New built engine starts. but wont stay on!!
Old May 10, 2009 | 10:08 PM
boostintt's Avatar
boostintt
ok i just went to garage and in fact the MAF is facing the wrong way! i will flip it tomorrow and hopefully thats it!!!!!!!!!!!!!
Old May 11, 2009 | 06:28 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^Aren't they go only one way to install?
Old May 11, 2009 | 06:30 AM
boostintt's Avatar
boostintt
yes. i had to modify mine so it ended up the wrong way.. problem fixed!!!! car idles just fine. good oil pressure, good temp. just need to put everything else back on the car and take it to exhaust depot!!
thanks everyone!!!
Old May 11, 2009 | 06:34 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
GOOD ! Are you going to update your thread man...more pic please =)
Old May 11, 2009 | 06:41 AM
GreenGoblin's Avatar
GreenGoblin
Glad to hear it was nothing major.
Old May 11, 2009 | 08:33 AM
maximariceboi's Avatar
maximariceboi
sweet!
Old May 11, 2009 | 09:20 AM
boostintt's Avatar
boostintt
ohhhhh God!!! now its the clutch!!!! i bleed the clutch and still not responding
no more air bubbles but clutch still sticks when i press it ???????????????
i have the JWT clutch and pressure plate...
is my slave cylinder bad???
Old May 11, 2009 | 10:14 AM
boostintt's Avatar
boostintt
i press the clutch all the way down and i can feel pressure but when i release it the slave cylinder still fully out and does not retract
Old May 11, 2009 | 10:43 AM
boostintt's Avatar
boostintt
when i put the fork and the throw out bearing on the tranny i did not snap the little ball behind the fork... my old tranny the little ball was broken off. but everything worked fine. i tried snapping the ball behind the fork but it wasnt going in.. thats y i left it like that.. but i guess it is in fact supposed to be there?
could this be the reason why the slave cylinder is not retracting? if so... then i'll pull tranny out and do that.
Old May 11, 2009 | 10:53 AM
boostintt's Avatar
boostintt
ok before i pulled the tranny you can see inside right behind the fork and you can see the little ball is in place... no need to pull the tranny.
any other suggestions? pressure plate too tight??? bolts too tight?
Old May 11, 2009 | 11:07 AM
boostintt's Avatar
boostintt
update: just found out there are different forks. and i think im using the wrong one. mine is hollow and the bolt on the tranny is not tall enought so i have to replace the fork for a thicker fork so it can match up with the bolt (ball)
Old May 11, 2009 | 12:39 PM
captj3's Avatar
captj3
If you are dropping the tranny just get the pivot ball from the dealer. You most likely need the one from a 300zx. It's about 1.5" long. I have the same one on my Z. They just unscrew from inside the housing. You may have to change more than just the fork.
Old May 11, 2009 | 01:26 PM
boostintt's Avatar
boostintt
^ i might just have to replace the pivot ball... no need to drop the tranny.
Old May 11, 2009 | 03:32 PM
Cass007's Avatar
Cass007
Stick with it man, you're almost there.
Old May 11, 2009 | 03:36 PM
boostintt's Avatar
boostintt
thanks dude!!! that means alot!!! im a very patient individual and i can cope with stress but this is getting me very frustrated!!!! i hope the end result is everything i dream of!!!!!!!
now time to remove the transmission
Old May 11, 2009 | 07:36 PM
ACI318's Avatar
ACI318
Did you change the tranny or fork when you pulled the motor?
Glad I could help with the MAS problem, I did the same once that how I new what it was.
Old May 11, 2009 | 08:30 PM
boostintt's Avatar
boostintt
HEY.. thanks for the help btw!!!
this is what happened on the tranny:
my old tranny was grinding, my buddy had a cd009 tranny which he thought was giving him issues, but in fact it was his clutch not the tranny. he took that tranny apart to see if there was anything wrong with it but it was fine. he sold me the cd009 in pieces and all i had to do is use a few parts from my old tranny and piece everything together.
when i took my tranny out that pivot ball was broken, so i used the one from his cd009 but i reused my old fork... now i got the fork that goes with that pivot ball and i will be replacing that tomorrow and bleeding the coolant system!! hopefully that will let me drive the car!!!!!!!!!!!!
Old May 11, 2009 | 08:54 PM
  #38
ACI318's Avatar
ACI318
Yeah that would be my first place to start. The 009 tranny pivot ball and fork are suppose to help with the fix of the trans tearing up. Just get whatever parts you need to make it work and GL.
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
