Gas Smell On full tank ?
Old Apr 15, 2009 | 12:13 PM
Dirty Dave's Avatar
Dirty Dave
Default Gas Smell On full tank ?
Ever Since my AAM return fuel system was installed on a full or close to full tank the interior will get a gas smell in it. Also if I let the car sit the next morning I will come out to a small puddle of gason the ground by the front of the passenger rear tire. This only happens when I fill the tank above 3/4. Is there a rubber seal I can replace or is the problem bigger ? Thanks, Dave
Old Apr 15, 2009 | 12:30 PM
IslandZavage's Avatar
IslandZavage
replace the fuel pump top O-Ring.. I had the same issue.. It expands when gas touches it and doesnt have a seal. Most likely when you open it the ring will be expanded, and that is most likely the cause...
Old Apr 15, 2009 | 12:45 PM
ToastZ's Avatar
ToastZ
1. Inspect the o-ring, replace it.
2. Also, double check that the correct bolts were used during re-assembly. The bolts that attach the fuel pump assy. to the fuel tank are very short bolts with fine threads. If the wrong length bolts (ie longer) were used you may have a worse problem. The bolts are also easy to strip out due to the fine threads and short length, so you may think about replacing them too after inspection.
Old Apr 15, 2009 | 12:49 PM
frankie945's Avatar
frankie945
You have another problem if there is a puddle of fuel on the ground. The large O-ring on top of the fuel cell needs to be replaced. Like mentioned above ^. You can pick one up at the dealer for cheap. The shop should have replaced it when it was installed. I had a fuel smell when I did my walbro install. Then I replaced O-ring,, Fixed.
If you had a shop install it I would take it back, mainly because it should have been done right. And you should not have any fuel on the ground that's dangerous.
Old Apr 15, 2009 | 01:14 PM
djamps's Avatar
djamps
Yea i had the same problem when it was installed (minus the fuel on the ground) but I took it back and they replaced the seal and it's perfect now.
Old Apr 15, 2009 | 02:07 PM
JS04's Avatar
JS04
Yea, had that same issue happen to me. The o-ring swelled. Just cut a lil piece out of it. Relayed it down and the problem was gone.
Old Apr 15, 2009 | 03:25 PM
BrianLG35C's Avatar
BrianLG35C
I think this is what's happening with mine again. This will be the second time my o-ring will need replaced.
Something about filling it up to full causes a problem with these o-rings.
Old Apr 15, 2009 | 03:40 PM
ToastZ's Avatar
ToastZ
I had to replace my gas tank to fix this problem, long story, many $$$,... but no more fumes in the end.
Old Apr 15, 2009 | 07:40 PM
BrianLG35C's Avatar
BrianLG35C
Details? What did you have them check? I'm headed to my dealer tomorrow and I'd love to give them some direction other than the o-ring.
Thanks Paul!
Old Apr 15, 2009 | 08:30 PM
Mr_pharmD's Avatar
Mr_pharmD
Thanks Paul!
can u get a part number for the o ring? I ahve that stupid fuel smell also... I always thought it was bc of the aam fuel system.
Old Apr 16, 2009 | 03:33 AM
BrianLG35C's Avatar
BrianLG35C
This was on my last receipt...
17342 - 01A00
Old Apr 16, 2009 | 08:32 AM
Dirty Dave's Avatar
Dirty Dave
I wish it was that easy the shop that installed it is out of business now. Thanks everyone for the input I will have to check all those things out.
Old Apr 16, 2009 | 03:35 PM
Mr_pharmD's Avatar
Mr_pharmD
17342 - 01A00
Thanks... say, how much do they usually run?
Old Apr 16, 2009 | 03:41 PM
BrianLG35C's Avatar
BrianLG35C
$10.
Old Apr 16, 2009 | 03:48 PM
Ed 718's Avatar
Ed 718
BRAVEHEART
Here is a tip for replacing that O-ring since I had to modify the fuel pump for my old turbo install. What I did was put the O-ring in the freezer to make it easy for that O-ring to sit properly. Once that O-ring get fuel on it it expands and makes it hard to sit properly and subject to a leak. It can be a pain in the *** if it gets fuel on it.
Old Apr 21, 2009 | 10:26 AM
BrianLG35C's Avatar
BrianLG35C
Any updates?
Old Apr 21, 2009 | 11:34 AM
QuadCam's Avatar
QuadCam
make sure that you only have 1/2 a tank of gas or less when you go to replace that o-ring. when the tank is full, the full level is higher than the service port for the fuel tank! GAS WILL POUR OUT OF THE TANK!!!!
Old Apr 21, 2009 | 03:49 PM
Mr_pharmD's Avatar
Mr_pharmD
any do it yourself with pix on changing the o ring?
Old Apr 21, 2009 | 05:35 PM
str8dum1's Avatar
str8dum1
undo the 6 or so screws on the cover on the fuel tank above the fuel basket. take out old o-ring that goes between the cover and the fuel tank. replace with new o-ring.
Old Apr 21, 2009 | 06:15 PM
Mr_pharmD's Avatar
Mr_pharmD
nice, thanks.
