Has anyone broke off the differential mounting bolt? Well, I did.. :(
Old Jun 8, 2009 | 09:43 AM
GreenGoblin's Avatar
GreenGoblin
Negative Mike would not work with out some modifications
Old Jun 8, 2009 | 09:57 AM
aarantes's Avatar
aarantes
I would be interested in this too. If you could send me a PM with how much shipped to 30066?
Thanks
Old Jun 8, 2009 | 10:14 AM
XKR's Avatar
XKR
Old Jun 8, 2009 | 10:31 AM
SoundPerformance's Avatar
SoundPerformance
Sound Performance
Originally Posted by XKR
Id suspect that you would have to grind the section between those 2 bolts holes flat on either side for our brace to work. Shouldn't be too much work.
Old Jun 8, 2009 | 10:38 AM
XKR's Avatar
XKR
PM me the price please with shipping to FP
Old Jun 8, 2009 | 10:59 AM
IIQuickSilverII's Avatar
IIQuickSilverII
you will need this mike
Old Jun 8, 2009 | 11:06 AM
XKR's Avatar
XKR
I agree Jorge.....I just dont want to get stranded. I am not sure what high tq does to that rear end with non drag racing cars
Old Jun 8, 2009 | 11:20 AM
thom000001's Avatar
thom000001
It still stresses it A LOT.
Any time you have traction the diff is trying to rotate in some way or another.......enough traction and enough tq and it will eventually break regardles of speed
I'll be getting one installed as soon as i get car over there
tom
Old Jun 8, 2009 | 05:03 PM
GreenGoblin
Mike I personally would take the Nismo cover off and mill the necessary areas to accommodate the brace. Would only take a couple mins once setup. Also are you running the solid mounts?
Old Jun 8, 2009 | 05:28 PM
XKR's Avatar
XKR
I will do that then
Old Jun 12, 2009 | 10:26 AM
XKR's Avatar
XKR
DID not receive the PM on price
Old Jun 12, 2009 | 10:49 AM
bbs350z's Avatar
bbs350z
sp, you guys have that in your shop? my car should be down there sometime next week, and i have a nismo diff cover. if possible, we could do some grinding, and mockup, and see how it fits, and what needs to be done for the rest of the people interested in this?
Old Jun 12, 2009 | 10:50 AM
XKR's Avatar
XKR
Old Jun 24, 2009 | 10:58 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
I finally got around fixing this and then some..
I had my shop make differential bushings out of urethane. Then I also had a machine shop make a differential cover bolt out of stronger material. Now, my differential housing has a minimal movement. It seemed like my differential housing bushings were all shot to hell, so the movement was putting too much stress on the bolt.
Here is a shot of my urethane bushing:
I also inspected all my other rubber bushings and they weren't looking too good. So, this is what I did...
I'm absolutely sold on the pillow ball setup. It does NOT make any noises, and handling and cornering has drastically improved over stocker...
Old Jul 29, 2009 | 04:44 PM
SnyperZ's Avatar
SnyperZ
Can you PM me a price on those SP braces as well?
Old Jul 29, 2009 | 09:35 PM
350Z400rwhp's Avatar
350Z400rwhp
Originally Posted by thom000001
Not sure on pricing, I'll get the sp boys to chime in.
Anyone have pics comparing the nismo finned cover to a stock cover?
Here are pics of the brace installed.
So I assume the SP Brace is an easier way to support the Diff rather than replacing the rubber support with an aluminum one which requires removal of the diff and pressing out the old rubber one (which I heard is a pita) to install. I have wheel hop issues at the track and was told that this is caused by the diff not being supported buy the single rubber bushing (mine has even ruptured). Would this eliminate wheel hop? I'm going to call SP tomorrow but does anyone have an idea on pricing of this support? I'm sure there will be some added driveline noise but at least this looks easy to take off if I ever return the car to stock and want to sell it.
Old Jul 29, 2009 | 10:33 PM
leeboyNY's Avatar
leeboyNY
Kimchi Eater
You need to drill two holes through your rear suspension frame. Not too difficult if you have the tools.
Old Jul 30, 2009 | 05:50 AM
  #38
djamps's Avatar
djamps
Is this even on their site? I can't seem to find any info on it. Maybe it was just a one-off?
Old Jul 30, 2009 | 07:53 AM
  #39
rrmedicx's Avatar
rrmedicx
I hope a large template is included so there is no guessing where to drill. I can't imagine mis-aligning those big holes and screwing up your entire rear sub-frame. Ouch!
Old Jul 30, 2009 | 02:31 PM
  #40
350Z400rwhp
I would rather do that then try and ruplace the rubber bushing with an aluminum one. Does he reduce wheel hop? How much?
