K&N's in place of foam filters
Old Apr 15, 2009 | 02:19 PM
Greddytwin350Z's Avatar
Greddytwin350Z
Default K&N's in place of foam filters
I know I read on here that guys with Greddy kits swapped out the very cheap foam filters in place for some higher quality K&N's or similar filters. I looked in the search section but couldnt find it. Any help? I have the foam filters on my Greddy kit and wouldnt mind swapping them out. Thanks
Old Apr 15, 2009 | 03:03 PM
tiguy99's Avatar
tiguy99
In for the info as well. I was going to ask the same question when I saw those.
Could you do this with the HKS systems too?
Old Apr 15, 2009 | 06:17 PM
Greddytwin350Z
Wow, no one? Come on guys, I know I read about this last summer or fall so some of you have this. I am dying for the exact filter part #. I cant remeber if there was any other brand but K&N but I want something better than the foam.
Old Apr 15, 2009 | 06:33 PM
XKR's Avatar
XKR
Here is the info you requested. This is what I use for my twin turbo 850bb setup. If you need t see more pictures...just click on my cardomain page in my sig.
Old Apr 15, 2009 | 07:09 PM
eltness350's Avatar
eltness350
The Untouchable
i went with the biggest u can pretty much fit in there ....lol
http://s70.photobucket.com/albums/i1...stuff035-1.jpg
RU-3610
Old Apr 16, 2009 | 11:13 AM
Greddytwin350Z
RU-3610
Did you have to move anything? The one on the driverside looks huge! Thanks for the info, the foam filters breath better but do you notice any power loss or boost pressure loss? Thanks, Robert
Old Apr 16, 2009 | 11:22 AM
JasonZ-YA's Avatar
JasonZ-YA
I think this is the thread your talking about?
https://my350z.com/forum/forced-indu...acement-2.html
my buddies car...........
-J
Old Apr 16, 2009 | 11:24 AM
Greddytwin350Z
[QUOTE=XKR;7211958]Here is the info you requested. This is what I use for my twin turbo 850bb setup. If you need t see more pictures...just click on my cardomain page in my sig.
Will the filter fit on the Greddy piping? I see why you put the elbow on it but I have my catch can on the other side. So I wouldnt need to. I dont think the size of the filter makes a difference when making power. But I would like something more reliable than the foam. I like the size of these. I thought the tubing was a 3" dia? I think this filter is a 2.5" dia. Thanks
Old Apr 16, 2009 | 08:52 PM
eltness350's Avatar
eltness350
The Untouchable
intake tubing is 2.75inches
Old Apr 17, 2009 | 02:51 PM
Greddytwin350Z
Thanks guys, I like the idea of using the extrems but I cant get on the K&N website!!! I just went and measured and unlike some of these guys I dont think I can use a filter any longer than 4". Any longer on either side and I will hit my radiator support. Thanks for the links and help guys. I really appreciate it.
Old Apr 17, 2009 | 02:59 PM
XKR's Avatar
XKR
[QUOTE=Greddytwin350Z;7214443]
He is correct 2.75.....Stay away from foam.
Old Apr 18, 2009 | 03:37 PM
Greddytwin350Z
RU-3610
How did you fit a 7" long filter in there? I measured today and from the back of the foam filter housing to the radiator support I only have about 4"-4.5"! I am trying to find an X-stream filter to fit. I see you kinda clocked your driverside piping. Did you also cut some of the tubing too. Has anyone used an X-stream filter with luck? Thanks, Robert
Old Apr 18, 2009 | 03:58 PM
Greddytwin350Z
I just also found an AEM #21-202DK. I personally have never used one of these dry filters. Has anyone else? Thanks
Old Apr 19, 2009 | 03:29 PM
RandomHer0's Avatar
RandomHer0
I run RX-4960
Did not cut piping, but did push them on a little further to get them to fit.
Old Apr 19, 2009 | 04:10 PM
eltness350's Avatar
eltness350
The Untouchable
+1 didnt do any cutting...jus pushed them into the piping a bit to get then to fit
Old Apr 20, 2009 | 04:34 AM
psychoballistic's Avatar
psychoballistic
Excellent info guys, looking to toss the foam also and get something different.
+1
Old Apr 20, 2009 | 04:56 AM
doug's Avatar
doug
here is another thread: https://my350z.com/forum/forced-indu...hlight=Filters
Old Apr 20, 2009 | 01:50 PM
Greddytwin350Z
Originally Posted by RandomHer0
I run RX-4960
Thanks RandomHer0
It just worked out for me that I ordered a pair of the RX-4960's today! The only thing is I also have a koyo R core radiator. I wonder if that will affect how much space I have? I know there is a lip on the inside of the filter. Was it easy to push past it without hurting the filter? Thanks, Robert
Old Apr 20, 2009 | 03:13 PM
RandomHer0's Avatar
RandomHer0
I have a big Koyo (not installed though). I took off the intake piping, from the car, fitted the filters, then put everything in as 1 piece. I couldnt get them in otherwise.
Old Apr 20, 2009 | 04:10 PM
IslandZavage's Avatar
IslandZavage
should have a before/after dyno w/video by tuesday evening for u guys if ur interested?!?!?!
