View Poll Results: Should I stick with JWT C2's or get bigger cams?
Stay with JWT C2's
34.48%
Get JWT C8's, JWT C9's or GTM Stage 3's
19
65.52%
Voters: 29. You may not vote on this poll
Poll: Stick with JWT C2's or go with Bigger Cams
Old May 9, 2009 | 11:48 AM
str8dum1's Avatar
str8dum1
he's using that tuned GTR now...
Old May 9, 2009 | 12:30 PM
ttg35fort's Avatar
ttg35fort
Professional
Originally Posted by Sharif@Forged
With the big turbo, and stroker, I would definately upgrade to something with more lift and duration. Rarely, do I find myself needing more midrange on a road course....but I could always put a little more top end power to good use.
To get more lift and duration, I will need to go with the JWT C8's or C9's, which I was leaning toward anyway.
Old May 9, 2009 | 01:00 PM
ttg35fort's Avatar
ttg35fort
Professional
Sharif, what cams are you using in XKR's last build (not 1.000 RWHP beast, but the one he is running until that is ready)?
Old May 10, 2009 | 06:23 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
C2's, but that was used with his previous power goals and much smaller turbos. New setup is getting C8's.
Old May 10, 2009 | 06:26 AM
Sharif@Forged
Forged Performance
Originally Posted by SmallTuner
sharif, that time attack beast is realy fast, i saw the video on youtube
still using the jwt S1 cams and a forged S1 short block with egale rods and arias pistons.
good work
We retired the 350Z, but yes it was running S1 Shortblock, and small cams from years ago...before the other grinds were available. I'll be running the GT-R this year in RTA.
Old May 10, 2009 | 06:59 AM
Tyler4's Avatar
Tyler4
Only the cool guys have C8's
Old May 10, 2009 | 07:49 AM
ttg35fort's Avatar
ttg35fort
Professional
I have been looking seriously at the C9's, but with that much overlap, I am worried about reversion becoming an issue.
I was even thinking of having the intake camshaft gears machined to allow me to retard them by 5-10 degrees in order to reduce the overlap, and then use the Osiris Tuner software to re-flash the ECU to advance the cams at the RPMs where needed.
Still, the C9's may sacrifice too much low-mid range torque, so the C8's may be the ticket if I change.
Sharif, what do you think about retarding the C9's and using the Osiris Tuner software to advance them where required?
Old May 10, 2009 | 08:43 AM
SmallTuner's Avatar
SmallTuner
Good Luck
Old May 10, 2009 | 08:48 AM
SmallTuner's Avatar
SmallTuner
cool guys !! what makes them cool
man , the price is just in the same range.
Old May 10, 2009 | 10:51 AM
ttg35fort's Avatar
ttg35fort
Professional
The C2's and the C8's are the same price.
The C2's will provide better low-mid RPM torque, while the C8's will provide better top end performance.
I don't want to give up too much low-mid RPM torque. However, I am increasing the stroke of my motor from 81.4mm to 90mm, which will increase my torque, though some of this increase may be offset by changing from the Greddy TD05H-18G turbos to the Garrett 3071 turbos (0.64 A/R).
Nonetheless, with my 3.5 L motor and the C2's, I was still getting some wheel spin in 3rd gear when the turbos fully spooled up (even with Toyo R888 305 tires on the back). Thus, some of the torque in the mid RPM range was unusable.
So, perhaps the C8's will open up the top end while not spinning the tires in 3rd gear... I'm thinking that with the C9's I will lose to much torque in the low-mid RPM range. Anyway, I'm still debating, but starting to lean again toward the C8's as a nice balance for this build.
Old May 10, 2009 | 02:11 PM
Tyler4's Avatar
Tyler4
The C8's are the only cam I've had with my build so I cant compare the mid range to anything else. But I do know that power up top is sick.
They do help me hook up, thats for sure. I can hook almost 100% in second gear with 600whp DD. Overall, I'm happy with them.
Old May 10, 2009 | 04:06 PM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
def. go bigger then the c2's. at least c8's. from what i remember, our machine shop did a head with the c8r's for the revup and had to take a little bit of casting out of the head so the lobes would have a decent amount of clearence.
Old May 10, 2009 | 06:07 PM
ttg35fort's Avatar
ttg35fort
Professional
If you caught my post here before I edited it, ignore it. I was discussing C8's and not C8'Rs, which are different cams.
Old May 11, 2009 | 05:01 AM
ttg35fort's Avatar
ttg35fort
Professional
OK, I'm back to going with the C8's.
It's funny, that was my original plan as I stated in maximariceboi's cam thread.
I should have just went with my first instinct instead of driving myself crazy.
Old May 11, 2009 | 05:23 AM
coachk's Avatar
coachk
Good choice... you won't regret it. You already know my opinion
BTW I did a sound vid(cams/exhaust) of my car and will try to get it to you soon.
Old May 11, 2009 | 06:02 AM
ttg35fort's Avatar
ttg35fort
Professional
Cool.
Old May 11, 2009 | 06:48 AM
Jtran Studios
which is correct, but both set of cams do the same amount of lift and also duration. one cam is for the non revup and the other cam is for the revup. that is the reason why i posted.
Old May 12, 2009 | 03:12 PM
  #38
SmallTuner's Avatar
SmallTuner
Cams are like Drinks
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
B Esquire
Sep 24, 2015 07:52 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
