K&N's in place of foam filters
Old Apr 20, 2009 | 04:47 PM
Greddytwin350Z's Avatar
Greddytwin350Z
Originally Posted by RandomHer0
I have a big Koyo (not installed though). I took off the intake piping, from the car, fitted the filters, then put everything in as 1 piece. I couldnt get them in otherwise.
Ok, thats what I will do aswell. Do you happen to have any pics? How close are they to the radiator support? How did you know how far to shove them on? Or did you go so far then try to install and work it on until they would fit? These filters are special order so I wont get until Fri or Sat. I hope to get them on quickly! Thanks, Robert
Old Apr 26, 2009 | 01:59 PM
Greddytwin350Z
Well I tried to instal the K&N RX-4960's and I cannot fit them in there! I didnt want to hurt the filters by shoe horning them in but it was clearly not in the cards for my car. I have to many other goodies in the way especially on the driverside. I am currently selling them on the regional Mid-A classified section at a great price if anyone is interested. I am going to try the smaller K&N's. But I want to sell the ones I have first. If anyone out there thinks they have the room and would like to get rid of the mushrooms of death these are the best filters K&N sells. Thanks for everyones input. Robert
Old Apr 26, 2009 | 02:59 PM
eltness350's Avatar
eltness350
The Untouchable
sorry that they didnt fit...i did the shoehorn thing
Old Apr 26, 2009 | 03:44 PM
doug's Avatar
doug
here you go..
Originally Posted by doug
this thread just reminded me i needed to change my mushrooms also..
i just got these http://www.clemmonstrading.com/servl...tail#itemadded
$38.96 each before shipping.. Larry (Jet) is running these
i got mine to fit.. no cutting.. just a little elbow greese
Old Apr 26, 2009 | 04:08 PM
Greddytwin350Z
I am going to try RX-4020-1 next! I still want the X-stream filter. They are only 4" long and only a 4" top dia. I want them but I need to sell the others first. I will do a fellow member a heck of a deal on them to get some green for the next ones. Anyone out there with no mods that want to get rid of the bad shrooms
Old Sep 22, 2009 | 04:45 PM
Jay'Z's Avatar
Jay'Z
I run RX-4960
Did not cut piping, but did push them on a little further to get them to fit.
Random this is false advertising!!! No way, I just got those filters and not even close to fitting...
Maybe a G...... Not a Z......
Old Sep 22, 2009 | 04:56 PM
Jay'Z's Avatar
Jay'Z
RX-4020-1
Just ordered these..... Ill let u guys know how it works...
Old Sep 22, 2009 | 04:59 PM
doug's Avatar
doug
i don't think he ended up with those.. he had some custom ordered ones.. but the ones i have fit perfectly for me
Old Sep 22, 2009 | 05:20 PM
Jay'Z's Avatar
Jay'Z
TOO Fawking big...
Part RX-4960 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 2.75 in (70 mm)
Flange Length: 2 in (51 mm)
Flange Type: Centered
Height: 5.5 in (140 mm)
Top Outside Diameter: 5 in (127 mm)
Top Style: X-Stream
Top Material/Finish: None
Filter Re-Oiling Amount: 0.96 oz (28 ml)
Footnote 1: Filter has molded-in velocity stack
Weight: 1.3 lb (0.6 kg)
Product Box Length: 6.88 in (175 mm)
Product Box Width: 6.88 in (175 mm)
Product Box Height: 7.88 in (200 mm)
Sounds like the right size!! Hoping they will get here tmrw!!
Part RX-4020-1 Product Specifications
Base Outside Diameter: 4.25 in (108 mm)
Flange Inside Diameter: 2.875 in (73 mm)
Flange Length: 0.938 in (24 mm)
Height: 4.75 in (121 mm)
Top Outside Diameter: 4 in (102 mm)
Top Style: X-Stream
Filter Re-Oiling Amount: 0.63 oz (19 ml)
Weight: 0.9 lb (0.4 kg)
Product Box Length: 4.63 in (117 mm)
Product Box Width: 4.63 in (117 mm)
Product Box Height: 7.25 in (184 mm)
Doug's Filter
Part RC-9350 Product Specifications
Base Outside Diameter: 4.688 in (119 mm)
Flange Length: 0.813 in (21 mm)
Height: 4.875 in (124 mm)
Top Outside Diameter: 3.5 in (89 mm)
Top Style: Metal
Top Material/Finish: Chrome
Filter Re-Oiling Amount: 0.75 oz (22 ml)
Weight: 1 lb (0.5 kg)
Product Box Length: 6.38 in (162 mm)
Product Box Width: 6.38 in (162 mm)
Product Box Height: 6.75 in (171 mm)
Old Sep 23, 2009 | 05:02 AM
Jay'Z's Avatar
Jay'Z
So these RX-4020-1 dont fit either????
Old Sep 23, 2009 | 05:07 AM
doug's Avatar
doug
better thread: https://my350z.com/forum/forced-indu...ment-part.html
Old Sep 23, 2009 | 05:22 AM
Jay'Z's Avatar
Jay'Z
I added ur filters....... I dont wanna bump that thread too.. Size looks very similar when stacked side to side.... Hoping i dont need to cut piping...
Old Sep 23, 2009 | 09:30 AM
Alberto's Avatar
Alberto
Cranky FI Owner
K&N on Greddy setup FTW! I hate the foam mushrooms...
Old Sep 23, 2009 | 10:07 AM
Jay'Z's Avatar
Jay'Z
Wow.. That looks as you must have cut piping right?? I mean i went all the way back but them filters were too big..... Ill be getting the other set tmrw overnighted.. Ill post pix of them.. Should be better..
I pulled the foam crap out.. I washed them but they didnt seem dirty on the inside at all.. The foam does look discolored in certain places not sure why... I measured the foam filters and its almost exact match to what i ordered... Cant wait!
Old Sep 23, 2009 | 10:11 AM
superchargedg's Avatar
superchargedg
Damn Noobs
I had to cut the piping on the drivers side to fit the AEM dryflows.
Old Sep 23, 2009 | 10:19 AM
Jay'Z's Avatar
Jay'Z
Ok...... Fawk..... I may cut it if the other set doesnt fit..
Old Sep 23, 2009 | 10:54 AM
doug's Avatar
doug
i had no cutting on the filters i bought.. just an FYI
Old Sep 23, 2009 | 11:00 AM
  #38
Jay'Z's Avatar
Jay'Z
Ill try the filters I already ordered.. If they dont fit.. Ill prob try another.. I really dont wanna cut the pipes.... But I may..
Old Sep 23, 2009 | 11:08 AM
  #39
doug's Avatar
doug
*kicks Jay in the nuts* Buy my ****ing filters *****
Old Sep 23, 2009 | 11:10 AM
  #40
Jay'Z's Avatar
Jay'Z
LMAO I will get "Dougs K&N's" next..... Thats my next try.. But I ordered the 2nd set last night already..
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
