colder plugs
Old Apr 1, 2009 | 12:39 PM
balla33's Avatar
balla33
Default colder plugs
just recently install some one-step colder plugs and now the car starts sluggishly, idling roughly jumping and falling until it picks up later but drives normal, just wondering is that normal for colder plugs or did i do something wrong, thanks
Old Apr 1, 2009 | 12:59 PM
coachk's Avatar
coachk
We need more info on your car...What ems, FI, etc..... Did you leave the gap the way they came? Also what plugs did you use and part # ?
Old Apr 1, 2009 | 01:18 PM
Jeremy@Altered's Avatar
Jeremy@Altered
Probably switched around 6 and 4 cylinders.
Old Apr 1, 2009 | 08:54 PM
balla33's Avatar
balla33
vortech supercharger with a reflash by technosquare and yes i left the gap the way it came in it was ngk's LFR6AIX-11
Old Apr 1, 2009 | 08:55 PM
balla33's Avatar
balla33
i did each cylinder at a time
Old Apr 1, 2009 | 08:56 PM
balla33's Avatar
balla33
i also did just install some 550cc injectors so could this have any conflict
Old Apr 1, 2009 | 09:15 PM
RevengeM.S.'s Avatar
RevengeM.S.
550cc injectors are the problem.
The car needs to be dyno tuned now with -HKS / UTEC / HALTEC -ect.
Old Apr 1, 2009 | 09:26 PM
balla33's Avatar
balla33
so the reflash does notin for the injectors
Old Apr 1, 2009 | 09:32 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Did you reflash ECU after installed injectors? or before?
Old Apr 1, 2009 | 10:02 PM
balla33's Avatar
balla33
yea just got my ecu back yesterday tuned for 550cc injectors from technosquare
Old Apr 2, 2009 | 12:09 AM
wannabuy350z's Avatar
wannabuy350z
your tune is off, do you have an afr gauge? probably your combustion mixture is flooded with fuel.
Old Apr 2, 2009 | 04:01 AM
Jeremy@Altered
that was the important part you left out, car has to be tuned.
Old Apr 2, 2009 | 10:10 AM
balla33's Avatar
balla33
no afr gauge
Old Apr 2, 2009 | 10:18 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Try contact with technosquare, do you have any ems running with? You running bigger injectors, i don' tknow it will be ok just get the reflash.
chefj
Old Apr 2, 2009 | 10:37 AM
350 Rookie's Avatar
350 Rookie
retune and set the plug gap lower too.
Old Apr 2, 2009 | 12:01 PM
balla33's Avatar
balla33
how much lower? its claims to come around .40-.44 which is perfect for our engines
Old Apr 2, 2009 | 12:05 PM
350 Rookie's Avatar
350 Rookie
You shoulda atleast checked the gaps. When im FI, i gap them to around .32.
Old Apr 2, 2009 | 12:07 PM
Tac-M's Avatar
Tac-M
wow....
s/c and no tune? no a/f gauge ? and then 550cc ?
step away from the vehicle !!!
Old Apr 2, 2009 | 12:29 PM
boostedmaxima's Avatar
boostedmaxima
Originally Posted by Tac-M
wow....
Old Apr 2, 2009 | 08:12 PM
balla33's Avatar
balla33
wow ecu reflash = TUNED
