will deatschwerk injectors fit AAM fuel rails???
Old May 16, 2009 | 09:21 AM
Mr_pharmD's Avatar
Mr_pharmD
Default will deatschwerk injectors fit AAM fuel rails???
I have the AAM fuel rails with RC injectors right now but I was thinking about switching over to the DW 800cc injectors. Anyone know if the AAM fuel rails fit STOCK or DW injectors without modifications?
Old May 16, 2009 | 10:12 AM
Clint@Altered's Avatar
Clint@Altered
They work perfectly! We use them all the time.
Old May 16, 2009 | 10:16 AM
frankie945's Avatar
frankie945
I'm almost sure they will work. At least I hope so. I just bought a used aam stage 1 FRS. I know with RC injectors you will need the spacers. The Deatchwerks no spacers because they are taller then the RC's. I should know for sure At the end of next week when I do the install. Will post up results if they will work or not, if we do not get a straight answer.
Edit: ^ That is good to know thanks...
Old May 16, 2009 | 10:21 AM
Mr_pharmD's Avatar
Mr_pharmD
Thanks for the help Clint... can u pm the best deal for DW 800cc if u have them in stock.
Also, I thought DW were the same size as the stock injector? If they are taller, will these fit with stock intake manifold with the AAM fuel rails?
Old May 16, 2009 | 11:34 AM
TinmansZ's Avatar
TinmansZ
I've been running the AAM rails and Dw inj. for a few years no problems at all.
350z82
Oct 1, 2015 06:25 PM
