Sep 15, 2003 | 04:58 AM
keepupp's Avatar
keepupp
I already have a monitor installed in the Nav spot, the Panasonic CY-VM5800U. The CAMP utilizes the audio/video inputs in amy monitor....it comes with a remote and remote sensor to change settings. Here is the link...
http://www.hksusa.com/products/?id=651
Old Sep 15, 2003 | 12:03 PM
5thgenluder's Avatar
5thgenluder
Im taking it that you are wondering if there is a air/fuel monitor on the camp system and as far as i know the answer is no. I didnt think anyone else even knew about the camp ive been lookin at it for 2 years and still have been unable to find anyone with it installed. Dont forget you need the harnesses for boost and fuel press and also the junction box.
Old Sep 15, 2003 | 12:15 PM
IPT's Avatar
IPT
Give these guys a call ask for Chris
www.scienceofspeed.com
They have had them installed on there NSX'S
They can answer any question you might have
parker
www.iptmotorsports.com
Old Sep 15, 2003 | 12:16 PM
IPT's Avatar
IPT
http://www.scienceofspeed.com/produc...ducts/NSX/HKS/
Old Sep 15, 2003 | 12:32 PM
mcduck's Avatar
mcduck
redlinez...
I had wondered the same thing and posted the question in another thread. I was told the factory Nav uses a different type of video connector/feed so the HKS Camp will not work directly with it.
There is a chance you could put some type of line adapter for it to work, but I have no idea whether this would be an off the shelf item or something you have to fabricate.
let me know if you find a way to do it and I'll do the same because I'd rather run the Camp through the factory LCD screen than add a second screen elsewhere in the cockpit.
Old Sep 15, 2003 | 12:53 PM
IPT's Avatar
IPT
Originally posted by mcduck
redlinez...
Adaptor for factory nav
you can find at
www.navtv.com
call the and they will point you to a retailer that has it in your area
it is exspensive like 800.00 last i checked
one guy has it here on the board
name
abyiss
i think
parker
Old Sep 15, 2003 | 01:14 PM
MY350Z.COM's Avatar
yeah InternetAbyss aka Jason has the NavTV, I believe he was the first.
Victor
Old Sep 15, 2003 | 01:43 PM
keepupp's Avatar
keepupp
parker
Thanks! I will give him a call.
Old Sep 15, 2003 | 02:57 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
There is no A/F monitering option for the CAMP - closest you can get is EGT but even that can be very misleading in terms of reading A/F without other info (timing, etc.)
Best bet overall would be a wideband 02 sensor...something along the lines of the FJO setup, works very very well
Also sent you a PM about the CAMP - we have one set in stock that a customer cancelled
Adam
Old May 23, 2005 | 03:48 AM
CESAROTORRES's Avatar
CESAROTORRES
Adam
Adam,
What is the FJO setup?
THX!
Cesar
sales@czp
Sep 23, 2019 03:30 PM
nanotech
Oct 2, 2015 05:02 AM
