Who says vortechs can't make power...
Old Sep 22, 2009 | 08:54 AM
  #61
350z006's Avatar
350z006
Details on your custom pulley? May consider moving to that in the future...
Old Sep 22, 2009 | 12:27 PM
  #62
str8dum1's Avatar
str8dum1
GTM sells the machined 2.60.
Or just buy a 90$ 2.60 from Vortech and take it to your local machine shop with a lathe and match it up to your current pulley for like $10.
They are just too thick from vortech.
Old Sep 22, 2009 | 12:35 PM
  #63
Mr_pharmD's Avatar
Mr_pharmD
I thought I was the only one that had the 2.60 bc I know vortech has a 2.62
Old Sep 22, 2009 | 01:50 PM
  #64
eltness350's Avatar
eltness350
The Untouchable
great numbers!! vid time!!
Old Sep 22, 2009 | 01:52 PM
  #65
350z006's Avatar
350z006
It's a 2.62...although I don't know if there's much of a difference between a 2.62 and 2.60 pulley...I'm more worried about slippage; I get that at about 12.5~13 psi on my revup kit...
http://www.gtmotorsports.com/product...roductid=16472
If your custom pulley is cheaper that GTMs I may go your route of getting that pulley...
Also, since you're a Cali guy, do you have your fuel regulator out in the open in the engine on your RFS setup, or are you "stealthing" it...
I ask since I try and keep my setup looking as stock as possible just in case I get pulled over...Cali sucks like that...
Old Sep 22, 2009 | 02:36 PM
  #66
str8dum1's Avatar
str8dum1
you can get 2.6 pulleys from 928m for ~70 each (although I am not sure if we have a 17 or 200 shaft)
http://www.928motorsports.com/parts/powerpulley.php
http://www.928motorsports.com/parts/6ribpulley.php
get yourself a 2.25
still need to get it lathed but they are CHEAP
Old Sep 22, 2009 | 03:23 PM
  #67
eltness350's Avatar
eltness350
The Untouchable
Quamen on here works for 928motorsports if u guys need a opinion/hookup
Old Sep 22, 2009 | 05:01 PM
  #68
Mr_pharmD's Avatar
Mr_pharmD
Wow, those 928 pulleys are cheap.
I think I paid around 180 but mine does have groves (instead of straight edges) that prevent slippage. As u can see from my dyno sheet, 18psi at WOT and no drop in boost.
Old Sep 22, 2009 | 05:20 PM
  #69
str8dum1's Avatar
str8dum1
ahh so you got one of the Reicherd Racing ultra grips then huh?
ya those are pricier and chew up belts, so keep an eye on that. you bust your serp belt, you are f'd
although spinning the blower at 64,000 might get ya 1st
Old Sep 22, 2009 | 05:53 PM
  #70
Mr_pharmD's Avatar
Mr_pharmD
Damn Bro, u are good, lol...
Hey how u get 64,000? I think I got 59,000 when I did the calculations.
Old Sep 23, 2009 | 01:26 AM
  #71
marra23's Avatar
marra23
Curious, see str8dum1 mentioned you needed larger injector to break 500whp...you're still on the 800cc and what's your IDC at?
What's the max you can spin that T trim at safely?....if 64000, sounds to high.
Old Sep 23, 2009 | 03:42 AM
  #72
mafoor's Avatar
mafoor
Vortech says the max rpm for a t-trim is 55,000...but ive been told u can take them a lil higher n it "SHOULDNT" hurt anything
Old Sep 23, 2009 | 12:16 PM
  #73
str8dum1's Avatar
str8dum1
5.75" crank
either 32/28 or 34/30 and a 2.60 at 7000 rpms is 64000 rpms
800cc should be 85ish or more IDC at that HP
Old Sep 23, 2009 | 01:28 PM
  #74
Chef-J's Avatar
Chef-J
Booooosstt!!
That's one beautiful pulley. Any reason you choose to go with 2.60?
Old Sep 23, 2009 | 01:37 PM
  #75
marra23's Avatar
marra23
5.75" crank
cool,
9000rpms ain't a lil higher.
Old Sep 23, 2009 | 10:04 PM
  #76
Mr_pharmD's Avatar
Mr_pharmD
5.75" crank
for some reason I thought the non revs were 32/30.
Anyway, I doubt it's really going to affect it much bc the rpms fly sooo fast for it to do any real damage (only 400rpm difference from 6600 to 7000). Also if u think about it, everyone seems to be running the 2.87 pulley with a 32/28 so they are also overspinning their blower at 6600rpm... not as much as mine but still over 53000rpms.
Old Sep 24, 2009 | 01:57 AM
  #77
OldManZ350's Avatar
OldManZ350
Hay Mr_PharmD,
I know you have a T-Trim, But what have you done to the Motor?
Can you list out the Details?
Do you have a Larger InterCooler?
Did you do any other modifications to your Vortech Kit other than a T-Trim and a 2.60 Pulley and Injectors?
Note: I have an SC-trim Non Revup 32/28, 2.87 rev to 7100=58,687rpm @ Blower
Thanks
Tim
Old Sep 24, 2009 | 05:33 AM
  #78
str8dum1's Avatar
str8dum1
^did you even look at page 1?
It really doesnt matter. 4000 impeller rpms isnt much but when you are already 5000 rpms past the recommended limits...
But if it fails oh well, if not great. rebuilds are cheap. The blower is still making power.
Next step would be get that bigger 6.7" ATI crank pulley. Alot more belt wrap. Hopefully you can do that soon.
Old Sep 24, 2009 | 07:51 AM
  #79
Mr_pharmD's Avatar
Mr_pharmD
Lol, u're making me worry now but the only way to see how much this T trim can really handle is to push it to the limits
Old Sep 24, 2009 | 08:02 AM
  #80
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by OldManZ350
Hay Mr_PharmD,
Thanks
Tim
Wow, I really like your times and it was your setup that helped prevent the slips. I c u aren't afraid to push your blower either.
Setup: basic stuff
CP heavy duty pistons 9:1 (I should have done 9.5:1)
Eagle Rods
ACL bearings
L19 head studs
PE head gaskets
DW800cc
stock heads
revup oil pump
Nismo R cams
Alphawerk headers
Kinetix cats
borla exhaust
Mrev 2+ with 5/16spacers
AAM stage 1 fuel setup and pump
Koyo radiator and 2 slim fans
pathfinder cooler mod
Competition stage 4 clutch
Vortech T-trim with 2.60
Snow performance stage 2 meth kit
GTM idler
GTM oil cooler
HKS VPRO
HKS knock
HKS CAMP2
Technosquare reflash
AT to MT conversion
New stuff ordered: nismo thermostat, OEM water pump and BBK 8/6pots
