Greddy TT, Stock Block, 8.5PSI DYNO - Video!
Old May 9, 2009 | 09:11 AM
RandomHer0's Avatar
RandomHer0
Default Greddy TT, Stock Block, 8.5PSI DYNO - Video!
Some faired REALLY well, and some maybe it was a heartbreaker. This was on a AWD Mustang Dyno, in Ottawa Ontario Canada.
I made 356whp and 369tq @8.5PSI AFR 11.3WOT and 4th Gear. I was hoping for more, but after seeing some cars make less than expected, and some make MORE than expected I didnt know what to expect LOL
The RPM on the print out seems to be off, we went all the way to redline 6800+
Thoughts? Comments? Anything more I can do?
Greddy TT, K&N Filters, 5/16" Spacer, FI Resonated Test Pipes, HKS True Dual Exhaust.
I'm thinking bigger DP and Exhaust might help? My goal was to see atleast 400, but every dyno is different.
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/yRjYTU4erGw&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/yRjYTU4erGw&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
Old May 9, 2009 | 09:53 AM
350 Rookie's Avatar
350 Rookie
What ems and who tuned it?
Old May 9, 2009 | 10:12 AM
RandomHer0's Avatar
RandomHer0
UTEC, street tuned by a local member, we have no close tuners to us so it's DIY.
Old May 9, 2009 | 11:33 AM
str8dum1's Avatar
str8dum1
best bet would be rent dyno time. you cant really optimize timing without a dyno to see actual gains and losses.
but i'd be happy with where its at now. nice safe #'s
Old May 9, 2009 | 11:34 AM
thom000001's Avatar
thom000001
5th gear is 1:1 in our cars too
Old May 9, 2009 | 11:40 AM
RandomHer0's Avatar
RandomHer0
Ya my buddy said he dyno'd in 5th Gear too, I didn't think that was right, we did 3rd, it was 337, then 4th gave these results, maybe 5th would have given better results...
I'm not trying to set records, the car is fun as hell, I just wanna drive the **** out of it safely lol
Old May 9, 2009 | 11:50 AM
240zx's Avatar
240zx
Why did you only rev the car to 58xx RPM? From the looks of the graph it seems that it would have made more power if you spun the car higher.
Old May 9, 2009 | 11:53 AM
RandomHer0's Avatar
RandomHer0
In my post I said the RPM on the chart seems to be off, we went all the way to 6800+, so Im not sure what happend there...
Old May 9, 2009 | 01:53 PM
BaZooKa's Avatar
BaZooKa
I think with the Evo TT, on a dynojet, 5th gear you will see 400 ..
Old May 9, 2009 | 02:07 PM
str8dum1's Avatar
str8dum1
take it to a dynojet. if your rpms are all messed up who knows what else is wrong with that chart. No sense tryin to figure it out when it obviously has problems
Old May 9, 2009 | 02:15 PM
thom000001's Avatar
thom000001
my car 4th vs 5th seems to make about a 13% difference in power.
Old May 9, 2009 | 04:39 PM
RandomHer0's Avatar
RandomHer0
Damn thats a lot.
Thanks for the input guys!
Old May 9, 2009 | 10:32 PM
Germanguy's Avatar
Germanguy
nope, exhaust is also "quite" good for FI imo, because its true dual. so the car is wrong dynoed. please put it for us to another dyno!
Alex
Old May 10, 2009 | 04:14 PM
Jtran Studios's Avatar
Jtran Studios
Vendor - Former Vendor
what was the smoothing for that dyno run? that torque kinda takes a big nose dive.
Old May 10, 2009 | 04:57 PM
str8dum1's Avatar
str8dum1
thats not that big of a drop, the scale makes it look worse.
look at most of the shop build threads. they lose way more than 30 ft-pounds by the end of the pull
thats also assuming that the rpm scale is wrong, like the OP suggests.
Old May 10, 2009 | 05:29 PM
Blwn_By_Twins's Avatar
Blwn_By_Twins
Can't remember exactly my numbers on a the Mustang, but it was in the same area. Like 36Xwhp I think. On a DJ at the same boost I made 416whp.
Old May 11, 2009 | 10:38 AM
TopNotch's Avatar
TopNotch
something does look a little strange about the dyno print out, doesnt tq always cross hp @ 5250 rpms?? Since this is how Hp is calculated?
Old May 11, 2009 | 11:21 AM
str8dum1's Avatar
str8dum1
the left and right scales are different, so they wont line up
Old May 11, 2009 | 11:24 AM
JZurita's Avatar
JZurita
Whoa, what's going on with your torque?
sales@czp
Sep 23, 2019 03:30 PM
