Injector install question
Old May 1, 2009 | 05:46 AM
moog's Avatar
moog
Default Injector install question
So I'm returning back to stock, and I removed my Vortech kit. Last night I finally got around to installing my stock injectors. After I reinstalled everything, I did not immediately prime the system to check for leaks. *mistake on my part* Plenum and everything got put back on.
My question is...if I didn't lube the o-rings with motor oil, how likely will they be to leak? That's like 28 bolts I don't want to take off again to check.
Old May 1, 2009 | 06:04 AM
failsafe306's Avatar
failsafe306
i've never tried. best thing to do would be to just suck it up and pull it apart again. There's a 50/50 chance you'll need to anyway, so why not?
Old May 1, 2009 | 06:20 AM
moog's Avatar
moog
Looking through the parts diagram, looks like I also didn't have these spacers for the fuel rail.
Old May 1, 2009 | 07:50 AM
350 Rookie's Avatar
350 Rookie
Did you even turn on yet? Turn on and check for leaks.
Old May 1, 2009 | 08:12 AM
moog's Avatar
moog
not yet...i primed the system a few times and didn't smell anything yet. I just swapped out my oil pan, so I filled it up w/ oil last night. Letting it sit for a day to see if any leaks when I get home from work. Will fire it up tonight.
Old May 1, 2009 | 08:28 AM
Glex25's Avatar
Glex25
moog if you didn't put the spacer in you will have to take off the rails to put them in
so while your there might as well take out the injectors and lube em.
I used a Qtip and lubed the injector O-rings and the cavity where the injectors go in
to play it safe.
Old May 1, 2009 | 08:40 AM
moog's Avatar
moog
are the spacers really that important? I ran without them when I had the 440 injectors in there.
If I have to put the spacers in, I will go ahead and put new o-rings in there along w/ the injector clamps. Service manual says to NOT use rubber gloves when handling the o-rings. What's the reason behind that?
Old May 1, 2009 | 08:46 AM
350 Rookie's Avatar
350 Rookie
Start the car and check for leaks. IF no leaks, dont worry about nothing.
Old May 1, 2009 | 08:53 AM
GreenGoblin's Avatar
GreenGoblin
I do not remeber those fuel rail spacers with stock injectors, with taller ones yes, but stock I do not think so.
Old May 1, 2009 | 08:57 AM
Glex25's Avatar
Glex25
The stock injectors uses spacers
bcoffee20
Nov 19, 2015 06:39 PM
seagrasser
Oct 11, 2015 03:27 PM
BlinkerFluid
Sep 8, 2015 10:06 AM
